Project: Blue Chieftec Dragon
Discussion in 'Project Logs' started by Bbq.of.DooM, 21 Nov 2005.
  1. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Not the official name. Havent thought of one yet.
    That's basicly the plan.
    Front grille cut out.
    Back cut out. Originally meant for watercooling. I sold my watercooling, then it was meant for dual psu. I didn't need dual psu, so now it's being refitted for dual silverstone 120mm's.
    My awesome leet fake dremel I got for 10 bucks. huhu.
    http://img475.imageshack.us/img475/3875/dsc018186xh.jpg
    The second PSU that I tried to fit in. It fit, but I didn't need a second. It's been turned into a TestPSU since.
  2. Bbq.of.DooM
    12 Feb 2005
  3. Bbq.of.DooM
    12 Feb 2005
    The system specs:
    AMD Opteron 146 CABYE
    ASrock 939dual-sata2
    512mb Samsung ram
    80gb Western Digital WD800
    Radeon 9250
    Some of it's old hardware, but that's all I can afford at the time, and also reusing a lot of my old rig in here.
  4. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    So all you gonna du is place a daul pcu and two sidepanels?
    What about a window in the top?
  5. Bbq.of.DooM
    12 Feb 2005
    It's not going to be dual PSU anymore, 2 fans instead there. The right sidepanel, the black on the drawing I did, it's gonna be drilled out extremly fine, like a grille. The top already has a large square window, I'll have pics tomorow. Thanks.
  6. Klekkus
    5 Nov 2005
    Ohhh, now i get it.
    It sounds cool that :rock: I like the idea of tha back. ;)
    Great so see one more chieftec mod on this forum, take a look in my signature (Project: Black Pearl, The Curse) for more ideas. Maby even a comment :D
  7. Bbq.of.DooM
    12 Feb 2005
  8. Bbq.of.DooM
    12 Feb 2005
  9. Klekkus
    5 Nov 2005
    jupp i chosed 2x80mm fans in the front and the bak in my project :D
  10. Bbq.of.DooM
    12 Feb 2005
    I already have 2 80's in the front, 2 80's in the mobo tray, 2 120's in the back (possibly), dual fan psu, and 2 floor fans (to be cut).
    Probubly not, actually. The front will probubly have no fans, and the phase change compressor. It all really depends though.
  11. Bbq.of.DooM
    12 Feb 2005
    Alright. There's some updated bits (hdd rack re-installed, top window sanded, grilles for right side, etching, wire management, etc etc) but then right after I got the pictures uploaded onto my P4 and deleted them from the camera, the hard drive on my P4 dies. That, and the heatsink on my Athlon T-bird killed itself, chipped die, overheating. Kinda hard to work when your pc's die on you, taking all the pictures with them. I'll try to re-create those as soon as possible, but until my Opteron comes, don't expect too much in the way of an update. Thanks for the patience.
  12. Bbq.of.DooM
    12 Feb 2005
    Alright. Sorry for the long time with no updates. I finally got some of my hardware in.
    Currently running
    AMD Opteron 146 CABYE 0536 Oc'd to 2.6
    ASRock 939dual-sata II
    2x256 Crucial Ballistix DDR 400
    80gb WD 800
    Radeon 9250
    2x Silverstone 120mm
    Zalman CNPS 7700AL CU
    OCZ Powerstream 420w
    Stuff to come
    Hydor L45
    DTek Storm
    Dual heatercore
    A C Ryan grille (hey they have the same name as me!)
  13. Bbq.of.DooM
    12 Feb 2005
    I haven't really had much time to work on it recently.
    My plan:
    Chilled water.
    New watercooling parts:
    Magdrive V
    DTek whitewater
    10 feet Tygon tubing
  14. Bbq.of.DooM
    12 Feb 2005
    Woah. Havent posted here in ages.
  15. The_Gimpy
    The_Gimpy What's a Dremel?
    15 Jul 2004
    Hey! I have that same dremel knockoff. I couldn't pass up the deal at canadian tire to pick it up. Hows it work for you? I haven't put mine to use much.
  16. Bbq.of.DooM
    12 Feb 2005
    Mine works really well. Only fault is that it's quite a bit bigger and heavier than a dremel. It's also an advantage when you're etching.
    Also, the case already has been "upside-down" 'd. Suprisingly, if you drill out all the rivets and put it upside down, most of the holes will already be aligned with other holes on the other side. Only the psu rail needed some drilling, and aside from that, it's a perfect match.
  17. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Do I see a phasechange compressor there in your sketch? That's sweet :) Though I seriously doubt it's going to fit in such a small place. Also you should keep in mind the evap tube is at the top of the compressor.. I think you'd better place it at the bottom somewhere. By the way is that thing going to chill your liquid cooling system or just the CPU?
    By the way you forgot to place a link to this thread in your log (or I just missed it).
  18. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    Sweet sketch up ;)
    Just got the same mobo yesterday :)
  19. Bbq.of.DooM
    12 Feb 2005
    Koradhil: Yeah, phase change compressor. I have a slimline DVD slotload coming in. It's gonna be chilled liquid. Kinda hard to draw the coils inside the reservoir. The design will be quite flexable (flexable stainless steel hoses connecting most things) so it will be quite adaptable. I'm eventually hoping to fit it inside my Coolermaster Cavalier.
    Hybr1d Thanks. The sketchup took 2 hours :X I find with the ASRock 939dual-sata2, if you do the vmod (the one above the cpu, connecting 2 points) then you get voltages up to 1.55v, with 1.025 being 1.50, and 1.050 being 1.55v. the "Memory frequency" is the ram divider; the DDR400 setting is the 1:1, the DDR 333 setting is 5:4, the DDR 266 is the 6:5, and the DDR 200 setting is 2:1. By default, the audio, usb, and LAN are disabled. Ram voltage only has 2 options (high, auto) and all that is in the "chipset" portion of the bios.
  20. Bbq.of.DooM
    12 Feb 2005
    This project has been put on hold for a short period of time, until I get this case done.
    While I finish working on the drawings, here's 2 basic renderings. [​IMG]
    It will have:
    -Clear
    -Wire management built-in
    -Black screws
    -4 hard drives
    -mid-tower
    -PSU cage (not in the renderings)
    -Built-in watercooling mounting
    -Preferably Aqua-computer stuff, if I can afford it :hip: :hip:
    I'll leave it at this right now, until I have the materials for the case and the drawings done.
