Project Blue Eagle
Discussion in 'Project Logs' started by Smilodon, 20 Jul 2003.
  1. Seal
    Seal What's a Dremel?
    2 Feb 2003
    very nice!
    how did you remove the atx connector though? did you use any special tools? Ive tried with a pin but find it impossible!
  2. [t0rc]
    [t0rc] What's a Dremel?
    28 Nov 2003
    Nice
    Pretty sweet looking!
  3. Fr0z3n
    Fr0z3n What's a Dremel?
    21 Oct 2003
    I have that mobo sitting in my closet as I type this. I actually ran linux on it for a little while. Good board though. :clap:
    Id like a PCB too. :clap:
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    bsodmike: i'll see what i can do... i have two versions... one is a 2 part PCB and the other is a 4 part... the 4 part is designed to fit perfectly in a box... and the 2 part thing is best to fit behind drive bays...
    seal: i used a thick needle wich i filed flat (dremel job) then put it down in the hole just between the tab and twisted it... that way the tab automaticly becomes pushed in... It's a bit tricky, but easy whan you figure out the tecnique...
    [t0rc]: thanks :) (you'r tag doesn't seem to work here.. ;) )
    Fr0z3n: Yeah, it's a nice board.. a bit old thhough.. but hey!, it works! :)
  5. MrTroy
    MrTroy What's a Dremel?
    15 Dec 2003
    bubble tubes
    those bubble tubes came with your case right? they arent your own mod?
    do the bubbles move?
    i was looking at doing my own tubes, or panel, very similar to the look of those, but with a pump basically that makes use of lighter and heavier liquids that are heterogeneous (wont combine)
    my first post on these forums, but with my plans for modding and getting a digi camera these holidays, shouldnt be my last
  6. MrTroy
    15 Dec 2003
    PCB
    Also, if someone is getting the PCB's made, i wouldnt mind one :p
  7. Smilodon
    25 Mar 2003
    MrTroy: First of all: welcome to the forums! :thumb:
    the bubbles doesn't move... it's solid acrylic rods with bubles. They came with the case.
    I might make some with moving bubles, but not yet.
    I don't quite get what you need a PCB for..
  8. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    He means your temp moniter on a PCB...
  9. Smilodon
    25 Mar 2003
    ahhh... Stupid me.. :duh:
  10. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    Good effort, i especially like what you did with the PSU cables! :D
    Will be watching this thread for further updates :lol:
  11. Smilodon
    25 Mar 2003
    Sorry about the lack of updates lately, but i have been busy, besides, i'm going to stuff in some new hardware as soon as i get it.. (damn christmas.. mail and webshops is sloooow!)
    more updates WILL come... sometime... ;)
  12. SnaRf
    SnaRf What's a Dremel?
    22 Nov 2002
    Smilodon, you don't accidentaly have an expressCSH file for the thermometer schematic... do you? :)
  13. Smilodon
    25 Mar 2003
    i have no idea what that is, but assuming it's a PCB/chematic program i would say no.. sorry... I use "proteus"... i have the files for that... :)
  14. SnaRf
    22 Nov 2002
    That'll work.
    I can't send you an email or a PM, so if you could please
    send me an email to snarf(AT)planetmars(DOT)co(DOT)za
    Thanx in advance
  15. skyrex
    skyrex What's a Dremel?
    22 Dec 2003
    dude, very nice job done and awesome attention to detail! i wish i was that creative... well i kinda am i just dont have the resources to put it all to work :(
    but all round, job done good. mod on!!
  16. kilobyte
    kilobyte What's a Dremel?
    21 Jan 2004
    loved the mod
    great job on the mod cant wait for mine to get done so i can post.
  17. Jang
    Jang What's a Dremel?
    3 Feb 2004
    just thought i would make a quick suggestion.
    Take your old case, get some of that alu, and get at it with a buffer and polish,
    then, once your done, nice mirror for the bottom of your case (Y)
    Sorry that was a bit breif, im in a rush :waah:
  18. Jang
    3 Feb 2004
    Bump.. anything yet?
  19. Smilodon
    25 Mar 2003
    sorry... this project is finished... i have got a new case now...
    this one is for sale if anyone want it (i might have a buyer already though :) )
    or mabye i should put my "linuxbox" (currently running XP(yeah, i know)) in it?
  20. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    Nice window!!
    But a variable speed jigsaw could do that much quicker and easier.. I do use a dremmel where its better - and when cutting a window I stick some thin 6-8mm board to back of case, also important is quality blades ideally not wide so you can change direction easily.
    But as someone said Laser is best - but not manage to get one yet :)
