Case Mod - In Progress Project: Blue Flames - Case Finish
Discussion in 'Project Logs' started by Nolimited, 24 May 2008.
  1. b1g-d0g
    b1g-d0g Well-Known Member
    30 Sep 2001
    Any updates matey?
  2. Nolimited
    Nolimited New Member
    12 May 2008
    Back for modding
    Good news all my part are present
    My memory Corsair 4 GB nice :D
    [​IMG][​IMG]
    Also the power supply Corsair 1000W modular i love it :thumb:
    The box
    Open
    The power supply box open
    The cables all black and nice :D
    Out of the box
    The modular options
    I test all part in the case to see what i need to do to finish the case. Cable management and some finishing.
    [​IMG][​IMG]
    Cutting the bottom where the power supply fan are placed.
    Also cut a hole on the motherboard tray to have access to the power cable "EPS12V"
    Before
    After
    with the power supply
    Finish for today next will come soon :thumb:
    happy modding
  3. Regidet
    Regidet Awesomenesstrocity
    8 May 2008
    not too bad. keep it up. nice selectrions with the hardware. :thumb:
  4. ComputerKing
    8 Sep 2006
    Nice sexy expensive hardware :p
  5. MrWizard
    MrWizard New Member
    5 Feb 2008
    Niiiiice. :rock:
  6. Nolimited
    12 May 2008
    Thanks i will do
    thanks not so expensive when find the good store :thumb:
    thanks MrWizard
  7. Nolimited
    12 May 2008
    I have search other hardware this weekend. :lol:
    A new fan for the Thermalright Extreme the other was not compatible.
    A mini CCFL kit (blue)
    AC MX-2 Thermal compound nice :thumb:
    And last the Zalman ZM-MFC1 Plus fan controler in Black :D
    other picture
    [​IMG][​IMG]
    The rear.
    I make a plate for cable management
    Cutting the plate and make the hole to placed on the motherboard tray.
    [​IMG][​IMG]
    Bussy to cutting for the cables :lol:
    Test with the cables :eek:
    the finish and mounted with the hardware :D
    an other view
    that's all for today until next update.
  8. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Looking nice, CCFLs are going to look S.W.E.E.T in this:)
  9. Nolimited
    12 May 2008
    Little update.
    Make some change to the case for cable management.
    on the left side 3 hole for the power cable, sata and ide cables.
    Before
    After
    Also make the hole on the motherboard tray bigger
    on the rear side of the motherboard tray i cut also a piece for the cables.
    That's all for the cable management
    I test today the zalman
    this week i will make some finishing touch on the rear fan grill.
    Happy modding
  10. Nolimited
    12 May 2008
    Hello get back for a Little update :D
    I need to finish all before 10/08 because the case will go in painting (Airbrush) during my holiday :baby:
    I make an piece for the hd led with 4 plexi and glue it in one part.
    After that a make the necessary to have it compatible with the front of the case.
    make a template and cut the unnecessary of this piece
    After 3 hours work on this piece with sand paper first 400 second 800 and last 1200 her the final piece
    I hope you like it its my first time
    Other view
    And the view in the case
    other view
    i have install all the hardware to test that all work and also make a video
    My first video
    I now not great change but all idea are welcome.
    The external will be all painting with airbrush
    Happy modding
  11. Nolimited
    12 May 2008
    Hallo little update before the case are going to painting :D
    I have finish to test the lights on the plexi that i have make to display the hd activity
    mounted the cables on the plexi.
    Placed in the case
    Some lights test
    I have also remove all the hardware and prepare all for the painting tomorrow.
    I need to bring the case to Didier specialist in Airbrush in Belgium you can see he's work on the blog :thumb: http://sunflower05.skyrock.com/176.html
    Sorry i now the site are in french but the pictures say all :D
    This also the first time that didier will painting a computer :D
    This week i will finish some cables for the power button and the other because next week i will be in vacation for 2 weeks.
    Happy modding and keep it up all :clap:
  12. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Nice job so far, just a suggestion. Get some of that rubber u channel stuff. I would put it around the hole you cut for the pc bracket, so it doesn't scratch that big nice fancy power supply of yours, just something i would personally do. You can find the stuff in the US from mnpctech's online store.
  13. Nolimited
    12 May 2008
    Thanks Mansueto :thumb: Nice idea i will look when the case is back.
    I have bring today the case for painting (airbrush) :clap: wait and see how the case will look :lol:
  14. Nolimited
    12 May 2008
    Hi All no update because just back from vacation.:p
    Also no good news :waah: the case is not finish painting i hope that it will be quick finish
    Until then Keep it up :thumb:
  15. n0cturnull
    n0cturnull Desperate to MOD!! =P
    30 Aug 2008
    nice fresh ideas, can't wait to see it all done :thumb:
    keep it coming!! :clap:
    _______________________
    (off topic) where do you usually get your plex dude? i am also from belgium (bruges) and brico doesn't give a good plexi?
    sorry for off topic
  16. Nolimited
    12 May 2008
    Thanks n0cturnull
    (off topic) the crystal plexi where buy in Brico and the other by Hubo i have find all in brussel.
    Nolimited
  17. n0cturnull
    30 Aug 2008
    any updates dude?
    i am really becoming excited on this :thumb: :thumb:
    ___________________
    (off topic again)thanks for replying to my question, practically i live in Bruges and i dun have a car yet and that explains that i can't transport all large goodies using only buses and trains. :waah: thanks for the tips. i might visiting the Hubo nearby if i have a day-off. :)
  18. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Nice Mod so far! I like what you've done. and your pics and explanations. I really like the look of the white plexi interior and the cable hiding, and the dvd drive stealthing. Can you explain more or show more pics of how you attached the mesh front to the dvd front?
    Also, have you thought about making the flame grill (now in metal, stick out in front of a different colored layer of plexi, perhaps lit light the case top and other parts? It's hard to make out for me in the night pics.
  19. Nolimited
    12 May 2008
    Thanks modminded for you comment i appreciate.
    for the DVDRom i have use some parts of the case and make some holes and fixed with screws
    Front view
    Inside on the bottom
    Side View
    All are cover by the grills from the front.
    The eject button are no more visible and i need to eject the DVD from windows.
    For the fan grills the choice of metal was use because it will be painting.
    No other pictures for the moment because the painting is not finish.
    happy modding :thumb:
  20. Nolimited
    12 May 2008
    Hello modders mini Painting update
    The painting take more time but final touch are done now. :D
    The metal fan grill is paint and ready :thumb:
    Before Painting
    [​IMG][​IMG]
    After painting
    The top and one side panel start at 50%
    The top before paint
    The side panel
    that's all for today more picture will come soon.
    I hope you enjoy and all comment welcome
    Happy modding
