Case Mod - In Progress Project: Blue Flames - Case Finish
Discussion in 'Project Logs' started by Nolimited, 24 May 2008.
  1. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    Thanks i find also
    Thanks dan-ere-07
    Not so bad
    Mini update take a picture from the rear where in test the paint fan grill with the fan.
    Closer
    i have also take a video from the new hard disk activity leds
    Tomorrow i will paint the inside off the case in Aluminium Metallic
    Thanks for reading :D
  2. The boy 4rm oz
    10 Apr 2008
    Nice work on the grill.
  3. Nolimited
    12 May 2008
    Thanks The boy 4rm oz
    I finish paint the inside part like the motherboard tray in Aluminium Metallic
    Before
    After
    That's all for today in 24h the paint is ready then i can begin to install the part and the light.
    Keep it up modding to all. :thumb:
  4. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    This is all freakin right with me!.. ground metal paint, von dutch eyeball and flames. my style of moddin :rock: Have you seen my new shop table? :naughty:
  5. The boy 4rm oz
    10 Apr 2008
    Simple,shiny silver. Goes perfectly with the exterior design.
  6. mnpctech
    21 Apr 2003
  7. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Nice work! 'Grats on the blog appearance too!
  8. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    Nice work NoLimited!! and congrats on the blog entry
  9. Nolimited
    12 May 2008
    Thanks The boy 4rm oz i find also
    Thanks Bill i really appreciate and happy to be appear on the Case mod blog :D
    I have also see the new shop table really nice and good choice of the red color :thumb:
    Thanks E.E.L. Ambiense for you the same :thumb:
    Thanks Kylevdm ;)
  10. mnpctech
    21 Apr 2003
    You're welcome dude! Keep up the good work :thumb:
  11. The boy 4rm oz
    10 Apr 2008
    Oops I missed that lol.
    Congratz mate, you really deserve it.
  12. Nolimited
    12 May 2008
    Thanks The boy 4rm oz no problem :thumb:
  13. Nolimited
    12 May 2008
    Little update today :D
    Final picture from the motherboard tray that i have finish painting.
    I mounted the motherboard tray and install the rear fan
    Picture from inside
    Other view
    I have also test the Billet Fan Grill Link from Mnpctech
    [​IMG] [​IMG]
    That's all for today :thumb:
  14. mnpctech
    21 Apr 2003
    very cool top panel Nolimited! It makes me wanna go grind some steel with swirls :hip:
  15. Cheapskate
    13 May 2007
    I come back and it's even better.:D The pinstriping really works. I envy your skill. My hands shake too much to do this stuff.
  16. Nolimited
    12 May 2008
    Thanks Cheapskate
    Back for update i have find some new parts for the case :D
    A new usb multi-Function card reader with E-sata
    next part I now not direct for use in the case but easy when you need to have data from other harddisk without to open your case :thumb:
    Usb 2.0 to Sata/IDE Cable with power
    I have also find back my old CM musketeer
    I open it to mod the background of every controller here the inside view
    The switch remove
    I remove the card and also the cover from one of the controllers
    An other view ;)
    Next time I will try to find out what background I will use 'Flames or the blue from the case' i will make some print layout and test it
    I will also paint the DVD and the card reader case in black
    Thanks for reading and all comment welcome :thumb:
  17. mnpctech
    21 Apr 2003
    I like your idea Nolimited, it's all in the small details! :cooldude:
  18. The boy 4rm oz
    10 Apr 2008
    It's always good to recycle ;).
  19. Nolimited
    12 May 2008
    Yes but sometime it is difficult to find what change to fit perfect on the case :wallbash:
    But i will find out ;)
    Update Time ;)
    Prepare the DVDrom the hard disk cage and the card reader for painting in matte black
    [​IMG][​IMG]
    Remove the covers off the card reader and prepare them
    also prepare the hard disk cage for painting
    [​IMG][​IMG]
    I forget some part :duh: the fixing of the card reader and Hard disk cage fixing
    [​IMG][​IMG]
    And now the same part after painting and dry of 24h :D
    The DVD
    The card reader before rebuild
    And now build
    The other part
    [​IMG][​IMG]
    [​IMG][​IMG]
    The hard disk cage ready to receive the Disks :D
  20. The boy 4rm oz
    10 Apr 2008
    Nice and black, good work.
