Case Mod - In Progress Project: Blue Flames - Case Finish
Discussion in 'Project Logs' started by Nolimited, 24 May 2008.
  1. The boy 4rm oz
    10 Apr 2008
    Those sleeving kits are good, the AC Ryan sleeve is very good quality I have found. Does it come with the pin removal tools?
  2. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    @ The boy 4rm oz nice kit and all come with 2 pin removal tools :D
    The kit is arrived :clap: Tuesday i will thanks my friend Stany :thumb: to pickup this kit for me.
    No update just simple picture from the new kit from A.C.Ryan the morf psu modding kit in black.
    The packaging :D
    The whole kit open :thumb:
    I will start this week-end by change my molex and add the flexsleeve.
    Happy modding
  3. The boy 4rm oz
    10 Apr 2008
    You really do get a lot with those kits.
  4. Nolimited
    12 May 2008
    @ The boy 4rm oz thanks il will do my best ;)
    I start this week-end to change most of my cables. :D
    Start with the cables of the card reader i need to separate them before start sleeving.
    after
    I did the same with the other cables
    Remove molex
    add black sleeving and add molex
    The 2 finish
    The molex
    Start to remove the sleeving from the 120mm case fan.
    Before
    After
    That's all for today i need to order some molex and fan connector because all need to be in black :D
    Happy modding
  5. Inf3ction
    Inf3ction What's a Dremel?
    10 Dec 2008
    Good job with that sleeving, I don't think I've ever had the paitence to sleeve in the entire time I've been modding. Keep up the good work. :D
  6. Nolimited
    12 May 2008
    Thanks Inf3ction the first did me crazy :lol: but after that it was no more a problem
  7. The boy 4rm oz
    10 Apr 2008
    Yeah I find sleeving as a chore but you do get good results. Nice work.
  8. Nolimited
    12 May 2008
    Happy new year to all :clap:
    I apologize me for the slow update but after a heart infection I stayed in bed for couple of day's but now all okay
    But lets start this new year with a new Mini update :thumb:
    I have order new parts for the mod.
    Female and male molex to finish the cables all black of cours :D
    also new sata cable from Ac-ryan
    Next a new ide cable for the DVD and the data hard disk
    I have order on the same time Blue UV painting but do not now if i will use this
    I have install the last molex
    [​IMG][​IMG]
    The 6 last pictures are take with my new EOS 450D camera i love it.
    Next time i will install the motherboard and connect all cables :thumb:
    Thank and happy modding :thumb:
  9. Loom
    Loom What's a Dremel?
    10 Aug 2008
    Happy new year to you too and hope your health is fine.
  10. The boy 4rm oz
    10 Apr 2008
    +1 to that.
  11. Nolimited
    12 May 2008
    Thanks Loom its not 100% good but its on the good way :thumb:
    Thanks The boy 4rm oz ;)
  12. Nolimited
    12 May 2008
    Installed Motherboard
    Back to update :thumb:
    I have start to installed the motherboard in the case.
    Just a little reminder from the hardware that i use.
    The motherboard is an asus Maximus Extreme with the CPU Intel Q9450
    The CPU cooler is an Thermalright Extreme 120
    The fan on this cooler will be an sharkoon Silent eagle 2000
    I use the MX-2 thermal compound for the CPU
    But let my start to mounted the CPU fan on the motherboard
    First add thermal compound to the CPU
    Install the great Cooler :D
    The rear view of the motherboard with the cooler plate in black :D
    An global view
    Before i installed the motherboard in the case i need to install the back plate from the motherboard
    View from the rear view
    and now all installed in the case
    other view
    the motherboard is install and now i can start the installations but that's for the next update :D
    thanks Nolimited :thumb:
  13. CobraMods
    CobraMods Gettin there slowly
    28 Mar 2008
    Lookin sweet so far, wires look much better sleeved =o)
  14. Nolimited
    12 May 2008
    Update
    @ CobraMods thanks i find also :thumb:
    Update Time :D
    I start with the installation of the memory on the motherboard
    2 x 2GB DDR XMS3 that will be nice :lol:
    Install done. I don't find them in black :waah:
    I will also install this sound card on the motherboard
    Next the video card i now it is and EN9800GTX but not so bad when i read the reviews and i buy this when i start this mod :)
    View from all install sound and video
    Another view
    View from an other angle
    Next start connect the power, reset and the hd led on the motherboard.
    This is the view with the cable not connect just insert to see how it like.
    Zoom on the connectors (jacks)
    I start the sleeving of the power, reset and HDled cables not easy they are very short ;)
    I forgot to take a picture from the cable finish but in the next view you will see the cables when i take a test to see that all works. :thumb:
    i test to see that all works and yes first the start button i like it :lol:
    The HDled work also youpy :D
    And the 2 on the same time i love the blue color :D
    and in the dark
    I will start this week-end the lights in case and see to set all the cables like i want.
    Sheers and until next update Nolimited
  15. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Thanks for the update, esp on the cable jacks! Those are too cool Nolimited.
  16. Spyrious
    Spyrious Modding all the Time
    8 Dec 2008
    Very good.I like the cover for the drive cage.
    Only one suggestion.You should turn the exhaust fan (clear) so that it pushes air to the outside of the case.I think you could get lower temps that way.
  17. Loom
    10 Aug 2008
    What he said.
  18. The boy 4rm oz
    10 Apr 2008
    I agree with Spyrious, turn the rear fan around and make it an exhaust. That way all the hot air coming off the TRUE will be expelled.
    Looks fantastic though mate, Excellent work of the jacks for the front header cables.
  19. Nolimited
    12 May 2008
    @mnpctech thanks i appreciate :D
    @Spyrious thanks for the tip i change them :thumb: (new pic )
    @Loom thanks Mate
    @The boy 4rm oz Thanks tips are every time welcome and appreciate :thumb:
  20. Nolimited
    12 May 2008
    Update Cables
    Back for update.
    I take a picture from the jacks because forgot the last time ;) i also start new sleeve cables :D
    I start to sleeve the audio cable and the cables of the mini CCFL kit
    Audio cable before
    Audio cable after
    CCFL cable before
    CCFL cable after
    Once the cables off the CCFL kit are finish i install the cables and the button for the lights
    Two buttons one for the inside an the other for the top and bottom lights.
    Complete view off the rear of the case
    some picture from the inside with the cables install
    I make some light test i love it :D :thumb:
    [​IMG] [​IMG]
    :D 80% are finish now i need to install all and make some test to see that all works :D
    Also make some final touch ;)
    Happy modding to all :thumb:
