Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    nice one :) I'm curious about the final position use and look at it's position of the angle block. :thumb:
  2. RonanH
    RonanH mod-envious
    30 Mar 2010
    Sweet effect :thumb: I hope you're not relying on superglue for a seal on your leds though...
  3. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    More pics are coming tomorrow, you wont have to wait long :D
    No, I've used a combination of things. The LED's only just fit in the holes, and ive used silicone sealant in the holes, and superglue over the top of the led. I may also add a layer of filler over the top of all that too.
  4. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    :eeek:"WTF" alert!:jawdrop: THAT's cRAAAzzzy! :clap: I love it.:thumb: You better put the trademark on it! When do you start taking orders.:rock:
  5. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Damn you beat me to it. I've had that idea for years, just didn't build it yet :(
  6. wejjy
    wejjy Minimodder
    9 Aug 2010
    That is soooooo original, Love it mate, this is my favourite project on the site, so many amazing ideas!!!
  7. riekmaharg2
    22 Feb 2009
    Thanks LooseNeutral :thumb:, has their ever been a modder who sells parts they have used in their mod?
    I know the feeling it happened to me when I was designing this case.
    Thanks wejjy :D
    Today I started off by glueing the blocks together and priming them for painting. I'm only painting the back half though:
    Here it is after painting:
    Its quite cool this paint, its plain silver as usual but then at an angle it gains a sort of mirror effect:
    I've left it for 24hr now to try properly before I polish the front half.
    In the mean time I've done some more wiring:
    Its abit messy but it wont be visible. Heres the other side of the MB tray:
    The wires won't actually go through that hole on the right, its just there for now to keep it in place.
  8. RonanH
    RonanH mod-envious
    30 Mar 2010
    :jawdrop:
    this just keeps getting better :thumb:
  9. dream caster
    dream caster just lurking from out there
    1 Jan 2002
    Just gave a fast reading to your thread.
    I like your design very much and you really get it done.
    Two questions:
    Where are you doing it?
    How do you plan to build and shape those curved corners outside in front and top?
  10. riekmaharg2
    22 Feb 2009
    Thanks RonanH :thumb:
    Cheers dream caster :D
    1.Im doing it at my fathers workshop, which he uses to produce products.
    2. They will be sandcasted
  11. bulldogjeff
    2 Mar 2010
    That block is amazing Kier, that looks the absolute muts when it's lite up...well done, it's all starting to shape up nicely:thumb:
  12. riekmaharg2
    22 Feb 2009
    Thanks bulldogjeff :D
    Heres the completed angle block after some polishing and another layer of paint. There is a little notch in the top of the polished part, which happened while I was polishing but the roof of the case sits on that bit anyway so it wont be visble:
    I also got round to doing one of the sides on the bottom of the case:
    First I cut out a peice of 10mm aluminium angle using the bandsaw:
    I then used a stainless steel brush to roughen the sides:
    I then glued one side of the angle to the side peice I made earlier using araldite:
    I then repeated the processes to glue the side onto the case floor:
    All thats left now is to prime and paint it.
  13. tkgclimb
    tkgclimb man it's all harder than it looks
    18 Jan 2010
    looks sweet, man you're putting a lot of work into it, I know it will come out awesome
  14. LooseNeutral
    13 May 2010
  15. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Nice work. keep it coming.
  16. HoryBP
    HoryBP What's a Dremel?
    12 Aug 2010
    It is just beautiful
  17. riekmaharg2
    22 Feb 2009
    Thanks everyone :D, stay tuned tomorrow for the next update.
  18. sc0ontz
    sc0ontz I'm a modder... I guess... :D
    30 Aug 2009
    this is really what you call build from scratch! even the barbs are built from scratch!
    great job!
  19. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    You are messing with my curiosity buddy! Moooooar pls! :)
  20. Combatus
    16 Feb 2009
    Cooooooool!:thumb:
