Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Thanks :D, heres the next update for you:
    I'm going to hold off on fitting the angle block for now just until ive finished the sanding and paint. So for now I'm finishing the sides. I made the second side in exactly the same way as the first:
    Once I had glued it to the case just like the previous I then used filler to fill the gap between floor and sides:
    I then sanded the filler down:
    I also got time to put filler on the PCI backpanel:
    Sorry about the small update, the setting time of the glue and filler used up most of my time.
  2. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Really nice progress mat, sorry if you mentioned it already but are you going to paint the case or powder coat it?
  3. riekmaharg2
    22 Feb 2009
    Thanks AnG3l, the MB tray, top and front will be left brushed, but the PCI back panel, and the bottom side parts which I've just made will be spray painted matt silver, and the mesh I'm going to use for the top and front will be spray painted satin black.
  4. AnG3L
    19 Mar 2009
    You will need a lot of preparation though and a good primer! Mod on buddy, I ll be watching! :)
  5. riekmaharg2
    22 Feb 2009
    Yep :D, I've got a self etching aluminium primer for it.
  6. bulldogjeff
    2 Mar 2010
    Have a look in halfords or any good car shop and get some filler primer, it'll take all the scratches and marks out, then just rub down flat and prime as normal, you'll save you're self a lot of hard work.
  7. riekmaharg2
    22 Feb 2009
    Will do if I have any small scratches, thanks :thumb:
    Today I glued in the bottom plate of the PCI backpanel and put filler in the gap:
    I then sanded down the parts I had put filler on yesterday:
    Sorry if my log is a bit boring at the moment, it should get more entertaining soon, as after the priming it will be time for the sandcasting.
  8. riekmaharg2
    22 Feb 2009
    Heres the case after the spray primer:
    Can anyone spot the mouse :D:
    Theres still a couple of imperfections:
  9. DeadP1xels
    30 Nov 2009
    crazy clean work mate
    Im loving it :)
  10. Razarach
    Razarach Minimodder
    28 Jan 2009
    nice work :)
  11. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    nice work.
    I think resanding the not perfect spots and use primer again will help with them. Maybe go down at the end to some finer grid?
    All in all a very nice build! :thumb:
  12. RonanH
    RonanH mod-envious
    30 Mar 2010
    Think this is the best bet... though I'm not sure if you can apply it over primer... worth a shot.
    Starting to look like a real nice case though, can't wait for the sand casting :eek: no idea what you're going to make like that but dying to see :D
  13. riekmaharg2
    22 Feb 2009
    Thanks everyone :D, yeah the primer with some fine grade wet & dry seems to have done the job (see below). I've just got to find a material to make the mould for shaping the sand, I may use the REP foam that I used to mould my last mod although I'm not sure whether it could withstand having the sand compressed onto it, so I may have to use a large block of wood.
    Heres the next update:
    After lots more filling:
    I forgot to mention I'm using a two part car filler for all this.
    Heres the pics after I've sanded off the excess filler and given it another coat of primer:
    And here it is after its first coat of silver paint:
    Its abit spotty at the moment but the next two coats will fix that, I'm just waiting for it to dry for 24hr now so I can sand this layer with some 1000 wet and dry to smooth it all, ready for the final layers. More pics of this and the other side will be coming tomorrow, I had to rush out and didn't have time to take more pics today.
  14. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Oh yeah man! Looks real nice....MORE and then some more Please!:D
  15. riekmaharg2
    22 Feb 2009
    Thanks LooseNeutral heres the next pics of the finished paint:
    I also used a work lamp to warm up the aluminium to set the paint faster:
    Tomorrow after its all dry I'll very very carefully remove the masking tape.
  16. Razarach
    Razarach Minimodder
    28 Jan 2009
    nice work with paint ;)
  17. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    Shiny is shiny
  18. riekmaharg2
    22 Feb 2009
    Thanks Razarach :thumb:
    Yep :D
  19. LooseNeutral
    13 May 2010
    Pretty girl there! :)
  20. Attila
    Attila still thinking....
    22 Feb 2008
    Pretty amazing to see such a construction devoid of rivets and screws. :thumb:
    Are you thinking of applying a few coats of clear to the case? I know from
    experience that the silver I've used in the past, catches a finger print and won't
    give it up. Plus the added depth of the finish with five or six coats of clear is
    terrific.
