Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Thanks everyone :) hopefully I'll get chance on thursday to do the roughing pass for the underneath, I've just been crazy busy the past couple of weeks.
  2. riekmaharg2
    22 Feb 2009
    I actually managed to get some work done today, heres the whole roughing pass on the underside:
    Theres a knot in the wood but some filler will fix that:
    There's also a release angle on the ends so it will come out the sand during the mould making:
    Im on christmas holiday next week so there will be alot more updates coming soon.
  3. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    I'll be wait'n for a little Christmas cheer here with this :D
  4. Sanatarium
    Sanatarium The Artist Formerly ATi_Loyalist
    22 Feb 2005
    Nice work! Really impressed by your CNC :D
  5. riekmaharg2
    22 Feb 2009
    Thanks guys :thumb:
    Heres the underside of the front panel during CNC:
    And with the CNC finished:
    All thats left now is to chop/sand off those square supports on the sides, then take it to the sand casters.
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Awesome news :clap:, got there in the end then :rock::thumb:
  7. riekmaharg2
    22 Feb 2009
    Yep :D, I finaly get back to doing more hands on work, rather than watching a machine do it for me :)
  8. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Nice work with CNC realy a great job!!!
    Congratulations!!!
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    :hehe::lol: Can't wait to see the aluminium piece :rock::thumb:.
  10. RonanH
    RonanH mod-envious
    30 Mar 2010
    sweet! Grats on battling through to get the mould finished :dremel:
    Now, bring your video camera to the sand casters so we can see molten hot alu being poured :)
  11. riekmaharg2
    22 Feb 2009
    Thanks Marcos :thumb:
    Yeah me too :)
    I'll see what I can do, hopefully they will let me, they know my dad so I might get him to try and persuade them.
  12. LooseNeutral
    13 May 2010
    They'd be crazy to let a free advertising spot get away. Maybe you can get a little discount deal too :D
  13. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    Unfortunately its not always that simple haha. Many companies have disclosure agreements that have to abide by, though I do think that an operation like this probably wont have a problem with it. The company I work for has a foundry but its all cast iron and we do massive, massive quantities of sand castings (like 300ish casts an hour) so I hope they do say yes. I'd be thrilled to see the differences in casting processes!
    So far you've kept the mod right on par with your Silent Fiberglass mate. Really have loved your work all around
  14. riekmaharg2
    22 Feb 2009
    Yeah, hopefully it will be easy so long as theres no disclosure agreements like sixfootsideburns said or any health and safety rules which could prevent me from filming, however its only a small local casting company so I dont think it will be a problem. I will have to wait for the right day though as they build up a large quantitys of moulds then cast them all in a row.
    Thanks sixfootsideburns :thumb:
    Heres the front panel with the support blocks sanded off, and the drill holes filled in:
  15. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Awesome work buddy!!! :)
  16. riekmaharg2
    22 Feb 2009
    Thanks Alex, I also forgot to say that those rough ends will be cut off the finished casting.
  17. Xye
    Xye What's a Dremel?
    21 Nov 2010
    Nice work. I presume you will be varnishing or waxing the wood otherwise you would have just used MDF?
    BTW have you tried Mach3 to manage your CNC? I'm looking into starting a small side business and it seems to come with most commercially available CNC machines.
  18. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    Sorry if I missed it...but what CAM program are you using? It seems like the path isn't ideal for that surface. What I mean is that instead of zig-zag, I think you should be doing a constant overlap surface (anyone familiar with MasterCAM will know what I mean). This will follow the surface instead of zig-zag, so in your case, it will go around in a rectangular shape, leaving the steeper edges smoother with no scallops.
    Hope this helps!
  19. riekmaharg2
    22 Feb 2009
    Yep Mach3 is the one I use, it works great, cheap too, and the manual is epic, lol.
    I'm using sketchup to create the 3D models, and Cut3D to create the toolpaths. Those rough edges are just there to create the sand casting mould and will be chopped off later to leave both ends open. Is the toolpath your on about the one where is works diagonally from corner to corner instead of horizontally from front to back?
    The sandcasting company manager was off site today so I'll phone again tomorrow to find out whether I can film the casting.
  20. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    This is what I was talking about.
    Instead of the zig-zag. May save time if you have to do this ever again!
