Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    A shall call you Mister reik! That's pure passion at work! Blood, guts and doo-dads.
  2. Dragonphreak
    Dragonphreak Minimodder
    26 Oct 2005
    wow, how much does that thing weigh?
  3. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    I wish you more patience and strength for you to bring more awesomeness brother!!! :) Mod on!!
  4. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Thanks everyone :thumb:, seeing it all shiny makes me want to create a mirror finish on these parts, I was originally just gonna have the brushed aluminium look but I might see if I can a mirror finish to match with the rest of the case.
    Its not bad only around 2 to 2.5KG, its definately worth the extra weight :D
    The next update will have to be monday now as my college assignments are due in next week so I'm having to finish thoughs off instead of doing this.
  5. LooseNeutral
    13 May 2010
    See, all that work you've put in to this... it does mean something to the gallery. Just went through the whole log again as a reminder of how you and dare I say, we, all watching, got here. learned a lot through conversations with you and yours with others. :D don't get much better. Crazy, If it wasn't for this I wouldn't have known to ask AnG3L whats up. wow. and :D it's all good..it does go around
  6. Fedmas
    Fedmas Leader of the casemod watchers :D
    29 Jan 2010
    What is your place? I want to steal everything :( Gorgeous!
  7. riekmaharg2
    22 Feb 2009
    Thanks LooseNeutral :thumb:, I think i might neaten my Log up abit once it's finished to make it easier to understand which parts go where.
    Hehe, thanks Fedmas :D
    The next update will be soon, I'm just waiting for a new palm sander.
  8. riekmaharg2
    22 Feb 2009
    The sander didn't arrive today so I grinded down the front panel with the flap disc, to remove all the little holes:
    For some reason the grinder is pretty much useless at smoothing out the flap bit on top so I'll have to use the sander for that.
  9. Fedmas
    29 Jan 2010
    Nice shots!
  10. riekmaharg2
    22 Feb 2009
    Thanks Fedmas :thumb:, I'm a bit of a newbie to photography but I'm slowly learning. I'm also saving for a macro lens.
  11. bulldogjeff
    2 Mar 2010
    Thats a very posh looking lump of metal you've got there Kier. Good to see your up and running after all the agro you had before.
  12. riekmaharg2
    22 Feb 2009
    Yeah I cant beleive how long it took to get the moulds finished, but it was definately worth it :)
  13. MrNitro
    MrNitro Performance Enthusiast =)
    26 Jun 2010
    Alu pr0n!
    Sweet!
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    You got that chunk of alu looking much smoother mate :thumb: gonna look great when they meet each other & fixed to the case.
  15. riekmaharg2
    22 Feb 2009
    lol :D
    Thanks Waynio, yeah I cant wait to get it fixed on. Once I've sanded it all I'm gonna mod the bandsaw I use to make it vertical so I can chop the parts in half length ways.
  16. RonanH
    RonanH mod-envious
    30 Mar 2010
    Modding to mod, extreme modtastic!
  17. AnG3L
    19 Mar 2009
    Nice work mate hopefully you wont need to close the holes with isopon, I hope the modded bandsaw will do its job!! Good luck!! :)
  18. riekmaharg2
    22 Feb 2009
    LOL :D
    I hope so too :), I will have to find someone with a verticle bandsaw otherwise.
    Heres the top panel after some sanding with the palm sander:
    Its already silky smooth even without using any Wet & dry :)
    Xye likes this.
  19. Xye
    Xye What's a Dremel?
    21 Nov 2010
    Looks Excellent. Are you going to paint it? Personally I would have left it as bare metal as it looks so nice. Though I guess fingerprints would be a problem then.
  20. LooseNeutral
    13 May 2010
    Really looking nice! Can't wait to see the fitting, should look awesome even in the rough, when you get there :)
