Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. Ice Maiden
    Ice Maiden New Member
    15 Apr 2011
    Wow! now that is looking good! How much is all this costing?
  2. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
    Yeah lol, I'll have to make a booklet to go with it :D, Thanks p0Pe :thumb:
    Thanks Ice Maiden, around £700! for everything so far, even though about £150 of that was stuff I bought for failed ideas.
  3. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    What he said!
    Now will you excuse me, I need to find a glue to put back my jaw...
  4. riekmaharg2
    22 Feb 2009
    Thanks AnG3L :thumb:
    The milling machine I use has just broke so its gonna be abit longer till I can carry on with front door panels :(
    The gear has come off the motors shaft and I can't find the fixing which keeps it in place.
  5. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Dear God, I've seen modders modify fans in many ways, but you're almost constructing one from scratch. Amazing work!
  6. Dragonite
    Dragonite Member
    15 Feb 2011
    My thought exactly :p
  7. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Awsome work, modding a fan motor is dedication.:thumb:
  8. riekmaharg2
    22 Feb 2009
    Thanks everyone :thumb:
    Heres the new design for the blower fan:
    I've put a little window here so you can just see the fan:
    The little gap on the right is so the light from the side of heatsink can be seen:
    The milling machine is also fixed now :) as the fixing for the gear was found.
  9. Nutman
    21 Oct 2008
    There are some really, really beautiful curves in this build. Keep it up!
  10. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Damn impressive work!
  11. RonanH
    RonanH mod-envious
    30 Mar 2010
    Impressive! As always :) Why didn't you use the motor that came with the blower though, or am I missing something obvious as usual...?
  12. morbid_looney
    morbid_looney New Member
    27 Apr 2010
    Thats a awesome design for the cross-flow fan. i like the way its still partially visible.
    makes your unique WC system even more unique, because i cant name any mod right now that has one on a heat sink.
    awesome!!!
  13. password
    password New Member
    28 Dec 2010
    that is nice and impressive :thumb:
  14. bulldogjeff
    2 Mar 2010
    Failed ideas it what drives us on and in the end provides a better end product. It can prove to be an expensive way to do things though.
    I've just started a new build and changed direction slightly with it already, ok no expensive cock ups but just new ideas popping into my head.
    If it all went smoothly where would the fun be in that. That said Heat blast went together exactly as planned, but I look at that as a one off..lol
    Mod on Keir you're doing an amazing job mate. I can't wait to see it all finished.
  15. riekmaharg2
    22 Feb 2009
    Thanks Nutman & GravitySmacked :thumb:
    Thanks RonanH :), for some reason even though it was the same type of brushless motor it was really noisy, so I decided to make my own :)
    Thanks morbid_looney & password :thumb:
    Thanks bulldogjeff :thumb:, yeah I like the try it and see what happens approach, it builds up your knowledge of how not to make something :)
    Heres the next update for the fan as the milling machine is still occupied:
    I started by drilling a hole through the center of a aluminum round bar, then widening it bit by bit:
    A mark was then cut into the bar to mark the end:
    I then drilled a hole into the center of the round bar with a center drill:
    I then started trimming down the outside:
    I then cut the end piece off:
    I then drilled a hole through:
    Heres it is after some sanding:
    And with the magnetic hammered in:
    Heres where it fits:
    The hole goes all the way through for the 3mm stainless steel shaft to go through, however the hole in the magnet piece I've just made is slightly smaller than 3mm so as it turns it will turn the shaft:
  16. bulldogjeff
    2 Mar 2010
    Nice work. Is there any thing your not going to make for this case?
    I bet you're even going to make your own air to cool it...lol
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    Simply awesome :clap::jawdrop::thumb:.
    Me wants a lathe which is affordable, just wish mills were the same price range :D.
  18. morbid_looney
    27 Apr 2010
    :thumb:LOL:thumb:
  19. riekmaharg2
    22 Feb 2009
    Yeah lol :D
    Thanks Waynio, yeah cheapest mills I've seem are about £1000
  20. TotalGaos
    TotalGaos Stainless steel.. hmm..
    16 Dec 2007
    Awesome work, I'm going to follow this.
    One idea though, why not putting the fan on top? I think it would be kinda cool to see the thing spinning, and maybe it looks better than looking directly into the heatsink..
