Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. Cheapskate
    13 May 2007
    ^What they said, with a few extra Woooooodleywhoooooohas.
  2. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Thanks IcyAero, I use 240 grit wet & dry to get out the deep scratches then I use 320 grit Wet & Dry in opposite directions to remove the scratches from the 240 grit, then I finally use the 320 to carefully create the brushed effect. The hard part is getting every swipe perfectly straight, otherwise it looks messy. I alway use water with the Wet & dry to prolong the life of the sandpaper, and to contain the dust.
    Lol :D, thanks for the awesome feedback everyone :thumb:
    Today I've sanded all the JB weld off the acrylic strips and the excess off the alu casting:
    Its also slightly polished just like the top panel one was before painting:
    I also glued some heatshrink onto the panel hinge to give the wire some extra strength for when door is opened and closed:
  3. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    love the design and the finish on them panels... Cant wait to see more.
  4. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    :jawdrop: Unbelievably beautiful. Stunning work of art. Hexagons are definitely the new black (as I think was said on the phinix tower thread some time ago!).
  5. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I think the reason why I didn't really reply in here, was that it's difficult for me to find words for it!
    It's just amazing! The design is beautifull, and the craftmanship is flawless! Cudos to you sir! :thumb:
  6. Shayper09
    Shayper09 Swimming in Deionized.
    14 Jun 2010
    Absobloodylutety incredible!
    I'm actually lost for words! This is a first for me!
    :thumbsup:
  7. miahallen
    miahallen Team IRONMODS - World Champions!
    5 Sep 2010
    This :rock:
  8. Nexxo
    23 Oct 2001
    Supreme metalwork. :thumb:
  9. kier
    kier -----------------
    1 Mar 2011
    Looking superb.
    frosting the acryl strip is maybe an idea, but it's looking very good allready
  10. riekmaharg2
    22 Feb 2009
    Thanks for the amazing comments everyone :thumb:
    Here's the next update. I cut out a piece of 2mm alu sheet using the jigsaw:
    I then filed it down so that it fits nicely inside the front door panel:
    The finishing part of the top panel arrived today:
    Its a 35 pores per inch sheet of open cell Polyurethane foam based on Polyether:
    Here's some eye candy of it glued into the top panel:
    Here's the foam cut out ready for the front panel:
  11. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    Can someone poke me? I can't believe how awesome this single piece is! :jawdrop:
  12. IcyAero
    IcyAero What's a Dremel?
    4 Aug 2010
    I'm not kidding, I actually went :jawdrop: and :blush: both at the same time for real!
  13. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    That front panel is super clean looking! Keep it up!
  14. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Need to find a glue or something to put my jaw back...
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Ooooh yeah, looking hot :clap::D.
  16. Shayper09
    14 Jun 2010
    Ermmm....
    Fancy building me a case? ;)
  17. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Time to wake up. I must be dreaming. :jawdrop:
  18. Stem83
    26 Mar 2011
    we use that foamy stuff at work, used as a dust filter in the fridges we make.
  19. karolis
    karolis Code Monkey
    10 Mar 2008
    Damn. This thing should be in an art gallery when finished. Nothing big for starters. I'm thinking something along the lines of Tate Modern?
  20. riekmaharg2
    22 Feb 2009
    Thanks everyone :thumb:, your comments continue to fuel my work :)
    Yeah its awesome stuff, though took me ages to find a company that would actually sell me some in a relatively small quantity. I've made do with a 1.5 by 1 meter sheet of it lol, its expensive stuff too.
    Yeah lol maybe we should all start the Bit-Tech exhibit :)
    If only I had the spare time :(
