Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. bulldogjeff
    2 Mar 2010
    I've missed quite a bit of this, that top panel looks superb mate. The lighting on it is pretty much perfect.
  2. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    If you need some more let me know and I will get you some for postage costs, that wouldnt be much i expect.
    Our sheets are only about 50cm sq give or take 20cms maybe
    (also have it in a nice blue too, Image as color reference only)
  3. Attila
    Attila still thinking....
    22 Feb 2008
    It's just looking freaking awesome mate. :thumb: Not long to go before we can have a look at the whole shebang. :D
  4. BOBDBONE
    BOBDBONE Owner at BS Mods
    4 Feb 2009
    That is amazing craftsmanship. I would not have the patience to pull that off.
    Great work. I'll be keeping an eye on you. ;)
  5. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
    Thanks guys :thumb:
    Cheers Stem83 will do :thumb:
    Yep, its all slowly coming together, here the next update:
    I first filed out two strips for the end of the mesh:
    I then JB welded it to the mesh:
    I then masked it up for painting:
    While the paint was drying I gave the backplate a quick polish:
    Here's the acrylic strips painted:
    I also painted the mesh but I forgot to take a pic of it :(
    Next stage was roughing up the surface of the backplate for the JB weld:
    I then put JB weld on and put some weights on top, results will be posted up tomorrow:
  6. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    JB weld madness!! I was wondering though will these acrylic strips illuminate as good as before?
  7. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Awesome!
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    Very nice fine detail work going on here :) & hope you manage to solve the consistant glow bit out if it's possible but I'm not sure if it is without running less juice through it with it being a small acrylic piece, tough to do a perfect glow without any glare spots but fingers crossed you manage to do it :).
  9. riekmaharg2
    22 Feb 2009
    Thanks AnG3L & Nutman :thumb:
    Thanks Waynio, I've actually decided to embrace the glare spots I think it looks quite cool, pics are below.
    I've had a bit of a set back with the top of the case, even with all my careful measurements the top and front acrylic strips don't line up :( luckily though I've found the solution. I've managed to pull the mesh from the acrylic using clamps on the milling machine without damaging anything, I've then trimmed the mesh down a bit and re-JB welded it the correct position:
    While waiting for the JB weld to set I finished off the work on the front door panel, by filling in the gap between the casting and the alu sheet with car body filler:
    I then sanded it all down and painted it:
    And here's the eye candy for you all :)
    The combo of foam and polished alu sheet allows for a slight reflection of light through at certain angles:
    It will have a little more sanding done on the alu casting and the acrylic will be polished just before I fit it to the case.
  10. Nutman
    21 Oct 2008
    So happy following this worklog - you've come such a long way (and still has quite a bit to go, hehe) and finally some crucial pieces are beginning to come nicely together. Mod on!
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    Beautiful work mate & nice fix ups :clap:.
  12. AnG3L
    19 Mar 2009
    If I am going to try to find the proper words to describe the amount and quality of your work I am gonna ruin everything. So just mod on bro, do what you do best! :)
  13. [ZiiP] NaloaC
    [ZiiP] NaloaC Well-Known Member
    9 May 2008
    The level of dedication, determination and skill with this piece is incredible dude. Well done. Cannot for more :)
  14. Krog_Mod
    Krog_Mod New Member
    23 Sep 2003
    That is gorgeous. Good work!
  15. riekmaharg2
    22 Feb 2009
    Thanks everyone :D
    I've made part of the hinges today, there a 5mm piece of threaded alu at one end which then reduces to 3mm. A 2mm tube of non friction plastic then sits over the 3mm end of the alu, which will create a smooth feel while opening and closing the door:
    All the work was done in the usual way on the lathe.
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looks kinda insignificant :lol: but it's a nice touch of detail to the function of the panel, good stuff :thumb:.
  17. voigts
    voigts New Member
    26 Apr 2006
    this is just so sweet.
  18. BrokenJaw
    BrokenJaw Member
    16 Jun 2011
    That foam and shiny aluminium really works well, especially with the hex mesh over it
  19. Stark.Jr
    Stark.Jr New Member
    22 Mar 2011
    i have follow this built from the start, and i did think in the start how the hell will he pull this case of :O. and now i see how,
    Metall skill, dont ever give up, tons of idees and a sick eye for details.
    im just on my knees bow for you!!
    Keep on whit this and i hope it never ends it just keeps getting better better and better!
    //Stark.Jr
  20. Stem83
    26 Mar 2011
    cant wait to see more of this come together, looks sooo good
