Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
    Insignificant yet highly effective :)
    Thanks voigts :thumb:
    Thanks BrokenJaw, yeah I spent a long long time looking for the perfect combo :)
    Thanks Stark.Jr, I have to admit there were the odd one or two parts that I wasn't sure how I was gonna make them lol :)
    Yeah its slowly getting there :)
    I've finally managed to get the hinge on and the door matching with the top panel, it was a bit more fiddly than I expect and I had to repaint the inside of the door twice as a caught the the paint while fitting the door :wallbash: however its finally done. Heres the pics with the top panel just resting on top as I can't properly fix it on just yet:
    I've yet to glue on a thin strip of rubber where the hinge hits the case:
    And here you can see the aluminium hinge with the plastic around its core:
    I'll give it all a final clean up and remove excess paint e.t.c later on.
    Now its time for the light strip which sits at the top of the inside of the case:
    I first marked up a piece of 2mm alu:
    I then began the long process of milling out all the parts while continually swapping the clamps around due to the rather thin areas:
    This will be continued tomorrow.
    Reverse likes this.
  2. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    oooooo looks sweet as. great craftsmanship
  3. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Dear, oh dear, that's frikkin' beatiful. I can't believe how well those cast pieces sit together. Amazing job - keep it up! :thumb:
  4. riekmaharg2
    22 Feb 2009
    Thanks Stem83 :thumb:
    Yeah me too lol, I was amazed that the separate castings both shrunk so evenly as they cooled.
    Waynio likes this.
  5. mr.sh
    mr.sh FEAR
    31 Jul 2009
    Great work. Look awesome! :clap:
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D Yeah that's what I meant :) wow this is looking sooooooooo damn hot when it all comes together :jawdrop: incredible stuff mate :clap::D.
    Crammed with awesomeness +rep :D.
  7. stonedsurd
    11 Mar 2009
    Fantastic work.
  8. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    ^^ what they said.
    the alignment is great. The overal look as well... can't wait to see more!
    :clap::clap:
  9. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
  10. Stark.Jr
    Stark.Jr New Member
    22 Mar 2011
    mod of the Millennium! :jawdrop:
  11. sebpruiz
    sebpruiz New Member
    9 Jul 2011
    I love the grill passing through the middle with the blue lines on either side. The grill reminds me a bit of the core 1000.
    Really good!!
  12. Cheapskate
    13 May 2007
    It was well worth the wait to finally see the panels in place.:D
  13. Salisant
    Salisant New Member
    17 Jul 2011
    Looking awesome :)
  14. GCOFIELDD
    GCOFIELDD Member
    10 Oct 2010
    100% with Cheaps.
    A lot of planning and effort has gone into this design. Looks damn amazing :thumb::rock::clap:
  15. Attila
    Attila still thinking....
    22 Feb 2008
    Holy moly mate, it looks like a bought one. :eeek: :hehe:
    Nah, it looks better. :thumb:
  16. riekmaharg2
    22 Feb 2009
    Thanks everyone :thumb:, glad to hear you all like it :)
    I had to re-cut some alu for the inside light strip again as I made one of the slots 1mm to big :wallbash:.
    So here's the new piece at the same stage as the old piece, I also used a knife to calve a groove into the alu instead of using a marker as the WD40 oil kept washing the marker off:
    I then milled out the shapes:
    Here's the result after a little filing of the edges:
    I then put some double sided tape onto the alu:
    And stuck on some foil:
    I then poured clear resin into the shapes:
    ColdzeroTeam likes this.
  17. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    That's interesting. How will it work?
  18. Nutman
    21 Oct 2008
    I ask the same!
  19. Stem83
    26 Mar 2011
    interesting.....
  20. riekmaharg2
    22 Feb 2009
    This is how :)
    Here it is after the resin set and with the foil off:
    I then sanded it down with wet & dry:
    I then sprayed on fluorescent blue paint onto the back of the piece:
    And heres how it looks on the side that will be visible, after I gave it a polish:
    All that's left now is to fix it into the case and light it from behind with LED's.
    matt... and Razer2007 like this.
