Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Wowwwww. That is awesome. Very smart. I actually like how it looks before it is sprayed too.
  2. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    That's exactly the technique I used to build a table about 2 years ago. I had a complex shape that would have been damn near impossible to make (aka have the whole match the plexi cutout) so I ended up just pouring resin to back fill it. Works a treat man! Looks pretty damn awesome!
  3. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Impressive stuff, look forward to seeing more :)
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    Lovely detail :).
  5. Combatus
    16 Feb 2009
    One seriously awesome-looking beast!
  6. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Cool. Will the resin be backlit?
  7. Evenge
    Evenge Minimodder
    16 Sep 2006
    Awesome work! :thumb:
  8. RonanH
    RonanH mod-envious
    30 Mar 2010
    :jawdrop: for some strange reason I stopped getting notifications about this build... thought it was on hold. Manually checked and KABOOOOM! 10+ pages of drool :eeek:! It's all coming together with so much awesomeness I can't believe my eyes! Fantastic :rock::clap:
  9. ColdzeroTeam
    ColdzeroTeam What's a Dremel?
    9 Dec 2010
    wow... very nice work :)
    +rep
  10. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Thanks :thumb:, yeah me too, I eventually went for the spray paint to make a better colour contrast between all the silver and the shapes.
    Thanks Sixfootsideburns :) yeah its a load easier to do and look just as good. I bet you used rather a lot of resin to do a table.
    Thanks GravitySmacked, Waynio, Combatus :thumb:
    O yes :D
    Cheers for the awesome comments Evenge, RonanH, ColdzeroTeam :thumb:
    Heres the next update, sorry about the wait.
    First off I JB welded the panel onto the case and soldered in some LED's:
    I put in a little loop for when the door is opened and closed:
    I then wired the top panel:
    I'm using 5V and have chosen resistors that don't give the LED's the power they are capable as I've got so many LED's in parrellel and some will have lower resistance than other, so even if they do allow more current through they wont be overloading:
    I then JB welded the top panel onto the case:
    Cheapskate, Nutman and Razer2007 like this.
  11. Razer2007
    18 Jul 2010
    oooh my heaven that looks amaaazing!! That light strip is super!
    +rep obviously
  12. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Superior!
  13. stonedsurd
    11 Mar 2009
    I would do unspeakable things to that case...
    :worried:
  14. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Fantastic work so far :)
  15. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Joined this build very late but just gone through it all and well "Fantastic Scratch Build!"
    Resin insets look the B's Knees, wouldn't mind giving them a go in the future!
  16. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    Now you did it. If we start seeing a billion people doing blue cases instead of orange we know who started the trend.
    Thanks for doing an awesome case. It's not too late to change it all to orange. ;)
  17. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Oh my. this is looking incredible. Those LEDs on the sides and top are just like you modeled, and they look awesome.
  18. Motoma
    Motoma What's a Dremel?
    5 Aug 2011
    This looks just amazing. I seriously wish I had the ability and patience to do this myself.
  19. Nutman
    21 Oct 2008
    +1 - well deserved.
  20. Cheapskate
    13 May 2007
    The last pic makes me thing you should wire them up to cycle like a landing strip.:D
