Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    Loving it :rock::jawdrop::hip::clap:.
  2. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    :rock: Yeah it rocks man!
  3. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Thanks everyone :thumb:
    hehe lol :)
    Thanks RedManc, yeah they work great, its not quite as strong as it would be with acrylic but its a load easier.
    lol, thanks monkeyfun, personally though I prefer blue to orange.
    Thanks voigts, thats what I was aiming for :)
    Yeah, could have been cool, too late now though :( the top panel is stuck on solid.
    Next bit of work is the top panel sides. I started by marking the areas I need to mill onto a 3mm strip of alu:
    I then milled out slots along the strip using a 4mm milling bit:
    I then sanded down the rough bits and stuck on some double sided tape:
    I then stuck the alu piece onto the wood so it doesn't move as I change the position of the clamps, I then milled the strip edge down with a larger milling bit to give a smoother finish:
    I then milled down some sections to 0.5mm:
    The next update on these should be tomorrow.
  4. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Cool. What are those very thin pieces for?
  5. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    And yes, I read this thread from the beginning to the end...again, and I think I will do this so many times in the future! Excellent ideas, excellent craftsmanship, as someone said it before, there is sooo many things that we may learn from you!:clap:
    enormous likes this.
  6. Jipa
    5 Feb 2004
    I just had a mahoosive modgasm looking at those pics. Superb.
  7. HighWire
    HighWire What's a Dremel?
    21 Mar 2005
    And here's me thinking I was somewhat of a metal worker... Back to the drawing board...
    Excellent work! Great attention to detail, not to mention quality craftsmanschip! Stunning!
  8. -Jv-
    -Jv- What's a Dremel?
    29 Mar 2011
    Oh god, I can't imagine how awesome it is too look at something like this taking shape knowing you all made it yourself.. Truly EPIC work !
  9. riekmaharg2
    22 Feb 2009
    There to fit over the blocks that hold the top panel onto the case as well as the blocks that hold the CD/DVD cage onto the case.
    Thanks nagyizom, I'm glad to here my log makes an interesting read :)
    Lol :D, Thanks Jipa
    Thanks HighWire :thumb:
    Thanks JV, that is one of the reasons I like this type of work, as specially when I takes a while to make it, as it adds to the feeling of accomplishment :)
    Next update will be tomorrow.
  10. riekmaharg2
    22 Feb 2009
    Heres the next update, I've filed out the holes:
    I then JB welded in some rare earth magnets:
    I then JB welded the strips onto the case:
    Then strips will be painted in a rubbery paint to eliminate any rattling between case and side panel.
    I then used a Jigsaw to roughly cut out a side panel, I then used the milling machine to trim down the side panel to match the case. I then trimmed down the ends so that the side panel fits over the top panel sides:
    I then milled down a large section in order to make the curved part of the side panel:
    I then setup a jig to hold a tube onto the side of a table and to hold the alu down while I hammered it with a rubber mallet:
    Heres the result:
    I then drilled two holes for the cables for the heatsink LED's:
    I then drilled out the many many holes for attaching the heatsink:
    And then the two large holes for the coolant angle barbs:
    Heres the heatsink acrylic where it will fit:
  11. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Very nicely done.
  12. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Sweetness!
    Btw: getting closer and closer to post #1000 in this worklog. ;)
  13. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Bloody hell man!
    Great work as ever.
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    ^ :D Agreed, Fantastic work mate :):jawdrop:.
  15. Cheapskate
    13 May 2007
    Great stuff. I don't like to use magnets, though. They do things to the metal plate in my head...
  16. Nutman
    21 Oct 2008
    Which one of them? ;)
  17. riekmaharg2
    22 Feb 2009
    Thanks voigts :thumb:
    Thanks Nutman, sweet I hadn't noticed that :)
    Thanks SiiP & Waynio :thumb:
    I'll have to make sure I don't get the hardware close to them as I'm installing it too. It was the best way I could think of making it without using screws or any other visible mechanism. I do have a plan in case the magnets aren't strong enough though.
    I need everyone's opinion on something. I can't decide what finish I should have on the edge of the acrylic sheet that seals the heatsink. At the moment its just the finish that came with it which look pretty cool:
    But its not as nice when there's a bright light shining on it:
    Any ideas on what the best finish could be?
  18. Razer2007
    18 Jul 2010
    I'll say sand the sides with like 300grit paper. So that it's frosted.
  19. [ZiiP] NaloaC
    9 May 2008
    I would also go with a frosted look, I think it would suit the finish on the rest of the case.
    As ever, looking forward to more :)
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    I think so too :).
