Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    IF those are stress cracks, you need to re-make the fittings. To strengthen a piece of acrylic like that, bake it in the oven at low temps for a certain amount of time (use Google to search for the exact recipe for this). This is common with especially extruded acrylics - cast acrylic is better at preventing stress crackings like these....
  2. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    I've just taken off the barbs and all the cracks are definatly on the out side, if they were stress cracks would I be able to crush it or pull it apart, as I can't. Each crack goes half way into the acrylic. Could it be the heat from sanding? I couldn't find anything on baking, I'm not sure what it would be called, I've tried strengthen acrylic and baking, and heat strengthen.
  3. RonanH
    RonanH mod-envious
    30 Mar 2010
    Some information on annealing plastics... this is for plexiglas but it gives you the basic procedure... it's pretty much the same principle as the procedure to anneal or harden metals.
    http://www.rplastics.com/annealing-plexiglass.html
    edit: apparently plexiglas is acrylic :D
  4. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Yea plexi is the brand name for acrylic. Try getting cast cubes from www.tapplastics.com.
    Also, instead of sanding them down, why not try a round over bit on a router?
  5. Nutman
    21 Oct 2008
  6. Cheapskate
    13 May 2007
    There's a couple of reasons this could happen. One big factor would be getting the plastic too hot during shaping. Any contact with alcohol or cold will accelerate the cracking. You could have had too much stress on it cutting the guts, or it could be you just got some crummy plastic.:(
  7. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    Those aren't crazing marks from alcohol. Crazing will make the cracks look almost like the acrylic was frosted. Those are definitely stress cracks, and you need to remake them ASAP or get them out of your system.
  8. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Stress cracks to be sure (called crazing). Having made many of my own reservoirs, I've had my share of issues with this. The kind of acrylic you use makes all the difference. Extruded acrylic is worthless when it comes to trying to machine anything. Only work with cast acrylic. Even working with cast acrylic, I don't machine sand anything. It is simply too easy to get the material heated up too much and cause it to craze. Acrylic also does not respond very well to having metal barbs used with it as the differences in expansion rates can cause crazing also. I've learned to only use plastic barbs with acrylic so that this is never an issue. I thought when I saw those that they look great, but wondered at making them out of acrylic like that.
    What happened to the link? There is no url in the code for it to link to.
  9. riekmaharg2
    22 Feb 2009
    The link wasn't suppose to be a link, wups. I meant for you to search that name in the Google sketchup 3D warehouse on the File menu.
    Ah yeah it could well be the difference in expansion which would explain why the cracks didn't appear until I started using them. I presume they are cast as they started off as ice cubes. Sounds like you need a special oven for that annealing process :( I have been able to flame polish the barbs as I didn't have much to loose if it went wrong which healed all the cracks nicely but they could crack again and the only problem with plastic barbs is they don't look very nice.
    I've also finally decided how I'm gonna finish the rad cover, and I'm currently waiting for materials for it and for the new CD/DVD/HDD bays.
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    Shame about the barbs mate, they looked awesome :( but you being you I'm sure you'll do something as good or better. :rock::D
  11. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Awsome build mate.
    To bad to hear about your cracks. I would agree with the rest of the crowd that it looks like stress cracks. From the picture, I think it looks like most of the cracks are on the outside of the connectors by the barbs. Im instantly thinking that maybe the two outlets/hoses were pressed to much together when beeing mounted. Don't know if I explain good enough but picture the 90° angle beeing decreased.
    Don't know at all if thats the case but that was my first thought.
  12. voigts
    26 Apr 2006
    Duh on my part. :duh: Got it. Thanks!
  13. GLA-58
    GLA-58 What's a Dremel?
    1 Sep 2011
    OOOhhhhhh yyyyyeeeaaahhhh some things seem to happen just when one does not need them. :wallbash:
    But I wish to congratulate you with this superb build. :clap:
    greetings and peace of mind.
  14. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    You are sick maaaan, thats awsome !
  15. riekmaharg2
    22 Feb 2009
    After I flame polished the barbs to melt the cracks together it seems to have solved the problem, they haven't re-cracked :), maybe that's one reason why the DCC laing pump res's are flame polished after machining.
    Glad to be of help :)
    Cheers GLA-58 & KoSoVaR^ :thumb:
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    That's good to hear. :)
  17. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    I just read trough the hole build log man, its legendary work!
    I'm just a bit sad that you didn't finish the MB waterblock, that looked amazing!
  18. Sarakon
    Sarakon The German
    11 Feb 2011
    Problem has been solved :D good good!
  19. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    I love you.
    Full homo.
  20. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
    Seriously love this build - the simplicity of the l/c loop is brilliant, and that PSU cover is inspired, would be cool if you could somehow tie/anchor that 24-pin cable to the floor of the case at a right-angle, would set off the rest of the precision nicely :)
    Also - are you going to add a grommet (or at least neoprene edging) to the routing hole for the PCI-E cables?
