Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
    Cheers Waynio :thumb:
    Yeah I was gutted when the machine milled through the bottom of it, after it almost finished, but I do quite like the new simplicity look of just a CPU and GPU block, I think it looks neater than having blocks everywhere.
    Yep :)
    :worried: lol
    Thanks CraigWatson :thumb:, do you mean so that the 24pin wires come straight along the motherboard tray from underneath the motherboard, then after a bit of distance they then curve round into the motherboard connector? I'm gonna add a cover for the sata wires/pcie wires but I haven't decided how it will look yet, the edges of the alu are very smooth if you are thinking they could cut into the wire?
  2. Mystikal0412
    Mystikal0412 Safety First, Think Twice!
    31 May 2011
    Great work on this mod! Love it!
  3. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
    Apologies, I meant the ATX cable from the PSU that's routed through a dedicated hole in the board tray (black with mesh sleeving).
    Neoprene/edging would just look better/cleaner/more professional IMO, just personal preference :)
  4. riekmaharg2
    22 Feb 2009
    Cheers Mystikal0412 :thumb:
    Ah, that one has an alu ring around which is glued in place now, do you mean replace the alu one with a neoprene ring?
  5. riekmaharg2
    22 Feb 2009
    Finally got another update for you all :), and this one will be the second to last update of parts being made with one update after that being final eye candy as well as the collection of my favorite images of stages from throughout the build.
    I decided to ditch the idea of using lexan for the rad cover, and instead opted for fiberglass, the downside being it takes ages to sand it down smooth but it was worth it to get the shape I wanted.
    So to begin I first made a mold by going across some glued together sheets of plywood with a ball end mill on the bridgeport, I then used a sander to smooth out the shape, then finally I stuck the backing of double sided sticky tape onto the mold to make it non stick for the fiberglass:
    I then milled out some clear acrylic pieces for the little windows:
    I then used fiberglass cloth with resin to create a form over the mold and to secure the acrylic windows:
    The black bits are from the bin bag I had it sitting on:
    You get a slightly transparent look:
    I then chopped the ends of some releasable cable ties:
    I then sanded the alu panel I made earlier and polished it:
    I then JB welded the alu onto the fiberglass and milled out a thin section of the fiberglass on each corner:
    And the cable ties will sit in like so and be JB welded in place:
    each cable tie slots into a hole in the side panel in order to fasten the rad cover in place. I have completed the cover but those pics count as eye candy for the final update :) I have also almsot completed the new CD/DVD/HDD cover panels which will be in the final making parts update.
    CraigWatson, Waynio and Editor22 like this.
  6. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    That's genus dude! +rep :D
  7. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    incredibly last minute sub:)
    loving the design and the ingenuity in this project.:jawdrop:
    you must have doubled the profits of JB weld in the past months :D
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    Lot of that in this project, & not a handful of awesome clever features but so many I totally lost track of how many :D too much awesome for 1 project to take in properly. :lol:
    The earlier eye candy pictures already shown are absolutely awesome so wow when this is complete it's a legendary build & already know it will cause eyegasms all over the place. :D:clap: rep
  9. stonedsurd
    11 Mar 2009
    The cable tie idea is awesome! :thumb:
  10. Sarakon
    Sarakon The German
    11 Feb 2011
    :D nice one
  11. riekmaharg2
    22 Feb 2009
    Cheers Editor22 :thumb:
    yeah lol, I used two packs gluing the top of the case on and gluing the front parts together lol, there only about £7 each though :)
    Thanks Waynio :thumb:, lol, I'm gonna try set up some sort of photo booth with those daylight bulbs for the final shots, so they should be the best quality pics I've done on the whole project.
    Thanks stonedsurd & Sarakon, took a while for me to think of using them, I was thinking a magnets first but the cable tie idea is much stronger, as they're glued and the ridges give the JB weld more grip to keep them in place :)
  12. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Effin' nice!
  13. Shurika
    Shurika Minimodder
    9 Mar 2012
    Yeah! Another great update! Cool, clean work:thumb:
  14. riekmaharg2
    22 Feb 2009
    Cheers Nutman & Shurika :thumb:
    I've decided to skip the last making update as the CD/DVD/HDD covers were made in the same way as the psu cover.
    So here it is the last update, with eye candy for all after almost 2 years of work. First off is a brief collection of the pics from the stages of the build:
    I hope you've enjoyed watching my project as much as I've enjoyed working my way through it :)
    And finally the finished pics, All those looking for high res pics, you need to click on the zoom links then click the magnifier at the top right of the pic, then if you want to download it just use the download button on the left, as the zoom feature uses flash so you can't right click and save it:
    Click Here for zoom
    Click Here for zoom
    Click Here for zoom
    Click Here for zoom
    Click Here for zoom
    Click Here for zoom
    Click Here for zoom
    Click Here to zoom
    Click Here for zoom
    Click Here for zoom
    Click Here for zoom
    Click here for zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    [​IMG]#
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Click Here to zoom
    Sarakon and [ZiiP] NaloaC like this.
  15. bruce_rob
    bruce_rob What's a Dremel?
    18 Apr 2010
    This is serious mate very nice work
  16. jhanlon303
    7 Sep 2006
    MEDIC!!!!!!!!!!!
    Man down. Defib needed.
    :jawdrop:
  17. bugeye
    bugeye Sleep Deprived
    16 Aug 2011
    Send him over to me when he's finished saving you ..... stunned by this build :jawdrop:
  18. Black_Mummy_DK
    Black_Mummy_DK What's a Dremel?
    3 Oct 2011
    that is freakin awesome!
  19. l3p
    l3p www.^.nl
    1 Nov 2010
    Indeed awesome man!
  20. mark1903
    mark1903 Minimodder
    27 May 2011
    F-ing Outstanding :jawdrop:
