Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. jadawgis732
    jadawgis732 What's a Dremel?
    31 Dec 2009
  2. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Could be photoshopped, too.
  3. Guest-23315
    Guest-23315 Guest
    Or a sheet of mirrored vinyl that isnt sitting flat?
  4. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    ^^^ thats my guess too.
  5. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    It doesn't seem to be too bad as I've smoothed out the edges and the paint softens the edge even further, I'll still be careful though just in case :)
    Thanks :thumb:, yeah I think it was definitely worth it :)
    Attila and Waynio like this.
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    It's a very neat look for final photos, think all projects could look a lot better using a method like this. rep for sharing the nuts & bolts of it. :)
  7. Attila
    Attila still thinking....
    22 Feb 2008
    Consider that idea stolen.:D It's simple and inexpensive, and looks good. +rep.
  8. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    The end result of your work is beautiful I enjoyed following this from the beginning. Outstanding craftsmanship I look forward to the next project.
  9. SkyThread
    SkyThread What's a Dremel?
    23 Apr 2012
    Really nice project, gave me many ideas for future modding.
    Keep up the nice work. :D
  10. riekmaharg2
    22 Feb 2009
    Glad to help :)
    Thanks Mechh69 & SkyThread :thumb:
    Also if anyone wants to know how to get the tubes onto barbs so tighly, all you do is pick a tubing that is slightly to small for the barbs, then heat the tube in hot water so it goes soft, then dip it into isopropanol or similar then the tube will go on easy then once the isopropanol has evaporated the tube is stuck solidly onto the barb and only scissors or reheating will allow you to remove it.
  11. Phyonics
    Phyonics What's a Dremel?
    4 Oct 2011
    I've just read the entire build log over the last 2 days.... and I've got to say that it's absolutely stunning :rock:
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    So many things I like in this project, the bendy anti vibe hdd cage is 1 of the many highlights, that was an awesome idea. :D
  13. riekmaharg2
    22 Feb 2009
    Thanks Phyonics & Waynio :thumb: glad you like it :)
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    Wow 374,904 views. :jawdrop::rock:
    I think this was a popular one indeed. :clap::D:thumb:
  15. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    And every view and comment was worth it. :thumb:
  16. echo three
    echo three What's a Dremel?
    26 Jan 2012
    I love flicking through the pages of this and watching it get built.
  17. riekmaharg2
    22 Feb 2009
    Thanks Waynio, Blooddrunken & Echo three :thumb: glad to hear you like it :)
  18. stallo709
    stallo709 Minimodder
    8 Apr 2011
    Fantastic work...compliment:clap:
  19. riekmaharg2
    22 Feb 2009
    Thanks stallo :thumb: sorry about the late reply I didn't realise you had left a comment.
    Here's a mini mod I've done to the CD/DVD drive bay cover. Its the spindicator from here: http://www.pcbheaven.com/userpages/hdd_led_spindicator/
    However I've put it into a line instead:
    Waynio likes this.
  20. Squigly
    Squigly MODfiend.. ~twitch~
    20 May 2012
    I like the horizontal version of the spindicator :thumb: Also im pretty sure the code could be modded so you get a back and forth on the LED's.. linda like the light bar that was on KIT from night rider :D
