Case Mod - Complete Project Blue OMEGA
Discussion in 'Project Logs' started by 4LIEN, 2 May 2021.
  1. 4LIEN
    4LIEN Modder
    4 Jan 2020
    INTRO
    Hello guys i'm back here to post my first new project of this year! It was started two months ago, now i still working on it, but it's already near to the end, so its time to worklogging! :dremel:
    This project will be soft modded, nothing extreme, its commissioned by a client!
    Will be based on the beautiful Corsair Spec Omega chassis, i really love this case and this is an opportunity to work on it!
    HARDWARE & COOLING SETUP
    Intel & Nvidia combo for this build, Gigabyte Aorus parts and of course watercooled, but for now only the CPU! In the future also the GPU will be put under liquid!
    Detailed components list:
    CPU: Intel i7 10700K
    MB: Gigabyte Aorus PRO AX Z490
    VGA: Gigabyte RTX 3070 Gaming OC
    RAM: 2x8GB Kingston HyperX 3600MHz
    PSU: Cooler Master MWE 750W Gold v2
    Storage: OS - Sabrent Rocket 256 GB / DATA-GAMES - Crucial P1 1TB
    Fans: 4x Cooler Master Masterfan MF120 Halo + 2x Scythe KazeFlex Slim 120
    Radiator: Barrow Dabel-30a 240 + 360
    CPU WB: Bykski Ice dragon
    Fitting, adaptors and others: Bykski + BarrowCH
    Pump: Barrow PWM 17W with 195mm reservoir
    Liquid: Alphacool Eiswasser Crystal Blue
    Tubing: hard PETG 14x10mm
    DESIGN & THEME
    This mod will be soft modded, so minor change will be made, the color of the case, some LEDs, grill and covers, and other little parts, but all in the style of the case shapes.
    So now let's start with a picture of the case!
    kim and Jean R built like this.
  2. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Disassembling this case was really easy!
    For the front face, i made a little mod, removed the glass and installed a grill, so i can achive a better airflow for the 360mm front radiator.
    Also another thing i done, it was to replace the original only Red LED strip with an RGB one.
    And this is a preview of the blue color chosen for this project, is a special matte blue with metallic effects!
    The new front assembled!
    Toru, Cheapskate and Jean R built like this.
  3. 4LIEN
    4LIEN Modder
    4 Jan 2020
    This case doesen't support vertical GPU mount, so i bought the Cooler Master GPU Holder Kit v2.0, that include also the riser cable!
    But with this kit the GPU will stay in the center of the case (that is a good thing for airflow on closed case) but we want the card on the border of the case, so i've modified a little the Cooler Master kit with some custom bracket and cutted a hole in the case for the cables.
    Jean R built likes this.
  4. 4LIEN
    4LIEN Modder
    4 Jan 2020
    So guys here we go with some pictures of the hardware components that will be installed in this mod!
    kim likes this.
  5. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    I definitely prefer that metallic blue :thumb: the red is a bit too vivid for my taste
    4LIEN likes this.
  6. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Some pictures of the liquid cooling parts!
  7. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Now it's time for something more interesting, the making of the interior covers!
    Designing the cover style
    Cutting the plexiglas for the backlight :dremel:
    Printed on paper sheet (the plexiglas panel is the one that will cover the PSU)
    Applying the paper sheet on black wrapping vinyl and start to hand cut all the lines!
    Preparing the vinyl for the application, it will be applied on a white plastic sheet.
    And finally the cover installed! :rock:Between the black adesive vinyl and the plexiglas there is a white plastic sheet, to diffuse the light. The LED strip will be positioned on the right side.
    You can see also the main hardware and cooling parts installed to test the clearances.
    Toru, Defyant Mods and Jean R built like this.
  8. kim
    kim hardware addict
    10 Jan 2016
    Nice and proper modding :dremel:...though :idea: ...after your Alienbase it might be a piece of cake :grin:
    4LIEN likes this.
  9. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    It's got a lot to live up to ! but i have faith in your amazing skills:rock:
    kim likes this.
  10. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Thanks guys a lot for the support!
    Like said by @kim , this mod will be a piece of cake for me! :grin:
  11. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Another little update about the interior cover! This time for the bottom one for the PSU.
    Plus the beautiful 24 PIN extension custom made with my friend Hardwire Custom Cable Maker Italy!
    You can also see the pump installed, i used the HDD bay like support, and just need to make a little metal sheet plate to fix it.
  12. 4LIEN
    4LIEN Modder
    4 Jan 2020
  13. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    Nice work buddy :rock:
    4LIEN likes this.
  14. pccustom
    pccustom Multimodder
    12 Jul 2017
    bello!
    4LIEN likes this.
  15. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Thanks guys!
  16. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Hello guys, finally this project is now finished! There is just a little extra to add, i hope i the next days, but the major jobs are done!
    So now it's time to post some good quality pictures to show the result!
    FINAL PHOTO SET PART 1
    Jean R built and Cheapskate like this.
  17. riekmaharg2
    22 Feb 2009
    That's one mighty fine looking PC :thumb:
    4LIEN likes this.
  18. 4LIEN
    4LIEN Modder
    4 Jan 2020
    FINAL PHOTO SET PART 2
  19. 4LIEN
    4LIEN Modder
    4 Jan 2020
    FINAL PHOTO SET PART 3
    Someone maybe can think: "what about the side panel?"
    Well the side panel was re-designed, because the original tempered glass isnt good for a vertical fan cooled GPU, so i made a sort of big grill to protect the side and also to allow a lot of airflow!
    The result is at your judgment!
    p.s. I'm also introducing a new style of photoset, hope to improve the exposition!
  20. Cheapskate
    13 May 2007
    It came out absolutely lovely. :thumb:
    4LIEN likes this.
