Project: Blue Penguin (Mini ITX)
Discussion in 'Project Logs' started by solar, 25 Sep 2004.
  1. solar
    solar What's a Dremel?
    6 Mar 2004
    It blows upwards but there is a vent directly to the side of it, so I guess most of it will be going out of there. The temp is fine anyway!
  2. H2O-G33K
    H2O-G33K What's a Dremel?
    25 Jan 2003
    Cool (sorry, bad joke!).. I think personally I'd make a small duct to encourage the air out of the case - that way the CPU fan would also be a case fan. I'm sure the temps are fine, I'd do it anyway - better to be safe than sorry! ;)
  3. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Nice work, is that a hercules monitor as it looks like their 19inch one that they didnt release in the end?
    Edit: Ah its a 14inch tft. Whats it like as it would look ace next to my 17incher?
  4. solar
    6 Mar 2004
    It's a lovely little monitor - sharp picture and I think it looks great. I got it from a computer fair.
  5. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Splendid I might get one in the next few days :)
  6. JungleGorilla
    JungleGorilla What's a Dremel?
    21 Apr 2004
    "splendid" now that's a word you don't hear too often nowadays.
    I love the mini-itx... I made a HTPC out of the Epia via m9000 and an old broken VHS chassis.
    I'm thinking of doing a similar project to what you have for a router/server.
    It looks awesome :dremel:
  7. toxicfeet
    toxicfeet What's a Dremel?
    23 Apr 2004
    Im currious if that monitor can be mounted on to a LCD arm. If it can, did you ever think about mounting the case to the back of the LCD to further reduce its footprint?
  8. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Nice little build... sort of ironic that you're using a M$ mouse, though!
  9. Vazzini42
    Vazzini42 What's a Dremel?
    16 Apr 2004
    solar i love this case, it's dimensions are almost the same as the mod I am currently working on ...
    http://forums.bit-tech.net/showthread.php?t=91995
    Do you have any pics of the internals? I am curious how everything is arranged internally.
    Looks amazing bud, great work, simple clean and purdy
    Vazz
  10. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    Nah, peripherals are one of the few things MS does really well. My MS mouse is currently mousing on a Linux system too. All the LInux or BSD systems at work seem to have MS keyboards & meese!
    Great case; the blue really looks good. Are you sure there's no room for a bloooo LED or three?
  11. solar
    6 Mar 2004
    Wow, I just noticed this thread got resurrected from over a year ago.. impressive!
    Well.. an update. The Blue Penguin sat on my desk and was used regularly for several months, but I found it to be a bit sluggish for everyday desktop use. I put an extra 256mb of RAM in there (another stick of RAM was such a tight fit that the top started to bulge slightly :D ) but I think the main problem was the slow laptop hard drive. Eventually I found a linux distro that works almost perfectly on my laptop (Yoper) so the Blue Penguin was retired. I am currently in the process of converting it into a file server for my network. I've replaced the fan with a heatsink for silent operation, and I'm currently pondering some different ideas for a new case (it'll need to be bigger as it's having a full size hard disk and a CD ROM). I'll be sure to post a project log on here when it's done :D
    Cheers for the interest guys.
    PS the little 14" monitor is now plugged into my laptop, mmm.. dual-head goodness.
  12. toxicfeet
    23 Apr 2004
    I am just curious if the box isn't too heavy to mount it to the back of the LCD.
  13. drinn
    drinn What's a Dremel?
    16 Jul 2004
    Very nice looking case dude :)
    What about blue or UV-cathodes? :D
