Project Blue Qube
Discussion in 'Project Logs' started by The Spyder, 21 Oct 2003.
  1. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    I love those cars. I had a hard time finding that Jetta here in the Netherlands after Fast and the Furious. I was obsessed by Jesse's white Jetta. After 2 months it turned out they're called Vento's here :rolleyes:
    Anyway, perfect project!!
  2. modtheplanet
    modtheplanet What's a Dremel?
    10 Oct 2003
    yes i would love to know what typ of software that is and where he got the touch screen lcd.
  3. Da_BaCoN
    Da_BaCoN Minimodder
    25 Aug 2002
    same here - i'd love to have that software. it looks quite nice
  4. Solarius
    Solarius What's a Dremel?
    3 Oct 2003
    Incredible. That's SO much better than the system that comes in the BMW 7 series, and I bet its cheaper too! Damned.
  5. Crass
    Crass What's a Dremel?
    26 Sep 2003
    Really clean overall look, Looks great.
  6. complexprocess
    complexprocess What's a Dremel?
    8 Jul 2002
    Awesome project. I'd be more than proud to have it sitting on my desk, and yet it's stuffed away in a trunk somewhere. :)
    Now that we've seen how you did the computer hardware, it would be sweet to see how your friend fit it into the car and handeled the software end.
    I'm looking forward to your next project. I've wanted to do an mp3 box for a long time, but it gets so cold in my car during the winter (and hot during the summer). I'm afraid it would get damaged.
  7. djengiz
    djengiz Pointless.
    16 Aug 2002
    Very nice! I really like the blue theme! :rock:
  8. Da_BaCoN
    Da_BaCoN Minimodder
    25 Aug 2002
    yeah, i'm really interested in not only the software, but how he molded the area for the screen too. got any info for us, please, kind sir?! :D :naughty:
  9. Bluebark
    Bluebark What's a Dremel?
    1 Sep 2003
    Very nice…good looking, yet functional. A beautiful piece to be locked away in a trunk… :sigh:
    P.S. Love the view...I didn't spot any fishing poles... :confused:
    P.S.S. Mighty fine look’n Mark :thumb:
  10. ynema
    ynema What's a Dremel?
    27 Oct 2003
    Great case. Something you could do to the corners is get some aluminium corner cubes Like so
    Might Neaten The corners And lift the base off the ground a Bit
  11. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    wow, very nice project, when it is in the car is it just sitting there or is it mounted or fixed down in some way, anyways very good work
  12. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Jetta Software looks like MediaEngine with a custom skin.
    Nice use of space, my cupholders are teh suck in my 1997 MK3. I put my cups on either side of the e-brake.
  13. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Great Job! I've been dreaming up an idea for a case similar to this but with a built in LCD
    I'm just sad it will be hidden in the trunk of a car :(
  14. bsodmike
    bsodmike Banned
    11 Oct 2002
    Is it me or is the bent metal touching the caps? I would think that is earthed? :eeek:
  15. spinDr
    spinDr What's a Dremel?
    13 Nov 2003
    capacitors usually have a plastic coating for that reason. If i remember my physics lesson right, that part of the capacitor isnt actualy attached to any of the plates inside.
    still i could be wrong.
  16. The Spyder
    The Spyder What's a Dremel?
    27 Apr 2003
    theres a 1/4inch gap above the cap and the fin if you cant tell ;)
  17. kojiosuna
    kojiosuna What's a Dremel?
    22 Aug 2003
    Hi Spyder
    I seldom post anything here, cause I get ideas for a progect and it never materializes. But I am really interested in the software used for the system you made. I can so use that in my car at this point and time.
    Thanks.
    KOji
  18. kingkobra
    kingkobra What's a Dremel?
    18 Jan 2003
    Spyder, what touchscreen, LCD did you use. I've been looking into doing some thing like this, but can't really decide on an LCD.
  19. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Your case fan creates some nice subtle lighting especially with the slightly see-through blue acrlyic case panel, looks really nice.
  20. Stanmanfoo
    Stanmanfoo What's a Dremel?
    14 Sep 2003
    major props on this project: that is some hot action you've got there. The blue plexi is amazing with the lighting and the touchscreen is just icing on the cake. Bravo!
