Project: BlueXPC NIGHT PIC!!
Discussion in 'Project Logs' started by Jack, 9 Feb 2004.
  1. Jack
    Jack Minimodder
    22 Dec 2002
    Hi peeps! Here goes
    WHAT IM MODDING
    So to start, firstly lets begin with the system
    SN45G Shuttle XPC
    XP2800+
    2 x 512MB Corsair platinum XMS 3200
    40gig Maxtor Diamond Plus 7200rpm
    120gig Hitachi 7200rpm
    Saphire Radeon 9700pro
    Pioneer 105 dual dvd writer
    Slk800
    2 x Shuttle psu's
    INSPIRATION
    So why do this ppl think that the shuttle is already a nice case! Not me :) yes its nice, but it can be better MUCH better in fact.
    I stubbled accross http://213.221.104.186/pcmax/forum/forumdisplay.php?s=&forumid=85 !!! and was :jawdrop:
    I was very impressed by all mods but 1 for me stuck out the most and that was project by benny Digistation v2
    So this is where my project starts....well kind off, in a week :D
    jack
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
    pretty - is that perspex?
    you can set transparency in sketchup, would show how it'll look very well, and we'd love to see...
    edit: best pics (that I found) of...
    Benny's Digistation are here.
    AlexG's Aero: here.
    Bambi's Time Shuttle: here
  3. KONIJN
    KONIJN What's a Dremel?
    30 Nov 2003
    like the design hope its going to work out
  4. broots
    broots What's a Dremel?
    24 Sep 2003
    Your design looks very nice! :D I'm thinking about getting a shuttle myself soon..
    *subscribed*
  5. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    this is gonna look nice man
  6. [twig]clown
    [twig]clown What's a Dremel?
    1 Jan 2003
    Looks a very good design. The insides get cramped quickly (moddin' an XPC myself atm). The extra PSU will come in handy! What is the extra bottom section of the case for??
    Good luck :thumb:
    -cLoWn
  7. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    If you get any where the level of those mods it will be a really ace project :)
  8. Dimazz
    Dimazz What's a Dremel?
    8 Feb 2004
    Good luck, off to a nice start. Ive always wanted a shuttle, to poor though.
  9. hikke
    hikke What's a Dremel?
    11 Feb 2004
    Why don't you sleeve the usb and firewire(is there any?) cables too? Those ugly gray cables don't look so nice in middle of that nice blue cable mess ;)
  10. white modder
    white modder What's a Dremel?
    19 Sep 2003
    waiting to see some progress, looks a fine mod to me
  11. Jack
    Jack Minimodder
    22 Dec 2002
    Update 1
    Ok guys here is the first update for this log i hope you like it! :) and that it makes up for the loss of ClearLi
    Making it all fit
    So to begin, i was planning on putting watercooling into this shuttle but atm i really cant perhaps when the log is finnished i will draw my attention to watercooling! but for now im just gonna have to make do with a SLK800 in there :thumb:
    So here it is fitted in all its glory!
    ooppss we have a slight problem here dont we!
    So here's how i overcame the problem!
    firstly i marked the clearing distance!
    I also decided to get rid of the access from the sides,
    Next i got out my drill and followed the lines drilling holes out as i went:)
    Once i had done that i took away the not needed piece of the cage to leave a big mess!
    I quickly sort that problem out and after around 20mins had sanded away most of the sharp edge's
    Once that was done i tested to make sure things were going right
  12. Jack
    Jack Minimodder
    22 Dec 2002
    The fan grill
    Next inline was the grill at the back of the shuttle
    Nasty
    I quickly masked this area off and marked out where i was cutting
    I then cut out the area! and sanded again the sharp edges
    You may be thinking that the edge's seemed alittle ruff and not straight well TBH they are but i dont care im not gonna see them!
    So internally we have this so far im guessing that the DVDrom & HDD will be going forward alittle bit more once the front has been attached anyway pics
    And i leave the first update with a sneak at the next
    Cheers for looking
    JACK
  13. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Looking really good... this must be one of the older shuttles because all the new ones come with the heatpipe style coolers for the cpu... good job
  14. Jack
    Jack Minimodder
    22 Dec 2002
    :lol: thanks for reading my post bud
  15. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    looking good mate :thumb:
  16. DreamTheEndless
    DreamTheEndless Gravity hates Bacon
    27 Jan 2004
    This one did too - He's just not using it.
    I keep thinking about modding my shuttle too. Nothing extreme - just bigger ventilation holes, a little window and some lighting and - that new 250 watt 'silent' power supply and passively cooled radeon 9600 AIW.
    Looks good so far - keep it up
  17. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Passive 9600 AIW?
    Tell tell! :D
  18. [twig]clown
    1 Jan 2003
    Progress looks gd. Just one thing though, as your choosing not to use the supplied cooling solution. Why are you still using the rear fan mount? It is built with the room for the heatsink (of the supplier cooler) to run between the case and the fan, so without that there, you must just have a nice gaping hole between the fan the back of the case. Meaning less potential room inside the case too. Just a thought :S
    Nice work :clap:
    -cLoWn
    Edit: can see what im talking about in this pic
  19. DreamTheEndless
    27 Jan 2004
    Pretty new, but cheap!!
    128 mb ddr1
    cable tv in
    av in
    av out
    agp 8x
    max res 2048x1536@60hz
    tv tuner
    remote
    other stuff too
    http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-345&depa=0&section=1
    Is passivly cooled right now already, but since my shuttle doesn't have great airflow around the agp card, I would either make the ventilation better and/or slap a Zalman heatsink on it.
  20. MechWarrior
    MechWarrior What's a Dremel?
    13 Oct 2003
    The heatpipe system would have been just as effective as the cooling you have now, and quieter as it would have been just one fan. Justa FYI :)
