Electronics Project Boxes
Discussion in 'Modding' started by monkeyville, 13 Feb 2007.
  1. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    Hey all,
    I'm currently putting the cosmetic touches to a uni project but am really struggling to find a project box for all the electronics/user input console. Has anyone got any suggestions for shops/ebay sellers or other place i could get a nice project box?
    I have a few restrictions though:
    30cm Length x 15cm Width x ~15cm Depth (or 12inch x 6inch x 6inch)
    Must look good. Presentation is part of the project spec. No poor plastic.
    Cheapish. Max ~ £40 although cheap is good/better.
    Suggestions would be greatly appreciated as i'm all googled out with no great sucess.
  2. Macaba
    Macaba What's a Dremel?
    4 Mar 2006
    Rapid electronics don't appear to have anything large enough. I would suggest finding an engineering friend who will fabricate a box for you out of some nice wood for £20. :D
  3. monkeyville
    3 Aug 2003
    yes finding project boxes hasn't been too hard, it's just finding one thats big enough!
    Manufacturing one has crossed my mind however i don't think its possible to get the finish i want without spending lots of cash. It is also a lot easier to reclaim expenses on bought products so would prefer to go that route
  4. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    you could try Maplin (www.maplin.co.uk)
    I don't know if they have anything that size though.
  5. Javerh
    Javerh Topiary Golem
    5 Sep 2006
  6. monkeyville
    3 Aug 2003
    managed to find an aluminium case in local maplins (reduced as well) for £6. Is not as deep as i would have liked but for £6 you can't go wrong.
    cheers for the suggestions though guys
  7. Dreamslacker
    Dreamslacker Minimodder
    13 Sep 2006
    Have you tried Hammond Manufacturing? I typically use them for hi-fi projects.
