Case Mod - In Progress Project: Buddha's Palm -Sponsored by InWin
Discussion in 'Project Logs' started by TheGreatSatan, 24 Sep 2009.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    This project is Sponsored by In Win
    Here's the case that In Win mailed me. It's called the Matrix and is a lot smaller than most other cases I've worked with.
    I start once I get my paint!
  2. TheGreatSatan
    5 Aug 2005
    So here's the case
    And that's how big it is
    The side has a vent that comes off for easy cleaning. This one is staying off
    This is how the front opens
    The bottom has a bay for a card reader or something
    The back let's you guide all your cables through one slot at the bottom
    It can also be opened or removed
    At the bottom back are tabs
    You lift up the two tabs and pull out
    Then you remove the faceplate like any other case
    And only then can the side be taken off
    Here the case is standing on its back as I remove the 5.25 bay
    Then there's this plastic shroud. It's probably for the Processor air duct?
    And there's the inside
  3. Dragonphreak
    Dragonphreak Minimodder
    26 Oct 2005
    It seems like a well constructed case. I'm curious how you're going to incorporate the Buddha theme in. Painted panels?
  4. TheGreatSatan
    5 Aug 2005
    and other things
  5. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Way too hard to get into and too plastic-y for me.
    Will see how your work can transform this though. :thumb:
  6. gabriel_d7
    gabriel_d7 Budget Mod?
    21 Sep 2009
    Excited already... :D
  7. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    I don't like how you have to remove the faceplate to remove the side.
    Looking forward to further developments!
  8. TheGreatSatan
    5 Aug 2005
    Sorry for a such a HUGE gap in updates. I got to a point where I was sick of modding and really needed a vacation from it. Now that I'm rested, let's finish...
    I'll paint the left side once I cut out the mesh for the window
    I cut out most of the mesh, but I still need to get it cleaned up
    I made the right side sky blue
    I bought some bamboo!
    And cut them to around 6 inches. Each cut didn't have to be exact. I think varying heights will look more natural
    It took a couple of hours to get enough made to cover approximately 18 inches. My hand is killing me!
  9. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    hmm, bamboo computer. Interested to see where this is going haha
  10. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Bamboo...I think you need a panda in there. Bamboo+Panda=hWin
  11. TheGreatSatan
    5 Aug 2005
    I took the bamboo and added it to the side of the case
  12. TheGreatSatan
    5 Aug 2005
    I photocopied my own hand
    I then sent the image to www.CrazyPC.com who cleaned the image up
    And made me some UV Window etches
    I cut out a small piece of Plexi
    And I cleaned up the window
    Then I carefully applied the image to the glass
    The blue is the UV color on the inside of the glass
    Here is from the outside
    And backlit with UV
  13. TheGreatSatan
    5 Aug 2005
    I made the front bottom blue to match
    Then applied the glue and bamboo with the Chinese characters for HOPE
    Then I put the chinese charaters for PEACE on the left side
  14. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Nice looking case you got there buddy. Mini ITX?
  15. stonedsurd
    11 Mar 2009
    It's mATX. Link to manufacturer page in the first post.
  16. Cheapskate
    13 May 2007
    It's a really bizarre contrast between the bamboo and 2001-style case. I'm curious to see how this goes.:D
    I think it would be interesting to use the bamboo for grills. Leave the outside futuristic, but have the windows filled with 'boo.
  17. TheGreatSatan
    5 Aug 2005
    I put the case back together.
