Project Bulletproof Eclipse -Phoenix from the ashes:Project Resumed-
Discussion in 'Project Logs' started by Unicorn, 25 Jul 2006.
  1. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    Why not try stripping the annodization first, then paint it. It might make the paint stick easier, but i don tknow that much about annodization...
    I hope the paint isnt to scratchable, because that wouldnt be good later on down the road...
    Keep up the good work :)
  2. Unicorn
    25 Jul 2006
    Thanks, nope the paint isnt that scratchable... I think that paint is specially designed to be used on bare metal/ non primed areas... When I said it would scratch, I meant if you dropped it on a hard surface :) The second one is almost dry, and I will update with pics later on.
  3. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Nah its mostly Lian Li's.
    Like the mod, the window looks sweet with the red bolts in it. :thumb:
  4. Unicorn
    25 Jul 2006
    thank you :)
    I had a couple of ppl tell me they werent sure about it but thanks, I like it too
  5. Unicorn
    25 Jul 2006
    Hard Disk cooler Finished!!
    Well its been a long 2 days... Im just home from a 6 hour shift at work, and the paint was dry so I put the cooler back together. Lol waiting for paint to dry is soo boring :p . Here are some pics of the cooler all newly painted... The paint on the second al bar loks really neat!! I did it in loads of really light coats, so I think thats why.
    Note the holes where he broken heatpipe should be :blah:
    My brother is in a CSS match downstairs, and we share the 8Mb connection through a Router connected to the LAN in our house, so ill have to upload the rest later when he finishes :grr: He tells me im lagging him... pfff in my day you dealt with the lag and got on with it :hehe:
  6. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I would have recommended hacking the router and turning down the speed a few Mb/s
  7. Unicorn
    25 Jul 2006
    PSU Modding...
    Err not sure what you mean... elaborate please? thx :)
    Anywho, while I was waiting for the water cooling kit to come into stock in the UK, I had been fiddling with my PSU, which was bought along with the case months ago...In case youve forgotten, it was a 600W seasonic S12 model. Matte black, with the most stable voltage apparently. Its also immensely quiet (I put one in my brothers new PC at christmas, and you just cant hear it at all!) so it should go along with my "silent water cooled" theme. :lol:
    Didnt take a pic of it beforehand, so heres one 'borrowed' off the internet...
    As you can see, its just a messy beast with all those multicoloured wires. Not bad plugs though...
    Well it got sleeved bit by bit (boring bit of modding this, but worth it none the less) and I decided not to open the casing on this one to finish the sleeving inside. A few reasons for this: 1. Ive modded PSU's before, then theyve gone faulty and the manufacturer wont touch it cos the warranty is void.
    2. This thing cost me £102, and I dont want to break it :(
    3. I was solderin an LED fan into a PSU once, and one of the capacitors hadn't discharged, and it threw me against the back wall of my workshop. Since then ive been wary of them...
    This is as far as ive got with it... Will keep working on it a little at a time.
    Fitted the mounting plate...
  8. Unicorn
    25 Jul 2006
    OK thought I might as well put this in as well... The eclipse comes with 2 hard disk LED's, for 2 hard disks (duh lol). At the moment, I only know of server motherboards and raid setups that have dual HDD LED headers, so I will wire the two HDD LED's together to make both flash with the activity of my drive...
    I have changed them from the standard Blue, green, green (from top) to this, red white, green.
    What the bezel looks lie, for them...
    I intend on changing the bottom LED to white as well as the middle one. Something tells me they should all be red tho... comments and suggestions plz!
  9. scifi3018
    6 Feb 2005
    I personally dont think a power led is neccesary, as you prolly know when the computer is on :p
    I think that the green should def. go... Maybe 2 red leds, or just 2 white leds...
  10. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    Lookin good
    Man I wish my PC had more harddrive LED's.
  11. Unicorn
    25 Jul 2006
    Solar eclipse concept art
    OOkay then so I was at work last night and I have a colleague there who has a modified car, and he shares the same interest as I do in moddin things like PC's, cars etc... He was tellin me about this guy that does airbrushing up north from here, and I was thinking of making the 'bulletproof eclipse' Theme a little more appaernt on the case. If it doesnt cost tooo much, id like this guy to have a go at painting a red solar eclipse on the back panel of the case. Here are some attempts that I fiddled with last night in paintshop... Im not that good, so if anyone is a little better, additions and ideas would be welcome! What do people think? I need to know!!! :idea:
    This is the current PC set up in my room, (bit untidy atm with the camera dock on top etc) you can see that the whole opposite window side of the case is visible when its there, so I thought the new one should have a nice pic or painting on it maybe... Thats why I came up with this idea.
  12. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Of the three, I like the first one the best, looks good.
    Keep it up great work :thumb:
  13. Unicorn
    25 Jul 2006
    Hmm lol thats the one I like as well! Think im going up there tomorrow to price the airbrushing job... Its on the black anodised panel... again im not sure about this one. If painted over, the paint will be left with a pattern in it. I dont mint that, as the rest of the case will be the same, but I would be worried about the paint not wanting to stick to the anodised aluminium. Remember this is the outside of the case, and the finish would have to be matte to match the rest of the case. Anyone any thoughts on this?
  14. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    Its got a great cooling set up and when its completed its going to run like a dream. And the Akasa case is great for modding and PC building great choice for a case...
    Subscribed
  15. Unicorn
    25 Jul 2006
    Ah cheers m8, I really appreciate all positive comments I get on this mod... Keep following, much more to come! :thumb:
  16. hydro_electric_655
    13 Jul 2006
    Iono if you can hacka router and turn donw the speed but w/e. So nice job so far but did you really get thrown acros the room after shorting a cap with yourself.
  17. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    sand - Primer - Wetsand - Paint - Clearcoat. not so hard ;)
  18. Unicorn
    25 Jul 2006
    Yes!! Knocked me off my feet, and I hit the back wall of the workshop... My arm was numb for 30 mins, then the pain came and stayed for about an hour. It was one of those massive caps in an old PSU...
  19. Unicorn
    25 Jul 2006
    But this is anodisation, you cant sand that can you? and I dont want to ruin the rest of the panel, remember, this picture is only gonna go in the middle of the panel, I still want the rest of the anodisation around it to match the other case panels...If this guy im gonna get to do it is worth his salt, he'll know what to do anyway. Hes a pro airbrusher apparently...
  20. Noni
    Noni What's a Dremel?
    8 Dec 2005
    Maybe a round tinted window thats risen a little off the sidepanel and then a EL wire of red underneath to give out a little glow?
