Case Mod - In Progress Project: c-black (Migui 2)
Discussion in 'Project Logs' started by MIGUI, 15 Apr 2009.
  1. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Hello everybody.
    I'm new here and here another of my projects, this is a case Armorsuit Lian-li PC-P80 with water cooling and some pneumatic.
    The case has four moving parts.
    Sponsored by:
    SketchUp idea.
    Here some of the components.
    The Case.
    The compressor to 12VDC. Work up to a maximum pressure of 8 bar, to be quite small, is 11.5 cm wide, 13.7 cm high and 18.5 cm long
  2. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    this is going to become very interesting mod if i understand correctly you want to make something like a water cooled pc with air pressure:confused:
    and how loud is the compressor ?
  3. MIGUI
    27 Feb 2009
    Hello.
    No, take moving parts. The front, right side and upper part.
  4. MIGUI
    27 Feb 2009
    Hi, bought this switch and black with a red light 22mm diameter Cambiare what brings on the factory box, only instead of turning on the pc.
    I had to put the silicone thermal switch, as the hole to work the box is just 22mm in diameter equal to outer diameter of the switch, so it could not hold the nut that comes with, thank goodness it was not bigger.
  5. MIGUI
    27 Feb 2009
    Hello.
    I modified the rack of hdd Lian-li.
    1. I changed the fan 8cm by 7cm two.
    2. I have put a black plexi front.
    Idea.
    This is the rack.
    These are the fans 7cm.
    Now the job.
    Now the front.
    The final result.
    Regards.
  6. MIGUI
    27 Feb 2009
    I have prepared the piece of pneumatic control. This anger lareral left in the case.
    This is the gauge pressure used to.
    This is the flow regulators, i used six. Regular stops will be the speed of movement (fast or slow).
    A view of how it will be the pneumatic control.
  7. La carotte d l'o
    La carotte d l'o What's a Dremel?
    27 Nov 2007
    Looks interesting. I will follow this.:thumb:
  8. MIGUI
    27 Feb 2009
    Hello.
    Today, I finished painting the chassis, the color is matte black.
    This is the result.
    Has four layers of paint.
  9. MIGUI
    27 Feb 2009
    Hello.
    I put the compressor, the pressure switch, the valves 5/2 way and the power supply for compressor and the valves.
    The compressor.
    Now the assembly.
    This is the pressure switch.
    The assembly.
    These are the valves 5/2 way to 12v, uses four.
    Now the assembly.
    The first valve.
    The second valve.
    The thrid valve.
    The fourth valve.
    View all valves.
    This is the power supply for compressor and valves.
    It's fitted with the same screw valves.
  10. The boy 4rm oz
    10 Apr 2008
    This is looking very interesting, I will be keeping an eye on this.
  11. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    +1
  12. .Fatality.
    .Fatality. What's a Dremel?
    10 Jul 2008
    +2 :D
  13. MIGUI
    27 Feb 2009
    Hello.
    Well, now mounting the drain valve, sisx regulators and pressure gauge.
    The drain valve. This serves to empty the pneumatic circuit.
    Th assembly of the flow regulators.
    With pressure gauge. This makes the pressure from 0 to 1megapascals (0 to 10bares).
  14. The boy 4rm oz
    10 Apr 2008
    As I said before, looks very interesting. You obviously have a very good grasp on pneumatics cos I have no idea of what's going on lol.
  15. MIGUI
    27 Feb 2009
    Hello.
    Well, the case will have four moving parts.
    1. The support of the motherboard in dereho side.
    2. The top cover.
    3. Front door.
    4. The front of the case to rise 5cm.
  16. rakesh_sharma23
    rakesh_sharma23 Minimodder
    2 Sep 2007
    Hell i just cant understand compressure , valus.........?????? what's going on.....But seems like hell icefactory inside the cabinet........Intresting
  17. stonedsurd
    11 Mar 2009
    Ooooh, this looks mighty interesting.
    Subbed to keep a watch on :)
  18. MIGUI
    27 Feb 2009
  19. MIGUI
    27 Feb 2009
    Hi.
    Well, I mounted the exhaust valve.
    This is the exhaust valve, used to prevent overpressure.
    Now the assembly.
  20. The boy 4rm oz
    10 Apr 2008
    Looking very good my friend.
