Case Mod - In Progress Project: c-black (Migui 2)
Discussion in 'Project Logs' started by MIGUI, 15 Apr 2009.
  1. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Just Awesome!! :D
  2. RuSGaMeR
    RuSGaMeR No Pain No Gain...
    10 Sep 2009
    Damn dude...I can't even say nothing :D
  3. MIGUI
    MIGUI New Member
    27 Feb 2009
    Hey guys.
    Here is the video.
  4. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Cool stuff, original to say the least!
  5. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    very cool, but you don't want to do that while you are copying something to your hdd! lol
    ssd's wouldn't be a problem though :D
  6. MIGUI
    MIGUI New Member
    27 Feb 2009
    Hey guys.
    I already have who uses fittings for water cooling.:thumb:
    The bitspower fittings.
    I have also laid the pump with its built-in tank, for your assembly, have used these supports antivibration, these supports the rubber is flexible enough to avoid noise and vibration.
    The pump with your reservoir XSPC.
    The tube used is 10 to 13 mm black Primochill (Primoflex).
  7. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    This is getting better and better brother!!!! I like your attention to detail man!! Mod on! :)
  8. ulysses Cazuquel
    ulysses Cazuquel Sex, Casemod & Rock'N Roll!!!
    29 Apr 2006
    Even with many modifications made by you your project is still very well built and you keeping the look perfect. :rock:
    At the end of your project, you could put the total cost of your project.
  9. Teyber
    Teyber ******
    18 Mar 2007
    wow i love it, so its going to be hooked up to solenoid valves controlled by switches or the computer?
    are those gas struts, or a bellvelle washer or similar?
    cheers :rock:
  10. MIGUI
    MIGUI New Member
    27 Feb 2009
    Hi.:thumb:
    Teyber, the valves selenoid will be controlled by switches and pc.
    I mounted the other pump.
    The rubber support.
    The pump with reservoir.
  11. Botn3vik
    Botn3vik Mod it!
    16 Nov 2009
    crazy build, but i like it! :D
  12. Jediron
    Jediron New Member
    22 Jul 2008
    That's not a mod, that's a HOT ROD :thumb:
  13. MIGUI
    MIGUI New Member
    27 Feb 2009
    Hey guys. :thumb:
    More update here.
    The project has been sleeping for a while, but more progress here.
    I put the two pneumatic cylinders on a rod and then mount the case.
    Here mounted in the case.
    Cylinders subject to the frame with the rod 6 mm.
    The clips are subject to the cylinder rod that passes the radiator and fan, so it is very sturdy. :D
    With the lid raised.
    More photos.
    Here a sample video.
    Regards.:thumb:
    disturbed13 likes this.
  14. Bad_cancer
    7 Apr 2009
    Nice :thumb: good to see it starting again.
  15. stonedsurd
    11 Mar 2009
    That is soooooooo cool!
  16. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    QFT
  17. disturbed13
    disturbed13 New Member
    28 Nov 2008
    now that was awesome!!!!!!!!
  18. shakka65
    shakka65 New Member
    17 Jan 2010
    That's rad dude!
  19. Vaptor-x
    Vaptor-x Member
    28 Feb 2010
    Awesome mod :thumb:
    I was wondering, do you use noise dampers on your pneumatic switches?? I can hear a big thump when you activate the pneumatic system...
  20. The boy 4rm oz
    10 Apr 2008
    I absolutely LOVE this mod, so much goodness crammed into one case.
