Case Mod - In Progress Project: c-black (Migui 2)
Discussion in 'Project Logs' started by MIGUI, 15 Apr 2009.
  1. stonedsurd
    11 Mar 2009
    Dude, this is going to be a very impressive build. It's already looking great!
  2. ckool
    ckool What's a Dremel?
    6 May 2005
    I never post but for this build i have to say AWESOME!
  3. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Well, I mounted the filter for the pneumatic circuit.
    This is the filter.
    Now mounting.
    Thank you for continuing the project :thumb:
  4. stonedsurd
    11 Mar 2009
    If you don't mind me asking, what's the need for the filter?
    In case some particles get into the compressor and foul it up?
  5. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    The air compressed by the compressor has a certain amount of water in it (humidity in the air). As the air gets compressed, the water particles combine together into larger molecules, and eventually into droplets. If you don't remove the water from the pneumatic lines before it turns into droplets, the water particles can damage the pneumatic system. Oh, and it also helps keep out any other particles that are unwanted.
    I've never seen anything like this before. Awesome idea, and great work so far! Looking forward to more updates.
  6. MIGUI
    27 Feb 2009
    Hello.
    Its utility is as stated JaredC 01, serves to avoid drops of water due to moisture. Also maintains the circuit free of particles.
    All this for the proper functioning of the pneumatic system is advisable.
  7. stonedsurd
    11 Mar 2009
    Ah. Thanks for that. A little obvious, shouldn't have slipped me :duh:
  8. MIGUI
    27 Feb 2009
    Hello.
    I have assembled a lubricator for pneumatic systems. Served for the air cylinders are lubricated, and also the smooth operation of pneumatic systems in general.
    This is the lubricator pneumatic.
    Mounting.
    I have used this support tube.
    It is located on this site. So it will be easy to fill with oil.
    Now with the lubricator.
    Regards. :thumb:
  9. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    very nice mounting there mate looks very clean
  10. The boy 4rm oz
    10 Apr 2008
    This is going to be very unique once completed.
  11. MIGUI
    27 Feb 2009
    Thank you very much.
    I also hope that it is very good.
    I will follow soon with more progress :D
  12. Jelle46
    Jelle46 Belgium
    14 Feb 2009
    That's some nice pneumatic stuff you've putted in there, is it all by Norgren, they make real quality products, I followed a 3-day cursus with them, here in belgium.
    greets!!! good luck!!
  13. MIGUI
    27 Feb 2009
    Hello.
    He is absolutely right, nogren is a mark of good quality. It has a large stock of pneumatic components. :thumb:
  14. MIGUI
    27 Feb 2009
    Hi.
    I will use five of these cylinders, two for the side of the motherboard, two of the above, and one for the front door.
    The piston travel is 100mm and its diameter is 10mm.
    An overview of how the work is falling.
    Regards. :thumb:
  15. bagman
    bagman Minimodder
    18 Apr 2009
    you got some interesting stuff there which i have not thought of using, got some great ideas and i like the mod on the hd rack looks really good and professional. you can very easily tell you have modded before
  16. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    What gave him away? The "2" in the project title? :p
  17. MIGUI
    27 Feb 2009
    Hi.
    It is the second mod, but unfortunately not the first mod I have. Nor do I put on any website.
    This will be the first project to the public by the net.
    Regards. :D
  18. MIGUI
    27 Feb 2009
    Hi.
    Well, I have prepared a small grill to cover up.
    There will be a triple radiator, so take this grill.
    Idea.
    Now the work.
    Regards :)
  19. The boy 4rm oz
    10 Apr 2008
    That grill looks very nice. The black plexi and the silver mesh match each other perfectly.
  20. stonedsurd
    11 Mar 2009
    It appears in your Sketchup model that you have attached the pneumatic cylinder-thing to a fan. the plastic on the fan *might* not be able to take the load as the panel is opened/closed, so how about a shroud or something so that load is more evenly distributed?
