Modding Project Canada
Discussion in 'Modding' started by timothyw9, 16 Mar 2006.
Thread Status:
Not open for further replies.
  1. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    yay! do we get mature posting after that? :p
    if you can, try and get as many of your components red n white...some mobo's are "strawberries & cream" eg: white board, red everything else. would go well with your theme :)
  2. SAS91
    SAS91 What's a Dremel?
    22 May 2005
    The only board currently red and white is produced by sapphire, the boards are pretty unstable, expensive and have a lot of options that would scare the crap out of a beginner. This kid needs to get his mits on an Asus A8V, a cheap 939 chip (sempron?) some cheap ram (£60 lowest on web(hynix)) and then build from there. Salavge disk drives from your old pcs as i did and then the only thing he will then need to worry about is a PSU and the modding task he has made for himself.
  3. timothyw9
    timothyw9 Banned
    26 Feb 2006
    have you even read the thread?????? already have a motherboard --?????????? and i am on a budget
  4. GuardianStorm
    26 Apr 2005
    sorry, i was just using the mobo as an example...im sure ive seen a similar Graphics card tho
  5. Guest-16
    Guest-16 Guest
    http://www.bit-tech.net/hardware/2005/11/24/sapphire_pi-a9rx480/7.html
    The Sapphire worked for me, but they are expensive.
    Semprons dont come in 939.
  6. SAS91
    22 May 2005
    I have one of the sapphires, guess we have had different experiances with it ;) I hate mine and would happily smash it over a member of sapphires staff head. And about the sapphire, didnt realise :) woops.
    And timothy, whats with the aggression? i was only giving you ideas...
  7. Guest-16
    Guest-16 Guest
    I seriously must get great ATI boards cause I rarely have problems with them but everyone else seems to hate them.
  8. timothyw9
    timothyw9 Banned
    26 Feb 2006
    can we please get back on form in this thread
  9. Kaboom22
    Kaboom22 Minimodder
    8 Sep 2005
    My first comptuer was made from discarded components from our family computer and parts from a car boot sale. It sucked, but at the tiem i thought it was great. Good luck, you seem to be off to a fair start.
  10. timothyw9
    timothyw9 Banned
    26 Feb 2006
    as i've just decided to give up the centurion 530 i am looking for a decent cASe for under £40
  11. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    That centurion is still one of the best cases you can get with your budget. There's also the Antec Super LanBoy for a little more.
  12. timothyw9
    timothyw9 Banned
    26 Feb 2006
    all i have to do now is wait from a reply by eclipse computers.
    waits
  13. Guest-16
    Guest-16 Guest
    Just dont use a case. Stick it on your desktop and have it running out. That way you can save money for the time being.
  14. timothyw9
    timothyw9 Banned
    26 Feb 2006
    and how exactly wuld i prevent it from static?
  15. mattthegamer463
    26 Nov 2004
    I wouldn't leave it lying out on a desk. That would not be very safe as a long term solution. I would see if you can bum a old ATX PC from a neighbor or something and use that case as long as its a ATX formfactor.
  16. hitman012
    hitman012 Minimodder
    6 May 2005
    Well, you don't touch it...
    I've run PCs on desks before for many weeks without issue. As long as you're careful not to spill drinks on it or slide on carpets before moving the thing, you won't cause any damage.
  17. GuardianStorm
    26 Apr 2005
    my friends first pc was duck taped to the wall... it worked well enough....took alot of duck tape tho :p
  18. mattthegamer463
    26 Nov 2004
    lol, that would be a sight. Yet another use for duct tape. Red Green would be proud.
  19. GuardianStorm
    26 Apr 2005
    its Duck Tape btw :p
    another solution for a case would be a few old CD racks or DVD racks...you could use the groves to support components
  20. mattthegamer463
    26 Nov 2004
    O RLY?
    http://www.ducktapeclub.com/
    "Duck tape club, adventures with Duck Tape brand DUCT TAPE"
    Its tape for ducts and ducting, not tape for ducks. I guess that because a company called Duck makes the tape, it becomes part of the name, like "kinder surprise" or "kraft dinner" Although whatever you call it, its still just the best tape in the world.
    EDIT: found this The answer
Thread Status:
