Scratch Build – Complete ⭐ Project Car - Complete Oct 9
Discussion in 'Project Logs' started by Paslis, 25 Feb 2018.
  1. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 9.
    Time to do some hood work.First i cut all the pieces i needed and drilled some holes and used some rivetnuts a little bit of welding and then the hinges were finished.
    The hinges are finished so then i made the top for the hood .
    The hood is far from finished but this is how it looks so far.
    More to come. :)
  2. Guest-56605
    Guest-56605 Guest
    You truly are a metalworking artist Pascal :cool: :cool: :cool:
    Any idea how much the completed desk (car) will weigh in at?
    Paslis likes this.
  3. Cheapskate
    13 May 2007
    ^Look at this guy calculating shipping costs on the sly. :hehe:
    I only saw 1 rim. I suspect it will be cut in half and used as a wall mount.
    Paslis and Guest-56605 like this.
  4. Guest-56605
    Guest-56605 Guest
    :hehe: If only @Cheapskate :sigh:
    It would be THE CENTREPIECE of any man cave to be fair :thumb:
    Paslis likes this.
  5. Yaka
    Yaka Modder
    26 Jun 2005
    man awesome build keep the pics coming
    Paslis likes this.
  6. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks a lot man. :D To be honest i have no idea yett.
    Haha your right about that Cheapskate the rim wil be cut in half.:D
    Haha thanks a lot again. :D
    Thanks a lot and pics wil come. :D
  7. Vault-Tec
    30 Aug 2015
    Beautifully done. Soo clean.
    Paslis likes this.
  8. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks a lot Vault-Tec. :D
  9. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 10.
    Its time to do some work again.First i cutt the pieces i needed and started with the mobotray.
    Thats finished but i had the feeling there was missing something so i made the pieces that were missing imo.
    Im happy with the end result and this is how it looks.
    More to come. :)
    cobalt6700 and Cheapskate like this.
  10. Cheapskate
    13 May 2007
    Behind the scenes at the EU Back to the Future remake...
    cobalt6700, Paslis and Defyant Mods like this.
  11. Paslis
    Paslis Minimodder
    13 Jun 2011
    Hahahaha :grin::grin::grin::grin:
  12. Paslis
    Paslis Minimodder
    13 Jun 2011
    A small update this time.
    It was freaking hot here and stil is so i did a small amount of work.
    This time i did some work on the wheel and tire.
    First i did some measurements.
    Then i cut the wheel in half.
    The same thing i did with the tire and this is what ik looks like.
    Then i start working on the mounts for the half wheels.
    Then it was to hot to continue so more this saturday. :)
    Guest-56605 and _Prometheus_ like this.
  13. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 11.
    Its been a long time sinds i update the project but here it is.
    Making the wall mount and painting all parts.
    The frame fits so now on with the brackets for the wheels.
    Time to paint all parts
    Taking the parts home and then its time to finish the project. :)
  14. Guest-56605
    Guest-56605 Guest
    I can't wait to see this in it's final form...
    Truly it's killing me to see it!!!
    Paslis likes this.
  15. Cheapskate
    13 May 2007
    He's back!
    -and he's gone again. :lol:
    Paslis likes this.
  16. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 12.
    Its time to put the parts together and here i go.
    Almost finished. :)
    _Prometheus_ and Cheapskate like this.
  17. Cheapskate
    13 May 2007
    A stock reservoir? I guess you maxed out your whimsy making it car-shaped. :lol:
    The two fans against the wall... Wife won't let you mod the drywall?
    Paslis likes this.
  18. Paslis
    Paslis Minimodder
    13 Jun 2011
    Yes a stock reservoir and imo it looks nice. :D
    Nope the wife didnt agree modding the wall. :lol:
  19. kim
    kim hardware addict
    10 Jan 2016
    :wallbash: pure madness :grin:
    Paslis likes this.
  20. _Prometheus_
    _Prometheus_ Minimodder
    2 Jul 2017
    Yeahhhhh!!!!:clap:
    Paslis likes this.
