Case Mod - In Progress Project: Car pc.
Discussion in 'Project Logs' started by Angel OD, 2 Nov 2007.
  1. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Okay, here goes... Was asked to do a worklog of this so..
    I decided that I was tired of the normal Dvd/tft sollution for the car, so I decided to take it a step further! :D
    Why not put a complete pc in the car? Ofcourse it's been done before, but that doesn't make it any less cool in my mind!
    I actually started to find stuff on ebay about a year ago, as I've already stated in my "Angel Inside" log, I have too many projects running simultaniously, so things happen to each project when I feel like it... This project however, came to a halt since I could not find a special cable which connects the PSU to the pc... It was actually non-existant... But through a lot of hard work, I've found it! :lol: I'm getting a mail about it next week, and get it home from the states... And then I just need to order the last cables in Germany, and then I'm up and running! :)
    The project:
    Xenarc case
    2 Ghz P4 Cpu
    512 Mb low-profile memory (19mm high...) And I might order another 512 mb when I buy the cable, since the shipment itself for the cable is about $40....
    80 Gig harddrive
    DVD rw drive from a laptop
    Bluetooth dongle (Which takes over my cellphone, when I start the car! :rock: )
    Wireless internet (My new internet provider actually includes hotspots around Copenhagen! :) )
    SIFR III gps receiver
    7" fully motorized touch widescreen
    Also I might fit the OBD2 cable I have from the car to my computer, so you can monitor the engine and such!
    A lot of software to make life easier on a touchscreen! :)
    The stereo itself consists of:
    A Kenwood amp, 2 x 95 watts, bridged to handle my new Earthquake Shallow 12" Subwoofer :jawdrop:
    A noname amp to power 2 pcs of 6x9" Kenwood rear speakers, and a complete set of 4 speakers in front...
    Pyle 7 channel equalizer for taking care of the sound!
    But pics... Sry about the quality, it was taken with cellphone... :wallbash:
    The first pieces arrived form the States:
    WIthout the case:
    Assembled: Can you belive this is a complete pc? :jawdrop:
    The Touchscreen:
    Notice the battery on the floor... This weighs.. I dunno, but it's crazy heavy! I don't know what it's called in english, but it's actually a battery you can have inside the car... The direct translation from Danish would be a "Dry Battery"?
    More pics will follow asap! :)
  2. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Very cool indeed :rock: Looking forward to seeing the pc installed in the car. What head unit are you using there?
  3. widmod
    widmod Minimodder
    9 Oct 2006
    thank you for posting i just love car pc projects :eeek:
    which car do you have?
    which motherboard do you use?
    what is so special with your PSU that you ned a certain cable?
  4. Cheapskate
    13 May 2007
    Nice. Roads here are so rough I wouldn't even think to try this.
  5. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    can't wait to see more pics..
    Looks interesting..
  6. Qhs
    Qhs µ modder
    24 Sep 2007
    Hmm PC in a car... Planning to run plates? lol jk. Interesting ill keep my eye on this.
  7. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    how much power does the battery provide?
  8. mirciu
    mirciu What's a Dremel?
    7 Jan 2007
    are you using a Opus power supply? cuz, y'r gonna need some protection during crancking. and normally the battery gives 13.4-9 Volts (if i'm not mistaken)
  9. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    The battery on start up can give much more than that. Some extreme batteries will do 18+ volts on ignition. There is a lot of surging going on in cars which is why it is best to either run the pc through a power adapter or have an inline fuse. I'd choose inline fuse since it's cheaper, smaller, and easily replaceable if you put it in a accessible location. Of course fuses rarely catch the voltage before it's blown up the hardware ; P
  10. Angel OD
    16 Sep 2007
    MVAgusta<<-- The headunit is actually a cheap one from Ebay (Around 350$ if memory serves...) Can't remember the name though..
    widmod<<-- My car is a '00 Volvo S40 1.8 , And before anyone starts to laugh, pls remember that cars in Denmark are; American prices + 180%... :wallbash:
    I have NO idea what the motherboard is, other than it's an intel 915 chipset...
    The thing about the cable is not caused by the PSU, but actually by the Xenarc itself. There is a "normal" input for 12 V, as on a laptop,
    but also a remote start cable, in the form of a mini-jack, and I have no idea what is ground/ + In that one...
    Cable:
    PSU is a Carnetix P1290:
    Actually...
    1. The carnetix is made to survive engine cranks... It will keep the computer running as low as 7 volts during crank, while fully loaded (90 Watts)
    2. When you crank the engine, it draws all the power... Doesn't throw it back at you... (This is also why your stereo will die, and start up again when you start the engine... The starter engine will draw an enormous amount of amps from the battery, up to over 500....
  11. Fozzy
    25 Jan 2005
    yup good to know. It's too bad you spent 40 bux on that cable. If you would have cracked open the PSU, 9 times out of ten Black or Brown will be ground and green/Red is hot or +. Also the remote start line generates an EXTREMELY small amount of power. So you had no risk really anyways. Why are cars so expensive there?
  12. Angel OD
    16 Sep 2007
    Actually... I didn't get around to buy the cable yet... Brought the carpc home from work today, (Making a bracket for it, got the measurements, so I don't need it for that anymore) and I'm gonna open it up again to see if I can figure out the ground and + of the remote... The original 12V line input I can meassure from my 230 -> 12v PSU! :)
    Cars are that expensive because... Uhm.. Mostly it's because the taxes we pay for cars, are going into many other things... We don't have to pay for insurance to go to the hospital and such.. If you get sick, need an operation or other things like that, it's all free! Dentists, and breast enlargements are not free though! *LOL*
    This thread didn't go much further. I put the pc in the car and had it in there for about 4 years. Then I decided to watercool it, and go a completely different way.
    The thread for the WaterCooled CarPC:
    http://forums.bit-tech.net/showthread.php?t=207889
