Scratch Build - In Progress ⭐ Project Car - Update 10 May 12
Discussion in 'Project Logs' started by Paslis, 25 Feb 2018.
  1. Paslis
    Paslis Active Member
    13 Jun 2011
    Update 9.
    Time to do some hood work.First i cut all the pieces i needed and drilled some holes and used some rivetnuts a little bit of welding and then the hinges were finished.
    The hinges are finished so then i made the top for the hood .
    The hood is far from finished but this is how it looks so far.
    More to come. :)
  2. 23RO_UK
    23RO_UK Hasta Mañana
    4 May 2010
    You truly are a metalworking artist Pascal :cool: :cool: :cool:
    Any idea how much the completed desk (car) will weigh in at?
    Paslis likes this.
  3. Cheapskate
    13 May 2007
    ^Look at this guy calculating shipping costs on the sly. :hehe:
    I only saw 1 rim. I suspect it will be cut in half and used as a wall mount.
    Paslis and 23RO_UK like this.
  4. 23RO_UK
    4 May 2010
    :hehe: If only @Cheapskate :sigh:
    It would be THE CENTREPIECE of any man cave to be fair :thumb:
    Paslis likes this.
  5. Yaka
    Yaka Well-Known Member
    26 Jun 2005
    man awesome build keep the pics coming
    Paslis likes this.
  6. Paslis
    13 Jun 2011
    Thanks a lot man. :D To be honest i have no idea yett.
    Haha your right about that Cheapskate the rim wil be cut in half.:D
    Haha thanks a lot again. :D
    Thanks a lot and pics wil come. :D
  7. Vault-Tec
    30 Aug 2015
    Beautifully done. Soo clean.
    Paslis likes this.
  8. Paslis
    13 Jun 2011
    Thanks a lot Vault-Tec. :D
  9. Paslis
    13 Jun 2011
    Update 10.
    Its time to do some work again.First i cutt the pieces i needed and started with the mobotray.
    Thats finished but i had the feeling there was missing something so i made the pieces that were missing imo.
    Im happy with the end result and this is how it looks.
    More to come. :)
    cobalt6700 and Cheapskate like this.
  10. Cheapskate
    13 May 2007
    Behind the scenes at the EU Back to the Future remake...
  11. Paslis
    13 Jun 2011
    Hahahaha :grin::grin::grin::grin:
