Case Mod - In Progress Project: carbon-fever! - 12.july - carbon-fever goes print!-
Discussion in 'Project Logs' started by derbaum, 7 Jan 2007.
  1. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    @ c-king: yes it´s a remote controll. keeps the case clean and helps lazy fellows to stay lazy ^^. no unnecessary movement.
    @tech-dann : thx and we´ll see at the end of the year.
  2. Xlixen
    Xlixen What's a Dremel?
    16 Apr 2007
    Wow, It really looks good. Great Work.
  3. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    NICE!! Damn that is one slick pice of work!
  4. Colossous
    Colossous Minimodder
    28 May 2007
    Absolutely amazing !! :jawdrop:
  5. widmod
    widmod Minimodder
    9 Oct 2006
    a really great case, but please sleeve the power cabels they destroy the smooth look of the case :naughty:
  6. derbaum
    11 Apr 2004
    @ wid. on my next psu i´ll do that for sure. hopefully i get one soon.
  7. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Beautiful work on the case :thumb: I esp like the clean interior!
  8. Mr. Oizo
    Mr. Oizo That yellow furry animal-thingy
    18 Mar 2007
    Nice case! Looks stylish. Good job!:D
  9. Claas M
    Claas M What's a Dremel?
    29 Jan 2006
    Hav I overread it? Is the 'cap' (with the yellow stripes) a remote control?
  10. derbaum
    11 Apr 2004
    the striped cap is part of the remote control, it covers the pwr button.
  11. fri2219
    fri2219 What's a Dremel?
    26 May 2007
    About the hard-drive
    Two things I couldn't figure out from reading your log:
    1) How do you keep hard drive seeks from reverberating like a drum?
    2) How do you transfer heat away from it?
    Thank you for sharing your work!
  12. Claas M
    29 Jan 2006
    @Baum: I firstly thought: why the heck he calls it finished when the top isn't mounted :D
  13. derbaum
    11 Apr 2004
    @ fri: rubberpads are glued to all styrene sheets. that kills most of the vibrations, you can only hear them when it´s quiet my room.
    the harddrvs run in a cage of 5mm alu bars and are cooled with a 92mm fan running @5v most of the time. hd tune says 32° C, i think that´s ok.
  14. Burned_Alive
    Burned_Alive What's a Dremel?
    15 Dec 2002
    Shame these arent available to buy commercially, id buy one.
  15. nazomcg
    nazomcg Minimodder
    4 Aug 2006
    The case looks absolutely fantastic, if only it had hardware of equal stature. Surely a mod a great as this should be able to get some serious sponsorship.
  16. derbaum
    11 Apr 2004
    @ burned: this case would be quite expensive even when produced in series. expensive means the 500-1000€ per case region.
    @ naz. no sponsorship yet. maybe i have to go to a exibition or a contest first before i can get in contact with the industrie.
  17. Xlixen
    16 Apr 2007
    The case is absolutely beautiful.
  18. derbaum
    11 Apr 2004
    ok i have one more (update). i had some time over the last weekends to add some cf to my keyboard and mouse. now everything is fitting the style of the case.
  19. ComputerKing
    8 Sep 2006
    WOWOWOW that mouse and Keyboard look Kickass now
  20. derbaum
    11 Apr 2004
    thx. add some cf to them really burned under my nails.
