Case Mod - In Progress Project: carbon-fever! - 12.july - carbon-fever goes print!-
Discussion in 'Project Logs' started by derbaum, 7 Jan 2007.
  1. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    thx for the stars ..you cant have enough of them ^^
    building everything from aluminium is one of my wettest dreams but there are some points standing against this.
    1. price: the whole case was planned as a low cost project. i first thought of less then 100€ for everything. aluminium is very expensive atm, i simply can´t afford it ( damn chinese guys ;) ) . the wooden parts are mostly made from stuff i found .
    2. weight. the case should be lightwight. i dont know the exakt weight but it´s definitly less then 10kg. if i would use 10mm alu sheets it would be pretty heavy
    3. workin with wood is a lot more easy. most of the tools my dad bought are for woodworking. neither having a mill or laser/watercut machine, nor knowing anybody who does and would do me a favour. ( there are compans in my town who own such machines but if i would cut it there we are back at point1 ). cutting everything by hand would be horrible.
    4.time: i want to be done till april and there is not enough time to redo anything. sidepanels will be a lot of work and of course wiring and lighting everything up.
  2. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    I have to admit this is very slick. I didn't think you could fab CF by hand either... but obviously you can. Keep up the godo work.
  3. ctrl_alt_del
    ctrl_alt_del What's a Dremel?
    25 Feb 2005
    The carbon fiber look is just incredible - great work!
  4. V3ase
    V3ase What's a Dremel?
    25 Jan 2007
    Really intresting , ask for EA (NFS:Carbon) sponsoring :p
  5. derbaum
    11 Apr 2004
    never thought of that ..but ...great idea ^^
  6. ogewa
    ogewa What's a Dremel?
    16 Aug 2006
    nice work looks to be a awesome mod cant wait to see the finished product.
  7. mashie
    mashie The one and only
    15 Mar 2002
    Nice to see some more CF based mods being built again. This one look really spectacular.
    If you had seen my CF guide you would have known about the tape on edge trick for the weave. I built two CF mods a few years ago (here and here) and I love the material.
    Good luck with this project, the end result will be very interesting to see.
  8. Evenge
    Evenge Minimodder
    16 Sep 2006
    CF looks better and better! Nice! :D
    Keep up the good work!
  9. derbaum
    11 Apr 2004
    @ mash thx. i read your worklogs long ago. now i´am biting my ass for not looking at them again when i was old enough to play with the big toys ( cf for example ^^)
  10. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Congrats on the front page. You have a very cool project underway! Can't wait to see more.
  11. SlappKnutts
    SlappKnutts What's a Dremel?
    28 Jan 2007
    That carbon fiber looks awesome! I project after my own heart! I had thought about doing a fiberglass case for a few months now, I'm in the business so to speak. But man that carbon fiber is just sh&t hot!
  12. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    Amazing work derbaum. 5 stars from me. :thumb:
  13. tkdwarrior
    tkdwarrior What's a Dremel?
    5 Jul 2006
    nice work so far. should be interesting to see how it goes.
    tip: if you want, you should look at the new style of recessed bonnet pins. pretty cool, hot stuff for imports right now. might be something you'd like. just google them.
  14. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    nice working, and you give me some ideas on how to bend and work with styrene, tnx a lot!
  15. derbaum
    11 Apr 2004
    maybe some of you are already waiting for it ..here it is: THE UPDATE.
    i have to confess it´s just a short one. more in the next days.
    the cover for my dvd drv will be glued to this alu-sheet
    the spine at the cover is made of plexiglas. light from leds will be reflected on the transversal faces. on half is for the hdd the other for the pwr led. the parts are divided by a thin layer of alu-foil
    in the end it will look very similar to this.
    the finished spine.
    and the backside.
  16. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    sweet! carbon fever does not sum this project up! whats greater then a fever...?
    (Click of a suscribe button)
  17. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    What a kind of precise man at work... I must use your same idea for the led , it's a cool touch to a case that I'm working on... tnx for the idea...
  18. Claas M
    Claas M What's a Dremel?
    29 Jan 2006
    hm... You have started the first things a few monts ago, not? It seems to be a cool mod
  19. derbaum
    11 Apr 2004
    i work on this mod for over a year now. only the worklog started on january
  20. Kurayamino
    Kurayamino As long as the Raven flies
    5 Sep 2005
    a razmataz, a carbon razmataz
