Case Mod - In Progress Project: carbon-fever! - 12.july - carbon-fever goes print!-
Discussion in 'Project Logs' started by derbaum, 7 Jan 2007.
  1. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    that is a REALLY bright LED! the subtle white light is my favorite style of case lighting.
  2. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    OMG! I was wandering about how many light a single led can be able to create, and the answer is : a lot! It's really strange to have a copper heat spreader for a led , but, wow, it's a really cool led! You gave me a nice idea...
    Tnx a lot!
  3. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    the copper heat spreader is really overkill. if you dont need temps near roomtemp you can use a much smaller one. the lumiled i used is out of the 1. generation of high power leds. it has just 20lm . newer models deliver up to 240lm (seoul z-led).
  4. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    lm is lumen for those who don't know...
    Looking nice!
  5. derbaum
    11 Apr 2004
    remember kids ...think first before cutting. the plexisheet became a bit too strait so i had to add a whole bunch of leds to get a even look.
    the lighting on the top of the case got quite tight too.
    at least the slot-illumination offered a bit more space.
  6. derbaum
    11 Apr 2004
    wired up n1 and clean.
    the frontpanel will be a major role for my light and fanstuff. nearly everything is connected to it.
    big fans are running 2.
    the tray is also nearly finished.
  7. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    As usual great work derbaum. I thought you had forgotten about this project as I hadn't seen any updates for a while.
  8. derbaum
    11 Apr 2004
    like an elephant i forget nothing but iam moving very very slowly ^^
  9. derbaum
    11 Apr 2004
    ummm let´s start with a little teasin
    the bolts for the sidepanel are sanded and polished.
    the case itself is now nearly finished, but the remote controll is not more then a concept.
    diameter 48mm , strength 10mm , aluminium. one of the few parts i didnt made myself.
    2 potentiometers are attached to the wheel. one for the fans on the top, the other one helps to vizualize the speed of the fans. more on that later.
    to visualize i need a bargraph or something similar. buying one was an option but no solution.
    i decided to build my own from small plexisheets and some unused smd leds.
    dont forget aluminium foil.
    see ya soon on part 2
  10. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    :eeek: Nice work.
  11. ComputerKing
    8 Sep 2006
    NICE !!! OMG this is crazy
    keep it up !!
  12. myriad
    myriad What's a Dremel?
    26 Apr 2007
    mmmmm looks good
    Ya, that was meant to sound creapy :D
  13. ssR
    ssR Carbon God
    11 Aug 2006
    hey man I'm not quite sure where you're going with this but you haven't disappointed me so far so I'll trust your senses :D
    keep it up!
  14. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    if you guys think 1 watts leds is extreme, how about a 5 watts. white led :eeek:
    5 watts white led.
    Oh btw. Damn nice casemodding. :thumb:
  15. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    I've lost the necessary word .. It's a BIG idea to hide the potentiometer behind the alu disc, but the fantastic idea is the bargraph using smd led!!!
  16. derbaum
    11 Apr 2004
    @ ssr ... i need to keep my little secrets but they will be revealed soon. (maybe have a look at older pix. i have a (beta) sketchup render of the rc frontpanel.
    @ tt modder .. keep your eyes on this.
    http://www.dotlight.de/shop/product_info.php/cPath/296_292/products_id/909
    just 3W but 240lm . i am tempted to buy one of them just to see how bright 240lm are.
    @ rig ... thx
    @ all. thx for posting.
  17. thermalnightmare47
    thermalnightmare47 What's a Dremel?
    18 Sep 2006
    awesome work so far just found it and all i have to say is you have some massive modding skilz..lol anyway keep up the excellent work...puts me to shame
  18. derbaum
    11 Apr 2004
    today we start with some bondo.
    while the bondo was drying i made the first modul. this one will carry 4 switches and a Ir diode.
    and the scond modul. pwr switch and a bargraph on this side.
    this button fits under the yellow striped cap. it´s made of a 5mm plexiglassheet
    i´ve had some time to paint the first pieces, too.
    modules done. the next step is to build the housing for them ( they are already standing on the parts of teh future case) and testing the bargraph.
  19. Bas van der Werff
    Bas van der Werff What's a Dremel?
    18 Feb 2007
    Looking sweet :thumb:
  20. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    The look is fantastic, I wish I have 10% of your skills...
    I would like to see the bargraph in action, I'm so curious!
