Scratch Build – In Progress Project: caseart - ca01 goes "FIRE & EARTH" | (update #2 > 02.22.2010)
Discussion in 'Project Logs' started by caseArt, 4 Feb 2010.
  1. caseArt
    caseArt iam from Austria ;)
    4 Feb 2010
    Hello :eyebrow:
    I would like to introduce you my Case-Con!
    created from mdf/wood, equipped with new innovative ideas
    about me:
    - I am wolfgang
    - 28 years from Graz / Austria / Europe / World
    - 2 children: 2.5 years son / daughter 0.5 years
    - Nick: "caseArt" -> mod = art
    - I create some mods in Austria
    - My case was in a gaming magazine
    - 2005 .. on the cebit (ECG) etc.
    - I never use 3d models.
    I want to inspire people with HANDMADE :dremel: and "WHAT" NEW!
    the case:
    to my plan:
    >>>>>>>>>>>>>>>>>>>>>> "TADAAAAAAAAAA"
    I give my case the name:
    >>>>>>>>>>>>>>>>>>>>>> "FIRE & EARTH"!
    paint bla / bla ...
    1.) in the upper area, I create a "plant - areal" YES for ordinary plants (like flowers...)!
    2.) on the open (left) side, I will mount between 2 fire-resistant safety glass
    -> 3x an oil lamp!
    I would like to show you a lamp, that you can take a picture!
    Hardware:
    i will update later....
    > please < excuse my bad English! write slow and loud ;)
    a special thanks to:
    powered by Noctua: www.noctua.at
    start with my logo "CA"
    a piece of aluminum
    taped
    logo painted
    proxon out... and action!
    after sawing
    grind
    key file
  2. Guest-16
    Guest-16 Guest
    No pics = moved to modding. :)
  3. caseArt
    4 Feb 2010
    oh sorry, here they are
    then continues with the logo (ca):
    to brush the aluminum, I need a sanding block + implementation
    shear + 320 sandpaper
    The finished sanding block from the side
    I have quickly finalized the implementation
    I stuck my logo with double-sided tape
    brushing from the top
    action!
    ready :)
  4. Validus
    Validus New Member
    25 Aug 2009
    Nice logo design.
  5. caseArt
    4 Feb 2010
    thank you :)
  6. caseArt
    4 Feb 2010
    to the case:
    material:
    connecting plates, drilling holes ...
    screw together...
    connected... :) (the upper part)
    The screws were sunk to trowel it
    completely assembled ...
    view from above:)
    1.)# Live modding:
    you need more pictures? please ask for it
    mfg
    caseArt
  7. shakka65
    shakka65 New Member
    17 Jan 2010
    Welcome to Bittech and great start on your mod. The logo turned out really nice. I can't wait to see how your mod will turn out.
  8. caseArt
    4 Feb 2010
    @ shakka65: thank you :)
    my little daughter: 6 months old! [/ B]
    <3
    I bought 2 spruce afford 20x20x2000 (mm). This had to be cut to length, I use my jigsaw with a selfmade SAW TABLE (+ ROLL TABLE)
    material: hinges, wood usw...
    I screwed the hinges to the board (must be very accurate)
    the roll table
    ready :) :D
    Now I had to customize the jigsaw
    fits!, almost 4 holes in the sleigh, i attached the jigsaw with the table
    cut to length,
    finished, works perfectly:)
    ok, it is very sick :D
    but it works!
    (my circular saw is broken :( )
  9. caseArt
    4 Feb 2010
    spruce afford're done, screw it now
    proforma arranged (not ready)
    I marked where I will attach the mounting angle
    clamped a aluminum sawblade and I cut out of alu-profiles the mounting angles
    finished
    i had to dowel
    6mm dowel pins, drill, etc...
    ready!
    uuuf,... it fits :)
    back to the mounting angles, marked, and also just drilled!
    assembling...
    i assembled the afford in a ditstance of 7mm
    Alright fits: D
    image from the front
    from the side
    puh,... I hope you like it
  10. caseArt
    4 Feb 2010
    to my plan:
    >>>>>>>>>>>>>>>>>>>>>> "TADAAAAAAAAAA"
    >>>>>>>>>>>>>>>>>>>>>> "FIRE & EARTH"!
    paint bla / bla ...
    1.) in the upper area, I create a "plants - areal" YES for ordinary plants (like flowers...)!
    -> 3x an oil lamp!
  11. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Wow, very nice
    especially mixing computers and FIRE!!!!!!!!!!!!! :rock:
  12. Jipa
    5 Feb 2004
    Computers and fire is cool, but I'm a bit worried of wood and fire.. :D
    Good work there, but seriously I'll have my doubts about the fire until I see you pull it off without burning your house down :)
  13. caseArt
    4 Feb 2010
    @ the_beast: yes !!!! fire :D
    @ jipa: thanks, i hope i dont look like him: http://boba.files.wordpress.com/2008/09/burning_man.jpg
    I think I will use "bio-ethanol", lamp oil is a "dirty" solution (soot development)
    My experiences:
    FUEL PASTE:
    - Not realy for inside using
    - Smells...
    - Ugly "flare"
    + Flexible
    + Cheap
    + Can be ignited from the cup dirket
    Lamp Oil:
    - Smells
    - Smokes
    - soot...
    - Insecure
    + Cheap
    + Long burns
    + Everybody knows:) fondue, etc. ..
    + nice flame
    therefore I will use bioethanol:
    Bio Ethanol:
    + Best visual flare
    + Safe
    + No smell
    + No soot
    + Flame burns at the surface, you can designed the "fire" as you want
    - 1L burns approximately 3 hours
  14. caseArt
    4 Feb 2010
    i fight against the flu, the last 2 weeks!
    atm i testing: the flame, the quantity, and heat
    now i use ethanol, so I try a bit around!
    in my "old" oil lamp ethanol dont burn!
    so I can forget this variant!
    ethanol in a stainless steel cup!
    1, 2, 3, .... FIRE !!!!!!
    I think it is a very nice flame, burns great, does not stink, but the heat makes me :eyebrow:!
    The cup is in the height of the flame, warm (NOT HOT), in the lower range (under the flare line) cold!
    Now I will have a "problem" with my case design!
    hmmmm..... I will build me a stainless steel container ;) :D
    lg
    caseart
