.:: Project Catalyst :: Valimont's HTPC :: 29/9 :: Flowcoat applied ::.
Discussion in 'Project Logs' started by Valimont, 11 Jul 2004.
  1. korhojoa
    korhojoa durr
    31 Oct 2003
    Me thinks, Green/Gray basecoat + Carbon fibre figure on top.
    Then some nice led's strategally placed to light places up from the inside.
  2. CYRiX
    CYRiX What's a Dremel?
    4 Sep 2004
    is the cd drive actually screwed in, just looked like you stuck it in there...i
  3. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    *qeustion* what is that thing in the bottom right part of the pic? sitting on your bed, i don't have the slighest clue what it is
  4. Valimont
    Valimont What's a Dremel?
    12 Nov 2003
    yup that's essentially what im going to do, cf sides and a cf figure, also i am going to place blue lighting around (under the keys, etc)
    its screwed in =D
    lol, that's actually a dismantled folder holder downer, (don't know proper name), im using that as the wire for the cdrom hinge as it was all that i could find
    today i should have completed the cdrom hinge, glassed in the psu cover bit, and completed more of the lcd bit :dremel:
  5. Valimont
    12 Nov 2003
    okay so i finished the cdrom hinge bit.. YAY! :D
    anyway...
    here is the metal wires bent and glassed into place...
    here is the cdrom cover glassed up, needs to be sanded etc yet...
    and voila!
    also here is the psu cover bit glassed on finally...
    this afternoon ill try and finish the lcd compartment.. (im waiting on some kneed-it to magically appear..), and if i get that done by 2nite ill be a happy chappy...
    also i might drill the button holes...
    :dremel:
  6. KingofHearts
    KingofHearts What's a Dremel?
    23 Sep 2004
    Loving it so far!
    I did not see any materials like masks or gloves. Just please make sure you wear a mask when your cutting or sanding that stuff. Especially the carbon fibre. I realize it sounds like a captain obvious but the stuff is so nasty to breath in Ill take the insult rather then have someone not wear a mask.
    Also I noticed on Zaps site he used painters tape on his carbon fibre then cut on the tape to reduce freying on the material. The tape holds the edge together. Useful if you will have extra. Its kind of a neat idea you may want to use.
    I love your hinges It sparks ideas how I can solve a problem in my own project. Looking good and cant wait for more.
  7. Valimont
    12 Nov 2003
    g0t safety equipment?
    :D
    nice idea with the cf though.. but i think ill be alright, ill be resining it onto the shell, then applying flowcoat for the design and then clear flowcoat over the cf...
    so any frays should be under the colored flowcoat
  8. Morphine
    Morphine weeee!
    23 Feb 2002
    would you happen to know of any good sources of information on fiberglassing on the the internet, or any guides as to working with this material? After reading through your log and seeing the work you have done, I am convinced that fiberglassing will really help me get the shape to the body of my next project that I really want. how well does this stuff hold up to flexing? If it is sanded, primed, and painted, will it resist flexing enough so that that paint will not crack and flake off?
  9. Valimont
    12 Nov 2003
    sorry i don't know of any guides on the internet... have a look around and see if you can find any
    though after i've finished this project i might do one in the guide forum
    basically i learnt to fibreglass over a week while i was doing work experiece
    as for flexing, if you build it up to 3 or 4 layers of glass it won't flex at all, provided you have laid it properly, with one or two you may get a little bit of flexing
    if you are building it out of fibreglass completely i would suggest not painting it but putting flowcoat on...
  10. Valimont
    12 Nov 2003
    okay so now i have practically finished the lcd... and that is all of the structural glassing work done.. HUZZAH! :clap:
    so here it is...
    this is what i needed the knead-it for, knead-it is an epoxy based dough that goes hard after about an hour, i use it to hold the bolts in...
    then i used some more on the lcd hinge...
    and voila!
    now all that i have to do is...
    - cut out stuff for back panel..
    - touchup lcd hinge
    - drill button holes (btw if anyone has a good idea for this feel free to share :D , i can make any shape button)
    - filler & sand
    - cf
    - flow coat!!!
    by 2moro i should be up to applying the cf... :dremel:
  11. H2O-G33K
    H2O-G33K What's a Dremel?
    25 Jan 2003
    Looking very nice indeed - keep up the good work :)
  12. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Fiberlicious dude! This thing deserves more attention than a few comments, it's really well done!
  13. KingofHearts
    23 Sep 2004
    Nice Mask :)
    Can you elaberate a little what flowcoat is? Im guessing it what will make the surface shiny but ive never heard of it before.
    Flowcoat = clearcoat ?
  14. SJH
    SJH Minimodder
    24 Dec 2003
    Great work dude!
  15. Valimont
    12 Nov 2003
    thx guys... :)
    have you ever heard of a product called gelcoat?
    well if you have flowcoat is gelcoat but has a wax in it so you can apply it on the laminate last...
    if you haven't...
    taken from http://www.fiberglass-hoods.com/
    i believe that the hood on that was done with gelcoat..
    so hopefully it will look something like that...
    also gelcoat is a resin
    also does anyone have a good suggestion for the design.. i was going to do the headphone girl on it.. but now im not so sure...
  16. Slayer the Unholy
    Slayer the Unholy What's a Dremel?
    19 Aug 2004
    I hope your case turns out as smoth as that car it will look incredible. BTW smooth that epoxy dough
  17. Valimont
    12 Nov 2003
    okay here's todays little bit
    basically now im just cleaning up all of the fibreglass..
    2moro should be flowcoat time etc :D
  18. Litecore
    Litecore What's a Dremel?
    21 Sep 2003
    looks great, keep up the good work! :thumb: :dremel:
  19. Valimont
    12 Nov 2003
    okay here we are...
    the buttons
    and the carbon fibre attached
    plz note that i needed to touch a couple of places up (as u can see in the pic) and also it'll have natural flowcoat over it..
    this afternoon i should have put the grey flowcoat on.. :D
  20. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    This is really taking shape now! :thumb:
