Project: Centurion | Razzz
Discussion in 'Project Logs' started by Razzz, 30 Nov 2006.
  1. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    wow, thats a lot of pics! this really looks good. that res is a cool idea, being copper it will act as a small radiator. being so thick tho, not much of one. that was one massive chunk you put on top of it. how did you remove the excess from the curved shape, milling, grinding, sanding (man that would be a lot of copper dust), or what?
    like everyone is saying, the hardlines look great. what did you bend them with?
    one last question, what are these?
  2. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    wow :eeek: that is very, very clean :D very nice, love it, show us more :D
  3. CrazyModder
    CrazyModder What's a Dremel?
    13 Jun 2006
    I believe they are wrenches for the fittings. :confused:
  4. z4114
    z4114 FACE!
    25 Jun 2002
    Wowzers! Those hard lines look awesome! That's always been one of the things I would want to do if I ever plunged myself into debt with a full WC case. They look so smooth and shiny. Could using metal pipes lead to galvanic corrosion?
  5. Razzz
    Razzz What's a Dremel?
    30 Nov 2006
    Thanks all! Great respond on this forum!
    It´s copper pipes with chrome, so you can´t bend the pipes to fast/much or else the chrome will be cracked.
    the camera I used for the last pictures is useless so I will take som more pictures later.
    Generic42: Yes, just bend them and put them on. Of course you have to change the fittings.
    sui_winbolo: hehe, yes it´s a Zalman fancontroller.
    itsjustacompaq: Those tools are special made for this project. Otherwise its (impossible?) hard to tighten the pipe with the fittings.
  6. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    very very nice mod
  7. Noni
    Noni What's a Dremel?
    8 Dec 2005
    Holy crap those pipes are pimping.
    Wire management is the only critque i have!
  8. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    Damn! I dont know wath to write to this, I'm pretty much speakless..
    You have doned a hell of a job! Kudos for you man!
  9. jodah175
    jodah175 Wannabe Modder
    26 Oct 2006
    wow, is all i can say. i've been thinking of doing hard lines for my case. wonder if it would be possible to bend up copper tubing and then have it chrome plated?
