project: Chemical Overdose 17-08: In stores now ;)
Discussion in 'Project Logs' started by _ferry_, 6 May 2004.
  1. ErrOnReq
    ErrOnReq What's a Dremel?
    7 Apr 2004
    unless the paint is rubbery, it will probably crack when the wires even slightly move.
  2. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    Thats what wire management is for :)
  3. ErrOnReq
    7 Apr 2004
    The wires, regardless of how they are managed, would need to be moved at some point in time though. If his CD drive dies and he has to replace it, he has to unplug the molex and IDE cable. Even if those were in loom or something, the loom is still flexible and would bend when unplugging the drives. If the paint is hard and not rubbery, it will probably crack and flake.
    I'm not sure how that rust paint stuff is, but by the looks of it, I would think it's pretty stiff and would crack if the material it is painted on flexes. I guess we will find out when _ferry_ replies
  4. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    Tnks all. :)
    The idea was giving the cables only a dirty look with some deep brouwn paint, like this:
    but without the mesh.
    Well, painting the mobo would be damn nice, but i don't want to kill it as you might understand.
    Today i'm going to buy 3x 120mm fan, and about 4meters of tube for the watercooling :) (if i'm not going to the beach :D )
  5. RR5
    7 Dec 2003
    There is an article about spray painting motherbaords. The gold traces are not effected by a non conductive paint.
    Same effect as a layer of dust on a motherboard and the board still works.
  6. _ferry_
    22 Apr 2004
    but i had to rust it with an oxidant, witch could also rust components and traces on the PCB
  7. RR5
    7 Dec 2003
    brown and a little bit of orange paint mix?
  8. Goblin Tinkerer
    Goblin Tinkerer What's a Dremel?
    24 May 2004
    I could tell you how to make rust with out any oxidents. You start by lathering your mobo with glue then dump a bucket of sand on it.....
  9. The Peacekeeper
    The Peacekeeper What's a Dremel?
    27 May 2004
    Dude that thing is freaking sick i love the way that it came out. Keep up the good work.
  10. _ferry_
    22 Apr 2004
    or sand down a piece of old metal collect the dust and dump it onto it :)
    But painting the heatsinks won't be a problem, and will be nice too :)
  11. piloux
    piloux What's a Dremel?
    12 Nov 2003
    I don't think that it is a nice idea to use this sort of paint over electronical parts ...
  12. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    ha ha ha, come on Piloux, wheres your sense of adventure??
  13. piloux
    12 Nov 2003
    lol , may be you could try it :D
  14. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    oh i will all in good time my freind, (just got job now need to make some $$$$) WE HAVE PROGRESS
  15. NixioN
    NixioN What's a Dremel?
    7 Jul 2004
    That is very nice! I love that glowing liquid.
  16. D B
    D B What's a Dremel?
    11 Apr 2004
    Do what plastic modelers do for rust .. like RR5 said , orange/brown paint.
    I think the test used for the motherboard paint idea was to spray something and test the conductivity with an Ohm meter ... yep , some risk is involved but might be worthwhile depending on how visable the motherboard is.
    How about clear FLAT paint ... very dull finish , for a protective coat
    _ferry_ ... that is an AWESOME case , idea , execution , attention to details , Etc. Etc. ...!! ...... and .....! ..........! , also ...!!
    DB
  17. _ferry_
    22 Apr 2004
    OK, i've been thinking about painting (jeah, thats take a lot of time :D ) And i will try to piant the mobo a little bit, just to make it dirty and old looking with some brown and orange paint. Like the cables's. The heatsinks will have some rust on them.
    I'm going on hollyday tomorrow, and the case is going with me, just for when i have some time left. Only a dial up connection so updating will continue after 1 week :)
  18. RR5
    7 Dec 2003
    I'm now thinking painting a motherboard might be a problem due to heat.
    Imagine gooey paint on a motherboard?
    Maybe I'm taking this a little too far, but better safe than sorry.
  19. ErrOnReq
    7 Apr 2004
    There are paints made for things that get hot. DupliColor makes a line of paints for your engine and brakes and whatnot that can take the heat unlike ordinary paint. Personally, I don't think it would be an issue unless you're painting the CPU itself :p
    I don't know if DupliColor's heat resistant paints are conductive or not though :-/
    I have seen a thread somewhere where this guy painted every component in his case; motherboard, graphics card, etc. Not sure where I saw it though.
  20. Xoddoza
    Xoddoza What's a Dremel?
    13 Jun 2004
    That would be here http://forums.bit-tech.net/showthread.php?t=60585
    BTW keep up the good work. Loving the case.
