project: Chemical Overdose 17-08: In stores now ;)
Discussion in 'Project Logs' started by _ferry_, 6 May 2004.
  1. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Those 5 green buttons, what are they for?
  2. irsekz
    irsekz What's a Dremel?
    23 Feb 2004
    my guess fan bus
    that looks kick ass exspecially the WC system that is a real nice green glow good job
  3. invader crack
    invader crack What's a Dremel?
    18 Jul 2004
    sick ass mod man :dremel: :rock: :dremel: :rock: !!
    the WC looks tight, the uv green glow must be impressive in person
    :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
  4. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    thats right:
    1: 120mm fan
    2: 80mm fan
    3: feet UV leds
    4: feet CCFL's
    5: free for case lights
    today i think i'm gonna get a metal front on my monitor, to make it a bit more in style to the case. mice and keyboard should be done too, but i have the time ;)
    the cable's i can fix at the lanparty friday, but the WC for the vid. card i will do after it, because its need a refill of the WC system, and now i had to hurry, and after the lan party i have all the time
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    sweet!
  6. _ferry_
    22 Apr 2004
    jeej, i won the 2nd price on a lan party, i had 42points, the nr 1 43 points, very closo. So i won a game, a keyboard and much compliments from the people around.
  7. tortuegeniale
    tortuegeniale What's a Dremel?
    7 Nov 2003
    cool :clap: is there an online pic of the first ? I wonder what kind of mod could be chosen over yours...... :confused:
  8. bullfrog
    bullfrog What's a Dremel?
    18 Jun 2004
    Its soooooooo beautiful, I want one i want one!! :waah: :waah:
  9. _ferry_
    22 Apr 2004
    Tnk you :blush: well, it depends on the choice of the organisation, not the audience ;)
    If it was, or when the case was completely finished the 1th place would might be mine, but offcourse i can only say that afterwards.
    I dont know a project log ore something like it, but the one who made it told me that he tought i would win. Well i almost did... he modified a coolermaster 4u 19"case, by using it as a normal (deep) tower with a very nice look and a complete custom made USB baybus even the software. he won a vapochill case, and i won a new keyboard and a game.
    The best pic ive got from his case is this one:
    it's the alu one at the left side.
    I'm happy with the glowing keybord, works well, but it woul look much better at my upcoming casemod....... (not gonna tel you what it is :p )
    and a nice closeup of my case :D
    (The pics didn't came from me.)
  10. -N4cR-Stigma2K
    -N4cR-Stigma2K Banned
    8 Jul 2004
    Thats f****ed up man :wallbash: . You should have won that price, even if the other guy was Piloux!
  11. FanatiK
    FanatiK What's a Dremel?
    25 May 2004
    This is a very nice mod but there is one thing that is bothering me. It seems like you are making everything look old rusty and worn out but the buttons you used on the front are bright like hell as if you bought them yesterday. Are you going to roughen them up a little or make them look old because they stick out like a sore thumb. Everything else looks very good. Sorry if this has been mentioned before. Keep modding!! :dremel:
  12. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    An intresting point, you could take a little black spray paint and darken a little around the LED.. so the light you see is not 100%
  13. _ferry_
    22 Apr 2004
    already don that :p ive took some brown paint and used that on the green parts, and added some rust at the black parts.
  14. malcolm
    malcolm What's a Dremel?
    8 Mar 2004
    It looks awesome, you should be proud. :thumb:
  15. D B
    D B What's a Dremel?
    11 Apr 2004
    Great work and congrats on 2nd place ( you know it should have been 1st )
    Very well done Mr. _Ferry_
    DB
  16. _ferry_
    22 Apr 2004
    tnks all for the congratz. Today ive made the 9600pro WC'ed :D You know i had a geforce4 waterblock, today i modified it into a ati block. probably at the end of this week he will be moved to the PC shop witch sponsored me. I had to miss him for +/- 3 weeks :waah: well, on the other side i'm proud aboout that.
    And if you disagree with the 2nd place you should slap the resetter
    :hehe: he was 1 of the crewmembers :D
    the cooling stuff, with the new metal top, as you might can imaging it took some time to saw,drill, sand and dremel before the 2,5mm metal was on the right dimensions. But the weather was nice and it saves me of buing a new block.
    And after mounting on the card.
    Finally mounted the top fan, now testing if he can better blow or suck, because i have 1 120mm intake, and a 80mm out. and the psu fan. But testing will show me the result.
    Last but not least, modified my monitor to fit with the case. not completely, because if there will be another mod it shouls look good too.
    things to do:
    1: finish the rear legs
    2: add some inside light
    3: mount the cdrom bezel again
    4: tidy up the cable's
    5: add a XLR connector on the cable to the WC unit
    6: new top window (this one is a bit too small)
    7: mount the GPU memory heat sinks
  17. ZeroX
    ZeroX What's a Dremel?
    17 Sep 2003
    realy nice work!
    hope the new windows looks as great as the one already in there
  18. Kelisis
    Kelisis What's a Dremel?
    18 Feb 2004
    To bad you didn't win. From the looks of it in the picture, your case is way cooler. You should've got 1st place. I like the moniter btw. Hopefully, you will paint the rest of it, maybe you could cut out "Ferry" on the side, light it green, and give the rest a rusty finish. :rock:
  19. _ferry_
    22 Apr 2004
    update
    soo, i made a new mousepad today. my dad his hobby is making glass in lead windows. so it was his job to cut the glass. After that i started with printing out the logo, taped it on the glass and begun with following the lines with a sharp knife, and this is the result:
    And the old one:
  20. MrBurritoMan
    MrBurritoMan What's a Dremel?
    27 Jun 2004
    oooooooooooo oooooooooooo i likes b100000
