project: Chemical Overdose 17-08: In stores now ;)
Discussion in 'Project Logs' started by _ferry_, 6 May 2004.
  1. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Hi
    I'm very intrested in the way you sandblasted the text in the tube.
    So I take it that the sandblasting process isn't very violant? since it didn't rip off or damage the tape?
    Have you tried sandblasting glass? would that work as easy as on the plexi ?
    thank you!
    L
  2. woodshop
    woodshop UnSeenly
    14 Oct 2003
    I'm in the typing mood so i'm going to wager a guess.
    SandBlasting uses a very fine silica sand shot out of a gun from a air compresser. this fine sand scraches the surface of the plastic/glass and thus leaves the image. The skill in it is getting the pressure and exposure time right. To long and or too much pressure will make the sand eat through tape so fast that you won't be able to stop before it gets through scraping the attempt. So that being said i think that glass is much harder to eatch has it's harder+ it's shock sensitive so it will shatter very easy. :D
  3. Garbach
    Garbach What's a Dremel?
    22 May 2003
    ...and don't forget too mention that sandblasting is very VERY bad for your health (smal particles deep in your lungs) so use proper safety equipment when you go at it!
  4. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    Sweet res mate!
    The case will be very cool!
    Keep it up :dremel:
  5. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    tnks all.
    I've done sandblasting on glass too:
    (logo from a dutch pc forum)
    I used glass, because normal plexi became full of scratches from my mouse.
    The strange thing is that the sand leaves deep cuts in the glass (at 7bar :p , plexi i'm doing on 5bar) but didn't damage the (normal) tape. Might because the tape is soft, and the glass is hard. the only problem was that because the lots of air small amounts of sand were blown below the tape at some small corners.
    The idea of using oil into the watercooling is to fill the res. almost to the top. but filling the last with oil. So it won't circulate trought the system.
    I will try how clear oil will work in top of the water, too see if there aren't strange reactions or something like that.
  6. FourDee
    FourDee What's a Dremel?
    6 Mar 2004
    Heh ook op GoT aanwezig? :D
    Mooie mod echt :eek: :thumb:
  7. Stigma
    Stigma Banned
    13 Jun 2004
    Not same as Piloux?
    Like me you did't use that modern options stuff that Piloux used right?
    Is your paint a oxydant, or is it just paint?
  8. _ferry_
    22 Apr 2004
    i did used the same as piloux, but the paint i'm talking about in your quote is the neon yellow stuff i used for the leaking effect :)
  9. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    Been some time since I last visited, forgive me.
    It all looks great, I aplaud.
    Cheers,
    Mike
  10. _ferry_
    22 Apr 2004
    update
    well, lots of pics coing up :)
    the res. with a blacklite in top of it. thats looks realy chemical :clap:
    a experiment with water and blue oil. it didn't work well, the blue color was almost gone after some hours.
    a shot of the back, offcourse there will be added holes for the water tubes, i think the space beneath the PSU is a good place for it.
    might you know this block, its an innovatec gf4 block. the flow is just made by a space from a few mm in height between the top and the flat copper bottom. i think thats not good for the flow. so i took my dremel, and made a water-way and removed some plastic from the top. Hope its gonna work, i'm almost shure :p
    hiding the CCFL cable on the same way i did on the legs at the normal case.
    and a shot from the front while adding rust at the inside.
    the fanhole with fingerguard at the top. just to give the motherboard some fresh air. There will also be a 80mm fan at the side, a very silent one in the psu and a 120mm at the other side.
    And after some minutes. The bright orange color on the top left will be gone after some days, and change into red. You see also thhe logo i made for the front. it will be mounted beyond an metal window.
    thats for it now. comments are welcome. now i'm going to keep myself busy with finishing up the inside (rust paint, cable's, pipes) and mount some hardware and thinks like that.
  11. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    i think u exceeded your bandwith because all your pics are down.
  12. ^R3CoN
    ^R3CoN What's a Dremel?
    14 May 2004
    Pics are up.
    Nais work mate ! :)
  13. Bobpa!
    Bobpa! What's a Dremel?
    28 Jun 2004
    Yep, pics are up... And I also can't wait to see what is next. I think you doing a nice job on this project so far :thumb:
    Keep it up dude, I'm enjoying this mod! :clap:
  14. _ferry_
    22 Apr 2004
    tnks my dutch modding friends :baby: :hip:
  15. Stigma
    Stigma Banned
    13 Jun 2004
    Help Me!!!
    What kind of primer do you use, I also saw Piloux use something very similiar
  16. MrBurritoMan
    MrBurritoMan What's a Dremel?
    27 Jun 2004
    wowo im impressed. ill have to try that rust paint out myself..need more pics. :thumb: :rock:
  17. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    very very nice ferry i like the general "theme" of the case, i like your idea of the high pressure tubing, one of my favorite ideas of your case, but other than that your case is just perfect industrial/chemical look.......... :thumb: keep it up
  18. Spy246
    Spy246 What's a Dremel?
    2 May 2004
    Y don't you sleeve the psu in some kinda thing that relates to this projects. Something that would make it look better
  19. riesjart
    riesjart What's a Dremel?
    24 Mar 2004
    The case is very nice indeed.
    And where youre from in holland, can't you help met with etching my case?
    Please send me a PM, because else it will very offtopic :worried:
    Keep on the good work. :clap:
  20. _ferry_
    22 Apr 2004
    tnks for the reply's, its a good simulation for keeping on modding :D
