Case Mod - In Progress Project: Chevy Hot Rod (4 month update!)
Discussion in 'Project Logs' started by TheGreatSatan, 10 Jun 2013.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    The case I'm using is the Cooler Master 690 Advanced a store display from Micro Center that served it's purpose for over 2 years! In that time it took a lot of abuse so it's due for a major makeover
    Under the plastic frame was 2 years of dust
    After a good cleaning, a nice coat of metallic silver went on
    And repeated that color on all of the metal mesh on the outside of the case
  2. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    ohh, shiny!
  3. XcOM
    XcOM What's a Dremel?
    3 Jun 2013
    Another mod of your usual quality there TGS
  4. Sn00k3r
    Sn00k3r What's a Dremel?
    7 Apr 2011
  5. dipzy
    dipzy Minimodder
    5 Jan 2013
    I lurve HAWT RODS! All that POWAAAAA!!
    Gona love this one :D
  6. TheGreatSatan
    5 Aug 2005
    All of the plastic on the case is painted purple. It goes on light at first
    And it slowly darkens
    This one section keeps going on wet and drying far lighter than the rest of the case
    Well at least the front is done. I reassemble all the metal mesh on the front panel
    And then put the feet back on
    After literally a dozen coats of dark purple, I finally get it to go on even
    I have these SilentX fans that I once used in my OCZ theme case. This time they're painted silver to match
    And I have this high power Aluminum blue LED fan for the rear exhaust
    So much more to come
  7. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    i want chromed exhaust pipes and HUGE supercharger! and i mean it!!! :D
  8. 666painkiller
    666painkiller If only....
    23 Jun 2010
    I agree!!!
  9. XcOM
    3 Jun 2013
    I am always in awe of your build logs
  10. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Hmm, I can't help but think that a metallic purple enamel paint would have fitted better with the whole hotrod look. Like the silver though, came out well on the fans.
  11. TheGreatSatan
    5 Aug 2005
    It actually is metallic, but lacks the look because it was sprayed on top of a primer and not directly on the bare metal
  12. TheGreatSatan
    5 Aug 2005
    I got the exhaust pipe to use as a scoop
    That will attach to the top via two screws
    I also repainted the reset and power button
    The drive cage looks a little weird, but I don't want to paint it
  13. TheGreatSatan
    5 Aug 2005
    I picked up a Cooler Master Musketeer on eBay for $7
    And some new Purple paint and primer in one that dries more evenly
    I'm using a light coat of glitter too just like in my Hello Kitty project
    While that dries I move on to the right side panel where I mark off mounting holes
    An then drill them out
    So I can mount these small block headers
    Then it just requires 8 bolts and nuts to secure it to the panel
    I think I need to cut these off too
    It looks cool so far
  14. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    The case looks great. Did you have to weight the case to stop it from tipping over with that header hanging off the side?
    As a side note, TGS you ahve have the best "wallpaper" in your shop.
  15. TheGreatSatan
    5 Aug 2005
    Actually, the case stands fine, even when empty I thought it would fall too
  16. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    Grunt, Grunt, Grunt :rock: Nice
  17. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I love it. I like the color, and the concept is sweet
  18. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Little Deuce Coupe you don't know what I gottttttt. :D
  19. TheGreatSatan
    5 Aug 2005
    I'm sorry for the delay. I have been working on this on and off and I keep forgetting to update the work log. Update coming soon
