Case Mod - In Progress Project: Chocolate Temptation-Update 4 June - I have got Sick & Facebook Page!
Discussion in 'Project Logs' started by KoSoVaR^, 23 Jun 2011.
  1. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    looks awesome m8 :D
    ps - check out my build if you have time ;) :p
  2. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Im have already subbed it :D!
  3. KoSoVaR^
    19 Dec 2010
    Hello Guys!
    Today I have not had time to do all that much, but it was anyway something when you still were tool-home ...
    I felt I had to do something about the fans... not because the cable is ugly ... whis they are not...but to make it flow with the rest of the theme ;)
    After those two fans I had a closer lookt at the start button ...I may fix me a 1.8mm LED tomorrow and then i will sleeve those cables aswell.
    While I am passing by to the shop tomorrow I'm also going to fix the cable hole on the PSU bracket and the reservoirholders aswell...I have to buy some ulist too to make the cablehole look tidy!
    I was for some reason somebody idea and I was looking where we had left the drill, once I had found it and began to remove some rivets, it looked like this ...
    What I wanted with this was to create a backinlet, clean but nice :)... Sure do, now I just need to fix more holes:)
    Measured if it is possible to get there two pieces of 80mm fans ... and it worked!
    Looks damn clean! ;D
    When I got tired in my head, I sat around with BP stuff and played how it all would sit ... came to the conclusion that I must have a mini-extender or the pump will not be able to fit!
    Q-Blocks are great to have the temp sensor input, etc.:) will fix so that the fillport and the tempsensor will sit on the Qblock while it goes to the res, should work this way:)
    Here's how it looks almost the entire package out ... no pump and miniextender course ...
    this was it for this late night!
  4. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Looks really cool.
  5. KoSoVaR^
    19 Dec 2010
    thanks dude !
  6. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Going for a brown LED? on the power button.
    Its all looking great, see this has made me wish I'd bought BP fittings I already know i'm going to have hose everywhere in my build!
    Keep it up!
  7. KoSoVaR^
    19 Dec 2010
    I cant find brown leds, there arn't any, I have to combind two leds at low latencys to make a dofed and not bright light... so i will make it white 5000K instead :)
    you can search for me if you want :)!
  8. The boy 4rm oz
    10 Apr 2008
    Some quality mounting work there. looks like you should be able to fit everything in there with minimal hassles.
  9. KoSoVaR^
    19 Dec 2010
    Hehe thanks dude :), yes it does...i only need that mini dual G1/4" extender and im ready to go :D!
  10. puttsy
    puttsy What's a Dremel?
    6 Aug 2011
    Really nice log and GREAT ideas. Not only is this well thought out, it is executed in an amazing manner. Been following along and am very impressed.
  11. KoSoVaR^
    19 Dec 2010
    Thanks dude ! its really nice to hear your oppinon :), and thank you again, you are welcome to subb !
  12. KoSoVaR^
    19 Dec 2010
    Now I come with a small update to the people ... has not happened all that much since I have devoted myself to work!
    But always do it anyway something on the side ... what I have managed to do until now is that I have made the hole for cables larger, short 8 mm at each end out of reservoir holders, and made it clear PSU for the test:), got a 8pin CPU connector out of Stefan, which I needed to get everything ready for that matter, the last thing to do at PSU will be to attach the sata connectors and solder back the fan and I'm ready to go for that matter, I must not forget to apply some thermal compound on the one cooler before fitting out of resentment when it needs it !
    CPU connector and assembly ...
    So much better:)!
    The scraping will be fixed:), the PSU will probably turn brown painted:)
  13. KiiYzOo
    11 Mar 2011
    looks good :D
  14. KoSoVaR^
    19 Dec 2010
    thanks dude ;D
  15. KoSoVaR^
    19 Dec 2010
    Whats up Dudes!
    Although lying sick in bed so I would surely have something to do ... you can not be stopped without the fuss over something ... so here you finally ....
    From a good friend I have with me a package home ... That man is no less than Arthur from coolingstuff (sweden)!
    I thank him because he has shown interest in my projects so far!
    The sponsorship included:
    1x EKWB Supreme LTX Acetal intel
    1x Liquid Extasy Vuci Acetal
    2x Primochill 7/16 Clear Slang 1m (2m)
    1x Arctic Cooling MX-4 4g
    1x Isopropylalkohol 300ml
    1x Swiftech MCP350
    2x Enermax TB silence VR 1500rpm
    TTook home the package ... but ... before I began with something so I had o eat something because of the penicillin :) I made some hamburgers a-lá Kosovar :D!
    The pacage safe at home!
    The content that I wrote above ... except isopropylalcoholcan since it will leave till tomorrow!
    Fans: Enermax TB Silence VR (built-in fan control ... will be removed and these rotates at 1500rpm instead of 900rpm as the regular ones)
    Fan control and 3pin connector, fan control cable will be bridged aswell!
    The hose, but the screw to compressionfittings can not screw all the way ... any idea why?
    A woundeful thermalcompund!
    Southbrigdeblock and its accesories
    Double, Mini G1 / 4 "extender ... was on the millimeter and it did not fit ... then ...damn..i will show you guys later!
    the Pump !
    I am going to solder an 3pin fan cable on to the pump, dont worry...my fancontroller can handle it!
    The Cpu block in all its glories ... I did not think it would be that big!
    So freaking nice!
    Size Difference ...
    Time for some assembly...
    diferences...need to be thinner...Arghhh :mad:!
    Time for some pumpmodding!
    Here i will solder a 3pin cable istead for the 3 and 4 pin conectors :), the pcb got some good solderpoints! but not the soldering job :O... wtf its awful !
    Changed to the bitspoweroring, the glossy one...
    Done!
    The loops must be cut and the cable should be fixed late, it will be well Sleeved as well, I will probably test the wc system soon so then there will be a movie out there... actually my first one!
    See yaah until next update !
  16. LazyMan
    LazyMan What's a Dremel?
    9 May 2010
    Looking good bro......good job on sleeving the fans
  17. KoSoVaR^
    19 Dec 2010
    Thanks dude !
  18. l3p
    l3p www.^.nl
    1 Nov 2010
    Totally forgot to subscibe :blush:
    I love loads of pics :)
  19. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    always wait for update on your build
  20. KoSoVaR^
    19 Dec 2010
    :O how could you dude xD heheh :p
    good to hear, subscribe to my thread and you will get a email when i update it :)
