Case Mod - In Progress Project: Chocolate Temptation-Update 4 June - I have got Sick & Facebook Page!
Discussion in 'Project Logs' started by KoSoVaR^, 23 Jun 2011.
  1. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Thank you guys!
    I will finnaly be awating my cnc-part now after christmasholydays...
    Then everything begins :)
  2. KoSoVaR^
    19 Dec 2010
    Hello my friend, have you made any progress with the experimenting of the coolant ?
    Happy Holydays btw :)
  3. ReDoZz
    ReDoZz What's a Dremel?
    25 Dec 2011
    good work bro :D<3
    KoSoVaR^ likes this.
  4. KoSoVaR^
    19 Dec 2010
    Thanks :), when will your project be up here in B-T?
  5. KoSoVaR^
    19 Dec 2010
    I thought it was time to do a mini update on what my latest addition has to offer:)
    A package from Zotac har ariven :) This is just a little preview photos taken with my phone in my dark room ... can it get better? ... will be to take real photos then also system camera is back from service.
    Zotac Z68-ITX WiFi
    Zotac GTX 470 in a different package only:)
    I have assembled some components, but lacks, however, a processor so far ...
    Now, I really noticed how small the motherboard really is: O!
    I will test my graphicscard right on and see how it works as it should be:)
    It was for this time, I come up with new and much better pictures soon:)!
  6. Briaireous
    Briaireous What's a Dremel?
    29 Nov 2011
    Wow thats a monster of a graphics card compared to the poor little mini-ITX motherboard :p
    Been watching this mod for awhile keep up the great work :)
  7. KoSoVaR^
    19 Dec 2010
    Yeah I know :), the small ITX is the monster mobo of its class aswell ;D
    Thanks!
  8. KoSoVaR^
    19 Dec 2010
    Hello everyone!
    I have to say that i have got some complaints that I have not done any updates in a while :/ ... The truth is that iat is so... but I did anyway take my thumb out and started to play around with all the things that I had at home today, its nice to finally have some sparetime afterall :)
    I dont have that much to tell you guys but today I wanted to see how everything is going to sit, I even did the planing for my tuberouting and what should be done on the chassis before it prepares for the ALU-weld and paint preparation.
    I have been thinking of re-sleeving the power supply ... What do you think guys?
    What I have at home right now is: Copper Brown, Vanilla Sands, Black, Color-X, Red, B-magic and little else from MDPC-X, including mass of different colors from Djungelapa :)
    I haven't decided that yet...and I will also crimp that sleeve aswell!
    I have been thinking for a while if my powersupply will work 100% to runmy system in LOAD :/ ?
    Here is todays Picdump :)
    I really have to fix the soft box that I have been planing to make for some time now and never had time to :(
  9. Djayness
    Djayness phwupupupup
    7 May 2008
    Nice EK block, probably the sexiest available :)
  10. Martininho
    Martininho What's a Dremel?
    8 Feb 2012
    Wow, nice modding Kosovar. Makes me doubt my desicion to scratchbuild before casemodding.
    :rock:
  11. KoSoVaR^
    19 Dec 2010
    It was mostly why i bought it ;)
  12. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Hello Kosovar!
    I think that maybe you should try other combinations of colors since your board has a lot of mixed colors is hard to find something that suits well for everthing.
    Maybe use lighter tones or get rid of the silver because It looks really different from the other shades you are using.
    Keep it up!
  13. KoSoVaR^
    19 Dec 2010
    Thanks, I appreciate your comment a lot :), dond forget to subscribe and rep me :D
    Hi!
    Toobad there is no m-itx sabertoothboard out there, i can tell you now that the motherboard will not be as mouch visible because of the waterblocks and the other componens, the small accents of yelllow and orange will not be visible at all at the end... Everything will blen in so perfectly at the end.
  14. Djayness
    7 May 2008
    True, it will most likely be very difficult to see the PCI lanes when everything is fully installed. If you use caution though, there are guides on how to spray paint these without any ill effects.
  15. KoSoVaR^
    19 Dec 2010
    Exactly yeah i know that aswell but i dont want to risk something good for something that will not be visible at the end, i think that my coolant will totaly draw the atention of this build after all ;)
    Im proud that mick made me this coolant...he is a great guy :clap:
  16. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    nice build there,
    the Swedish are the best
  17. KoSoVaR^
    19 Dec 2010
    Thank you...I wouldnt call me a swede hehe...but i was born and I do live here ;)
  18. bguilleminot
    bguilleminot What's a Dremel?
    11 Aug 2011
    That sleeve looks like snakes going out of the connectors =O
  19. Djayness
    7 May 2008
    Thats because A, he's using paracord like a boss and B, he's not using heatshrink which is totally awesome :)
  20. KoSoVaR^
    19 Dec 2010
    Thats right Daniel :)
    I really liked that sentence:
    Like a bowss :clap::rock:
