Case Mod - In Progress Project: Chocolate Temptation-Update 4 June - I have got Sick & Facebook Page!
Discussion in 'Project Logs' started by KoSoVaR^, 23 Jun 2011.
  1. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    This is how the waterblock looks like now
    I have to whait until fall for my cnc parts but that gives me time to make the waterblock and find the oring aswell !
    Dont forget to like my facebookpage !
    https://www.facebook.com/KosovarMods
  2. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    That block get's better and better! :)
    I'm very sorry I can't help you with the design for the o-ring, but my SolidWorks just keeps messing up when I import your part... :(
    Mod on! :rock:
  3. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    I'm in love with the block since the first day you posted the sketches :D
    Really want to see that little block finished and installed :)
  4. KoSoVaR^
    19 Dec 2010
    Thanks Martin
    I habe been investigating a differenr viority of blocks, the oring channel will begin 1mm from.the edge, the oring that o will use will be 1,1-1,3mm thick, do you think that it will be okay?
    My bitspower memory block uses one of those orings ant too bad it dont fit, i will look if the 6x memoryblock has the length that i need :) but the oring is perfect!
    Nice to hear brow!
    I cant whait to install it myself
    I can announce that im going to make another sideproject and it will have with the same theme to do, what case etc etc will be a secret!
  5. KoSoVaR^
    19 Dec 2010
    Hello Guys!
    I have nothing up to do now that im quite sick...
    Im trying to sleeve a custumers PSU right now and it goes fairly good...but pretty slow.
    I have some PCI-e cables to do now and send it before friday so that i can have time to test it with the PSU tester etc :)
    ADD ME ON MY FACEBOOKPAGE TO SEE WHAT IM DOING RIGHT NOW!
  6. KoSoVaR^
    19 Dec 2010
    Hello guys, I just wanted to tell you all that the project isn't dead, i will continue on it when the CNC-Team is back from thier siesta ;)
    Meanwhile im up to a new project, which will be more simple than this, and it will also make that i can have something to work on meanwhile...
    I usally do a lot of sleeveworks nowerdays and if you are interested of seing those please goto this link and like my page for much other stuff...
    Best Regards
    /Venhar
  7. KoSoVaR^
    19 Dec 2010
    Hello everyone!
    I just wanted to tell you that i have started another project.
    Plese check it out, comment and dont forget to subscribe :)!
    The project is called MonoBits and its is going to be a highend watercooling build
    http://forums.bit-tech.net/showthread.php?t=237985
    See yaah there!
