Scratch Build – In Progress Project : Cigar Box Guitar (UPDATE 18 June)
Discussion in 'Project Logs' started by BagUd, 26 May 2011.
  1. BagUd
    BagUd New Member
    5 Jan 2004
    Hi. I wanted to give my father in law a special present for his birthday.
    And came up with a Cigar Box Guitar. Because he loves guitars and owns a music school.
    Wait a second for the images to load !!!
    So the idea that i came up with is this:
    On E-bay i found this cigar box. (29 x 35 x 6 CM)
    The inside.
    So the design began with the measurements of the box.
    and yes he is a F.C. Hansa Fan (Germen football team)
    I went to the local lumberyard and got a piece of Jatoba board.
    And began to transfer the layout for the neck.
    UPDATE
    The neck rough cut
    And with the box
    Started routing the head to get it angeled.
    Clued a piece of board to the back. so i could route the back to.
    The finished head.
    Routed the neck to make it round.
    Closeups
    Ive cut the mounting hole in the box for a test fit.
    Clued two pieces of Oak together for the fret Bord.
    Cutting the F-Notes in the case.
    Fixing some mistakes the router made. its on the back side and doesn't mater because it will be painted
    Drilled and test fitted the Jack connector.
    First coat of paint with the neck covered in tape.
  2. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Wow you got some woodworking skills there bro!!! Is this going to be .....a guitar or a pc??? I am confused I must say !! :)
  3. BagUd
    BagUd New Member
    5 Jan 2004
    Thank you very much. It's just a guitar. :D
    little update!
    Just got a package from Germany
    Two stickers and a patch.
  4. BagUd
    BagUd New Member
    5 Jan 2004
    Update
    Ive gotten a little work done over the past weeks.
    The case with the final coat of lacquer.
    And here with the sticker.
    Here is the head with it's sticker.
    And just an overall image.
