Project Cisko* Black
Discussion in 'Project Logs' started by Cisko, 2 Jul 2004.
  1. Cisko
    Cisko What's a Dremel?
    6 Jun 2004
    1/3 do
  2. Cybertronic
    Cybertronic What's a Dremel?
    25 Feb 2004
    Cisko, how did you manage to disassemble the HDD cage and put it back on?
    I would love to know how you did it as Coolermaster uses rivets :sigh:
  3. piloux
    piloux What's a Dremel?
    12 Nov 2003
    he drilled into the rivets and after put new ones I think
  4. Cybertronic
    25 Feb 2004
    Just had a look at my Coolermaster 201 ATC (brown sides), there seems to be 12 rivets that needs to be drilled out :eek:
  5. MrBean
    MrBean Minimodder
    21 Apr 2004
    Hello Cisko,
    Impressive work so far!
    The only problem I can see may be this:
    The hard drive may overheat, as it usually sinks it's heat via the chassis of the PC, where it is bolted to the drive-rails......maybe you should consider at least having a fan blow air over it from the font of the case?
    Keep up the nice work, I will definately keep an eye on this one.
  6. Cisko
    6 Jun 2004
    not new one , but simple screw and grind her head ( not sure of right word > limer , meuler in frensh )
  7. Cisko
    6 Jun 2004
    there are two fan on front which blow on it :) temp at 28°C with 24°C in my home, ( i am not in africa but belgium so never really hot :hehe: )
    thanks for comment , tomorrow : the watercooling :naughty:
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    looking good dude, will def keep an eye on this...
  9. Cisko
    6 Jun 2004
    ty :)
    and just two pics of the wc status
    http://cisko08.free.fr/pc/mod640/wc%20003%20(Custom).jpg
    http://cisko08.free.fr/pc/mod640/wc%20009%20(Custom).jpg
  10. Cisko
    6 Jun 2004
    Temp :
    Barton 2500+@3200+ 1.7 V
    34° full with 2 120@12V , ambiant : 22°
    :clap:
  11. MrBean
    MrBean Minimodder
    21 Apr 2004
    Mmm...I only saw the fans after I made my post, but better be safe than sorry, eh?
    Anyway, quite true, "Holland is 'n bietjie koeler dan Suid Afrika...."..lol..
  12. Cisko
    6 Jun 2004
    Project PAUSED :blah:
    'll stay like this , for holiday and , i have to study for my second sess :wallbash:
    we can see the lm317 :hehe:
    and software :
    2500+@3200+
    His 9800 Pro @ defaut
    nice try, but i am from the other side of belgium , the frensh side :rock: :hehe:
  13. Cisko
    6 Jun 2004
    Hi , i get some time to work so , i do this
    bad pics , sorry , can t have the miror effect , but he is :)
    litle idea ... ll be continue
    and just 2 word about my Psu : Forton Aurora 350 W
    i just adjust the variable resistor :thumb:
    IT S ROXX :rock:
    many more tomorrow :p
    http://cisko08.free.fr/pc/mod640/up200804%20(Small).jpg
  14. xstephx
    xstephx What's a Dremel?
    21 Aug 2004
    nice job buddy ;)
  15. Aa-chan
    Aa-chan AA-CHAN
    8 Jul 2004
    I love the cas ein it's original form, but it should be even nicer when it's done. Good job on the temps aswell :) .
  16. Cisko
    6 Jun 2004
    thx, more tonight :hip:
    and i am looking for optic fibre for the second bay , hard to find it on belgium :(
  17. 330td
    330td Minimodder
    12 Aug 2004
    Conrad.de or .fr :)
  18. WNxPunk
    WNxPunk What's a Dremel?
    1 Feb 2004
    Looking good, I like the lights round the feet. :dremel:
  19. Cisko
    6 Jun 2004
    news , metal around the pump , i hope it ll block the magnetic field because i can t use my screen close of my pc :( it s an alu case so it did nt block field
    whitout flash
    other side
    and you can see a 10cm uv behind the ide
    and the back , with ****ing stain :wallbash:
    http://cisko08.free.fr/pc/mod640/up 210804 (1) (Small).jpg
    so many wire , and it s only the beginning
  20. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    Funny **** dawg :rock: :hehe: Keep modding!
