Project: City 17 HL2 Mod by Bilbo Fraggins Completed! (with some bugs to work out)
Discussion in 'Project Logs' started by Bilbo Fraggins, 9 Jul 2004.
  1. D B
    D B What's a Dremel?
    11 Apr 2004
    Have to comment on the great work you've done so far , I cant wait for each update !
    DB
  2. Soepkip
    Soepkip What's a Dremel?
    18 Jul 2004
    This rust paint also looks pretty good. I also made a HL2 mod for some guy, not als cool as yours, but it looks pretty need ;).
    BTW, why don't throw your case in water and let it be there for a week, you'll have rust :hehe: :cooldude:
  3. Pr3d470r
    Pr3d470r What's a Dremel?
    18 Jul 2004
    Hey Bilbo i made a city 17 logo for you to look at
    [​IMG] :dremel:
  4. Bilbo Fraggins
    Bilbo Fraggins What's a Dremel?
    1 Jul 2004
    hehehe Thnx for your comments :thumb:
    As for the case progress i should have the window done by today or tommorow and once thats done i can paint or do whatever the the rest of it.
    And for the logo :D i found one that is the best yet ;P sry if its big
  5. tortuegeniale
    tortuegeniale What's a Dremel?
    7 Nov 2003
    :jawdrop: please make this pic turn into reality ! :jawdrop:
  6. piloux
    piloux What's a Dremel?
    12 Nov 2003
    this logo is cool , it will be nice on your case :)
  7. Bilbo Fraggins
    1 Jul 2004
    where do you think i should put it?
    a)right side
    b)down the front where i have nothing and i need help for ideas
    c)both
  8. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    I think you should definately put it on the front, it'd look a bit isolated on it's own on one side so the front is best.
  9. D B
    11 Apr 2004
    At this stage , I would think about putting it on the front also but it looks easy to install so I would wait untill later so as to save room for last miniute inspiration
    DB
  10. Bilbo Fraggins
    1 Jul 2004
    Front it is :D
  11. Nath
    28 Dec 2003
    good choice! more pics, more pics...
  12. Bilbo Fraggins
    1 Jul 2004
    i think i can only get the logo on there.. not the c17 :( also if i put the c17 part i think it would not be as neat
  13. D B
    11 Apr 2004
    Thats OK ... just keep working on it (your case) and something will come up and you'll find the perfect place for it or you may decide that just the logo looks perfect there anyway and put the c17 in a different spot , or ? ... sometimes these things take care of themselves when you quit "fussing" over them
    DB
  14. Bilbo Fraggins
    1 Jul 2004
    Logo painted
    Ok :D i painted a logo on the front sry if the pics are a bit dark but thats the way they are
    Here is one side:
    and the other:
    With the frame:
    Thnx for the coments :)
    My next plan is to either cut out the c17 and the logo on the right side.. im debating that but i will find my answer soon. :D :thumb:
  15. invader crack
    invader crack What's a Dremel?
    18 Jul 2004
    very nice modding man... keep up the good werk
    paint is lookin very nice (i guess cuz its actualy rust or sumthing?)
    i think im diggn these hl2 mods the most outa nething being done right now :thumb:
  16. Nath
    28 Dec 2003
    If you do put that logo (cut out) on the right sight, then I think it would be a good idea to put it in the bottom-right corner of the panel (near drive cages) just so it doesn't look like it's in the middle of the sidepanel with nothing else.
    You could put a window, but missing one corner, and in the corner but the c17 logo cut out.
    Sorta like:
    ::edit:: i did a little diagram but it's not working so you'll have to use your imagination.
    except in different proportions (i.e. the corner larger) and with the c17 logo in the cut out corner.
  17. Bilbo Fraggins
    1 Jul 2004
    OK sounds good....
    If i understant this right you are sugesting to make a cut out on the right side and paint the bottom logo?? :eyebrow: lol you might have to clear that up. or get that diagram working :thumb:
  18. Nath
    28 Dec 2003
    Here it is (i had to replace the ascii art with some photoshopped goodness):
    Understand now?
  19. Bilbo Fraggins
    1 Jul 2004
    yup :dremel: i understand now but becuase i have a window on the left side of my case i think a cutout or a paint job will look nicer.. and plus my mobo slot is right there and there would be nothing to see anyway :(
    Nice work with the art though :dremel:
  20. Arkangyl
    Arkangyl What's a Dremel?
    16 Dec 2003
    I meant put the valve so the stem is glued to a button; along the same logic that you can glue anything to a button then by pressing X item you press the button.
