Project: Classified *UPDATE FEB 20*
Discussion in 'Project Logs' started by Cardan, 23 Jun 2005.
  1. Cardan
    Cardan What's a Dremel?
    21 Jun 2005
    PROJECT: CLASSIFIED
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Ok here we go....
    The theme of this is gonna be STEALTH meaning all cables will be cut and extended so you wont be able to see any cables. The Paint will be a mirror black with tinted windows. this will be watercooled and im gonna make a custon res for it. There will be speakers mounted in the front along with a PS1 LCD screen.
  2. Cardan
    21 Jun 2005
    thats the base. it will have the cut out that you see in the front and it will have that cut out on the sides too. and on the back there will be the controls for the speakers. the base will be sitting on top of a piece of 1/4 inch plexi that will be lighted to look like under glow with purple CCFLS
  3. Cardan
    21 Jun 2005
    thats how the speakers will be mounted
  4. Cardan
    21 Jun 2005
    a nice 120 mm Blowhole in the front bezel. im still working on getting the bondo smooth more pics to some soon.
    im gonna cut out that and replace it with plexi and im also gonna make a plexi mobo tray. and all that plexi will be tinted.
    il also plan on making the drivebays out of plexi.
    MORE TO COME SOON!
  5. MegadetHCl
    MegadetHCl What's a Dremel?
    8 May 2004
    Looks like you're off to a pretty good start, and that case appears to have plenty of space for everything. Is the layout of the case similar to the newer cases where the motherboard is 'upside down'?
  6. Cardan
    21 Jun 2005
    nope. this is an old Gateway 2000 server case.
  7. frodo
    frodo What's a Dremel?
    1 Nov 2003
    GO GO BONDO (aka car body filler)
    looking forward to see how this one turns out :D keep it up
  8. omicron
    omicron Baud.
    8 May 2004
    Sweet jesus that case looks huge.
    You're off to a good start, i'll watch this.
  9. mondriaan
    mondriaan What's a Dremel?
    20 Aug 2004
    Looking good so far keep up that bondoing.
  10. Cardan
    21 Jun 2005
    ok i have a question. Should i make this the res? (the can is about 7 1/2 inches tall
    or should i make a Defyant style res with tinted plexi and black modders mesh over it?
  11. Zero82z
    Zero82z What's a Dremel?
    5 Mar 2004
    I think the Defyant style res would work better, as the metal used in cans is not very strong and could get easily damaged.
  12. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    That is some sick stuff. It keeps me up long time. I think what keeps me up is the nasty taste it puts in your mouth after you drink it oh and while you drink it. Much prefer bawls.
    Well back on topic front looks cool with those grills reminds me of a face with grills as eyes and pipe as mouth. Keep up that work
  13. Cardan
    21 Jun 2005
    ok well i got some things today
    -2' by 4' piece of 1/4inch plexi
    -Key Starter
    -Window tint
    ill take a pic of the key starter as soon as i get some bateries for my camera
    expect updates soon
  14. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Hurry hurry... really lookin' forward to seeing how this turns out. -.-
    :~subscribed.
  15. Cardan
    21 Jun 2005
    and here is the starter switch
  16. perplekks45
    9 May 2004
    Watch your bandwidth dude...
  17. McDoogle
    McDoogle What's a Dremel?
    29 May 2005
    Bandwidth exceeded :(
  18. Cardan
    21 Jun 2005
    damnit. i hate it when this happens...
  19. Cardan
    21 Jun 2005
    ok the pics are fixxed
  20. perplekks45
    9 May 2004
    First: Nice starter.
    2nd: Imageshack, huh? :D
