Project ClearCase
Discussion in 'Project Logs' started by Arik.G, 26 Mar 2004.
  1. Arik.G
    Arik.G What's a Dremel?
    26 Mar 2004
    Hello to you all :D
    this is my allmost finished project that i'm working on for a while:
    (I'll let the images speak for them selves)
    i just want to say that all completly home-made.
  2. Hephaistus
    Hephaistus What's a Dremel?
    11 Mar 2004
    Woo nice, :rock:
    i like a lot the front, but you should one way or another change/stealth the front of your cd/dvd-rom :hip:
    also nice work on the dragon, but can you not hide the leds on the bodem, so it seems that de dragon shines on it's own instead of the leds.
    litle question, how did you let the dragon shine, i know about the leds,
    but how? scareving in the plexiglass or....? :confused:
    Sorry about my bad english :duh:
  3. trigger
    trigger Procrastinator
    22 Mar 2004
    Oh Yes!
    That is so good! Nice. I LOVE what you've done with shining the Red LEDs on to the dragon, that is sooo good! Is the dragon laser etched?
  4. Arik.G
    26 Mar 2004
    The Dragon is hand etched with a Dremel.
  5. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Holy Damn, you made that Dragon bu HAND!? :baby: :rock: :jawdrop: Damn, you have incredible dremel working skills man. Not to mention, very good artistry :D Great job on the case! :thumb: Although I DO have one suggestion-stealth the black optical drive in the front with some plexi. maybe you should paint the plexi like you did for the fans-you would hardly be able to tell it was there! :D
  6. Arik.G
    26 Mar 2004
    I think u missunderstood me :rolleyes: i didn't draw that dragon, it's an image i found on the net. I just copied it to that Plexy with a Dremel.
    And the front plexy is not painted, it's just a smoky color plexy.
    I know that it's a good idea to stealth that drive but not enought plexy left for that :wallbash:
    I am now working on the water cooling for that PC:
    (You can see the radiator, submergible pump 800L/H, reservour, my old WB,
    some fittings and a cooper for a new WB that is under design)
    here is a little scetch up of the new WB, It's my third attempt to build one my self.
  7. BlueMax
    BlueMax What's a Dremel?
    23 Mar 2003
    it's looking awesome, man!
  8. Hokuem
    Hokuem Guest
    wow
    Wow, this case have style!!! :rock:
    I love soooo much the power and reset switch on the front, how did you do it? :hip:
  9. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Without speaking for the poster of the project it looks like he cut out some square plexi and added a square peice of something black in the middle and lighted the outer ring with plexi. We have a modding guide of the forum for doing that somewhere...
  10. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    wow thats badass.
  11. rosec
    rosec What's a Dremel?
    22 Mar 2004
    I'm a nOOB to the modding scene but I no what I like. That dragon is quality good job, hmmm cogs whirling hmmm.
  12. piloux
    piloux What's a Dremel?
    12 Nov 2003
    congratulations , that rocks :rock:
  13. naelq
    naelq What's a Dremel?
    14 Oct 2003
    כל הכבוד!
    :clap: :clap: :clap: :clap:
  14. Arik.G
    26 Mar 2004
    After changing the water block design i came up with that:
    All was done with a dremel ONLY.
  15. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    damn sweet man. Glad your getting watercooling on it;) I was gonna say
  16. Arik.G
    26 Mar 2004
    I haven't updated the project for a long time, but now i got a few things i done. first of all i finished the water block.
    now you can see the water cooling system installed and running for a while in open case because i still checking it for leakes before i turn on the pc:
  17. hmekk
    hmekk What's a Dremel?
    17 Jul 2004
    what are the temps ? :thumb:
  18. Litecore
    Litecore What's a Dremel?
    21 Sep 2003
    correct me if im wrong here, but shouldn't there be some kinda rubber-thingey
    between the block and the plexicover to make it even more leakproof ?
    i really dont know the word for what i mean but you'll prolly understand anyway.
    just a thought, nice block though. and the gehtt0tank is great! :thumb:
    MOD ON ! :dremel:
  19. LunatiC
    LunatiC What's a Dremel?
    4 Sep 2004
    d00d! Thats dragons crazy! :rock: :rock: :rock:
    lovin it! Keep up the good work dude!! :rock: :rock:
  20. KingofHearts
    KingofHearts What's a Dremel?
    23 Sep 2004
    I think its called a O-ring. It might not be needed if he sealed it with that goopy bathtub cocking stuff I dunno. If there is nothing there at all it will eventually leak from expanding and contracting from the heat over and over again.
